Old 09-27-2014, 03:42 PM   #1
2012 16' International
Bratenahl , Ohio
Hitches
I'm a newbie and could really use some hitch advice from one of you experienced Air-streamers. I ordered a new Flying Cloud 25 foot that shows a GVWR of 7300 lbs. I also ordered a Ford F150 with the correct axle and all towing options. Now while I'm waiting on them to come in, I'm trying to figure out my hitch. My dealer wants me to use the E2 Fastway...probably because that's what they sell. I've talked to Hensley and they say the Hensley Swift Arrow. Reese says the RP66084. Who do I believe or where do I get un biased advice? Thanks in advance for any help.
Sent from my iPad using Airstream Forums - Fred
FKemp0850 is offline   Reply With Quote
Old 09-27-2014, 03:47 PM   #2
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
I'd sure take a serious look at the ProPride too!
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 09-27-2014, 03:50 PM   #3
Bratenahl , Ohio
Thanks!
Old 09-27-2014, 03:50 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, The hensley and propride are both over kill for your trailer. Check out the BlueOx Swaypro.
MICHAEL
Old 09-27-2014, 03:52 PM   #5
Bratenahl , Ohio
OK...thanks!
Old 09-27-2014, 03:56 PM   #6
1977 27' Overlander
Carrollton , Texas
The Eaz-Lift Prostar with the 9.5' drop if truck is 4x4. 10,000# towing.
KL's 77 is offline   Reply With Quote
Old 09-27-2014, 03:58 PM   #7
Road Ruler's Avatar
Images: 38
Considering a new truck and trailer, I would beg to differ. A 25' over 7,500 lbs is getting up there and if it were me I would be looking at the Hensley, Propride offering.
Old 09-27-2014, 04:01 PM   #8
Bratenahl , Ohio
Since this is my first trailer...I might go up to a larger one someday and then I'll need a better hitch for sure. So, is there any reason I shouldn't get the Hensley now and just be done with it? Will it cause me trouble with my 25 foot?
Old 09-27-2014, 04:04 PM   #9
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
I personally like the design of the air-safe hitch.. even though i did not try it yet..propably another alternative to the ones mentioned above.
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 09-27-2014, 06:18 PM   #10
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I have a 2014 25 flying cloud and my TV is a 2013 Ford F250 FX4 Diesel I myself picked a Equalizer hitch. It works I've logged lots of miles and never had any issues. It's a good hitch for the money.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 09-27-2014, 06:39 PM   #11
I am picking up a new 25 flying cloudFB next month. My TV is a Chevy 2500 HD Diesel. The Airstream dealer is recommending an Equalizer E4 hitch 12000. I had previously planned on purchasing a ProPride. I realize that there are many, many opinions on which hitch is best. I am trying to determine if the Equalizer will do the job and provide safe towing. Silverbp can you elaborate on your experience with the Equalizer. Interested in others on the forum opinion on effectiveness of the Equalizer E4. Also on whether the size of the Equalizer needed for my setup.
Magic Carpet is offline   Reply With Quote
Old 09-27-2014, 06:50 PM   #12
silverbp's Avatar
LaMarque , Texas
Well I also looked the PP hitch and talked to lots of folks before went the way I did. Just could not see spending twice to three times as much for a hitch that didn't work any better then the Equalizer hitch. I have the very same hitch that you listed and I can't be any happier. I'd say save the money and put it toward something worth wild. It's your call. Bill
Old 09-27-2014, 07:18 PM   #13
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Equalizer standard hitch with 1000# bars for the last 6 years ... but more bar than is really needed. I'd get the softer bars if I had it to do over again.
2015 25' Eddie Bauer International Sp Ed
2017 GMC Yukon SLT; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 09-27-2014, 08:12 PM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have used Equal-I-Zer, Andersen, and now use a ProPride hitch. The Hensley/ProPride design works differently than all other hitches, projecting all push or sway forces forward to the truck rear axle, where they are stopped before they can occur. All other receiver mount hitches leverage push or sway forces forward to the truck steering axle, a much less desirable condition.
Those who use Hensley/ProPride will most probably highly recommend them, those who don't usually recommend a variety of others.
A half-ton truck and a 25' Airstream is a dream to tow using the Hensley/ProPride design, and ProPride is a less expensive and a newer, improved version of the Hensley.
Doug and Cheryl
Help on Hitches clown Hitches, Couplers & Balls 4 09-23-2003 02:31 PM
Towing Hitches deblue Hitches, Couplers & Balls 0 08-20-2003 11:02 PM
"Quality S' hitches? drboyd Hitches, Couplers & Balls 1 07-07-2003 08:51 PM
differences in reese hitches Craig Hitches, Couplers & Balls 7 06-15-2003 07:01 PM
Blue Ox Hitches... crazylev Hitches, Couplers & Balls 4 03-12-2003 11:01 AM
