Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 04-23-2016, 06:55 PM   #1
Plattsmouth , Nebraska
I also need help identifying this airstream
A friend of mine passed away recently and his family knew I really like airstreams and gifted me the airstream he was restoring. He has been working on it for 4 years. I can't find the serial number anywhere in the bags of stuff yet. Can any one help me identify this airstream.
Jhiner1978 is offline   Reply With Quote
Old 04-23-2016, 08:45 PM   #2
1976 Argosy 26
Fair Oaks , California
Congrats on Airstream. No picture showing .
Argosy Heir is offline   Reply With Quote
Old 04-24-2016, 08:37 AM   #3
here is a link to the image
https://goo.gl/photos/ckPT1CMLDijwwwtv9
Old 04-24-2016, 09:25 PM   #4
Old 04-25-2016, 10:53 AM   #5
1963 22' Safari
Vail , Arizona
Serial Number info
On mine, it is on the name plate that is attached under the window to the right of the door. From the picture, it looks as if the name plate is removed and has left that shiny rectangle that is about 2 inches wide and 14 inches long.
BTW, you got a very nice gift. Now finish it up and have a good time!
morganobenn is offline   Reply With Quote
Old 04-25-2016, 11:29 AM   #6
1956 22' Safari
1955 26' Cruiser Overlander
IVINGHOE , BEDS
My guess would be a mid-late '60s Overlander, 26ft long - probably need to see a photo of the windows on the other side to be sure, but looks quite like this 1967 http://vintageairstream.com/wp-conte...2/05/06_31.jpg
airstreamian is offline   Reply With Quote
Old 04-25-2016, 11:33 AM   #7
1965 24' Tradewind
GREENWOOD , South Carolina
Looks like my 1965 tradewind
CINDISUE is offline   Reply With Quote
Old 04-25-2016, 01:39 PM   #8
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
s/n locations
The serial number may also be stamped on the front frame rail near the propane tanks
rvb is offline   Reply With Quote
Old 04-25-2016, 08:16 PM   #9
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
Is it possible to lookup the Airstream number on the front above window and get some info?
PeterKV is offline   Reply With Quote
Old 04-25-2016, 08:33 PM   #10
I went there today and found what I was looking for the plate that was removed..
As I can tell its a International 28' Ambassador from cali with the double bed
He labeled everything thankfully because its all in pieces. I think my first step is finish up the frame and then rivet the bottom skin on then new axles wheels insulation then floor, all before I put the top skin back on.
I need a step by step guide. Is there something link that around?
Old 04-25-2016, 08:47 PM   #11
1968 26' Overlander
Manheim , Pennsylvania
Click in General Repair forum and start reading in the first link that shows up "Stickys link to the major renovations" From the looks of that photo, you are at ground zero. How is the frame? Rusty? Freshly painted? Make sure the frame is good and solid, then put a good subfloor on top of it. That's your next step. After that you can either "flip the frame" to refinish the belly pan, tanks, belly insulation, or you can reattach the shell and move everything if you can't keep workin on it there. Good luck! Looks like an awesome fun project. Lots of work, time, and money. But you will have a classic when you are done! Looks like a '66-'68?
SonOfAnder
'68 Overlander
https://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 04-25-2016, 08:54 PM   #12
1999 30' Excella 1000
small town , Maryland
Welcome to forum Jhiner1978. Sorry to here about your friend's passing. Sounds like your more than a friend...your family
streaminwild is offline   Reply With Quote
Old 04-25-2016, 09:01 PM   #13
The frame is in great shape, I just need to paint it and go from there
Old 04-25-2016, 10:30 PM   #14
1973 31' Sovereign
Middletown , California
I'd guess a '68 or '69, good years. Should be able to tell from numbers on A frame. Best wishes on getting it back together.
ijustlee is offline   Reply With Quote
Need help identifying this little airstream conric Vintage Kin 8 07-31-2015 01:51 PM
Need help identifying my Airstream Airstream_ID Airstream Trailer Forums 2 11-08-2014 08:10 PM
I need help identifying these rims NatchezBear Wheels, Hubs & Bearings 4 11-02-2008 06:31 PM
Need help in identifying this Airstream JimGolden On The Road... 10 01-01-2007 01:56 AM
Need help identifying old Airstream! KY Girl Our Community 3 12-12-2002 06:16 PM
