Old 08-10-2005, 02:38 PM   #1
I got one!!
I brought her home Monday. 1991 31' Excella Classic. She is in need of some TLC and some work. The floor has two holes rotted thru in the front by the sofa/bed from a leak. The A/C needs some attention (not very cold). The skins are in great shape although the clearcoat is peeling. I think she looks great. My first order is to get the A/C fixed and shelter for her.
I will be in touch very soon, thanks for the support. Gary
ID:	13894   Click image for larger version
Duramax is offline   Reply With Quote
Old 08-10-2005, 03:11 PM   #2
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Post Way-to-go!
Gary,
Hey ... way-to-go! Looks great. Nice skin, awnings all around! The A/C even looks newer than the coach. Gee - you got it all!
Happy Trails!
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 08-10-2005, 03:17 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Duramax
...I think she looks great...
I do too!.
31'? It looks really lonnnnnng for some reason.
Congrats!
Tom
Old 08-10-2005, 05:10 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Nice one! Looks like a LONG LONG trailer! Good luck, keep us posted
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 08-10-2005, 06:35 PM   #5
sd90mac's Avatar
Colfax , North Carolina
Well, what a nice looking rig. Congratulations and best wishes.
Hmmmmm, I have an idea for a great maiden voyage!!
Come on down to St. Pete for the rally in September at Fort Desoto and let us all see your new acquisition. But only if you get the air fixed first. It will be to hot without it.
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 08-10-2005, 06:35 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Duramax,
Nice looking unit...where is the rot in the front? If it is about where the curve stops and the straight wall starts front and center, make sure you check the condtion of the main frame bolts...one of mine was missing and the other was wallowed out. So I basically had no stuctural rigidity, if I had continued to tow in that condition the trailer eventually would have self destructed....
Aaron
WBCCI #XXXX AIR #2495
Old 08-10-2005, 06:42 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Congratulations!
That is a good looking coach. If you want to show it off in person, you could come to the Forum Rally in St Petersburg next month (shameless plug)!
Old 08-10-2005, 07:59 PM   #8
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Gary, nice looking setup you've got there! And welcome to the Forums.
The rot in the front area of my TT was caused by a leak in hole where one of the front running lights' power wire came thru the outer skin. The Vulkem around the wire had been disturbed in some way by the PO. Once the wire was moved, if broke the Vulkem seal around the wire. Water would pour in around that wire, run down onto the window frame, then down the wall into the U-channel at the base of the wall. From there, the U-channel would fill up and eventually drip onto the floor in several areas. Whereever there was a gap in the u-channel, the floor had rotted away.
Point is, leaks can come from many areas. I have my TT completely apart in the backyard/garage/etc so it is easy for me to trace and repair leaks. Good luck.
www.nesa.org
Air No. 6427
