Old 09-27-2014, 03:42 PM   #1
2012 16' International
Bratenahl , Ohio
Hitches
I'm a newbie and could really use some hitch advice from one of you experienced Air-streamers. I ordered a new Flying Cloud 25 foot that shows a GVWR of 7300 lbs. I also ordered a Ford F150 with the correct axle and all towing options. Now while I'm waiting on them to come in, I'm trying to figure out my hitch. My dealer wants me to use the E2 Fastway...probably because that's what they sell. I've talked to Hensley and they say the Hensley Swift Arrow. Reese says the RP66084. Who do I believe or where do I get un biased advice? Thanks in advance for any help.
Sent from my iPad using Airstream Forums - Fred
FKemp0850 is offline   Reply With Quote
Old 09-27-2014, 03:47 PM   #2
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
I'd sure take a serious look at the ProPride too!
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 09-27-2014, 03:50 PM   #3
Bratenahl , Ohio
Thanks!
Old 09-27-2014, 03:50 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, The hensley and propride are both over kill for your trailer. Check out the BlueOx Swaypro.
MICHAEL
Old 09-27-2014, 03:52 PM   #5
Bratenahl , Ohio
OK...thanks!
Old 09-27-2014, 03:56 PM   #6
1977 27' Overlander
Carrollton , Texas
The Eaz-Lift Prostar with the 9.5' drop if truck is 4x4. 10,000# towing.
KL's 77 is offline   Reply With Quote
Old 09-27-2014, 03:58 PM   #7
Road Ruler's Avatar
Images: 38
Considering a new truck and trailer, I would beg to differ. A 25' over 7,500 lbs is getting up there and if it were me I would be looking at the Hensley, Propride offering.
Old 09-27-2014, 04:01 PM   #8
Bratenahl , Ohio
Since this is my first trailer...I might go up to a larger one someday and then I'll need a better hitch for sure. So, is there any reason I shouldn't get the Hensley now and just be done with it? Will it cause me trouble with my 25 foot?
Old 09-27-2014, 04:04 PM   #9
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
I personally like the design of the air-safe hitch.. even though i did not try it yet..propably another alternative to the ones mentioned above.
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 09-27-2014, 06:18 PM   #10
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I have a 2014 25 flying cloud and my TV is a 2013 Ford F250 FX4 Diesel I myself picked a Equalizer hitch. It works I've logged lots of miles and never had any issues. It's a good hitch for the money.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 09-27-2014, 06:39 PM   #11
I am picking up a new 25 flying cloudFB next month. My TV is a Chevy 2500 HD Diesel. The Airstream dealer is recommending an Equalizer E4 hitch 12000. I had previously planned on purchasing a ProPride. I realize that there are many, many opinions on which hitch is best. I am trying to determine if the Equalizer will do the job and provide safe towing. Silverbp can you elaborate on your experience with the Equalizer. Interested in others on the forum opinion on effectiveness of the Equalizer E4. Also on whether the size of the Equalizer needed for my setup.
Magic Carpet is offline   Reply With Quote
Old 09-27-2014, 06:50 PM   #12
silverbp's Avatar
LaMarque , Texas
Well I also looked the PP hitch and talked to lots of folks before went the way I did. Just could not see spending twice to three times as much for a hitch that didn't work any better then the Equalizer hitch. I have the very same hitch that you listed and I can't be any happier. I'd say save the money and put it toward something worth wild. It's your call. Bill
Old 09-27-2014, 07:18 PM   #13
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Equalizer standard hitch with 1000# bars for the last 6 years ... but more bar than is really needed. I'd get the softer bars if I had it to do over again.
Old 09-27-2014, 08:12 PM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have used Equal-I-Zer, Andersen, and now use a ProPride hitch. The Hensley/ProPride design works differently than all other hitches, projecting all push or sway forces forward to the truck rear axle, where they are stopped before they can occur. All other receiver mount hitches leverage push or sway forces forward to the truck steering axle, a much less desirable condition.
Those who use Hensley/ProPride will most probably highly recommend them, those who don't usually recommend a variety of others.
A half-ton truck and a 25' Airstream is a dream to tow using the Hensley/ProPride design, and ProPride is a less expensive and a newer, improved version of the Hensley.
Doug and Cheryl
Old 09-27-2014, 08:42 PM   #15
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I'm using the Equal-I-Zer hitch. Its been fine, provides plenty of weight distribution. Using 1200 bars. Never had a sway problem, though it could be I've just been lucky.
kscherzi is offline   Reply With Quote
Old 09-28-2014, 12:01 AM   #16
Bratenahl , Ohio
Thank You to everyone! Fred
Old 09-28-2014, 03:20 AM   #17
2004 16' International CCD
Chicagoland , Illinois
I seriously considered the Hensley/ProPride systems. I believe that there are several good reasons to consider other options.
The Hensley/ProPride systems have had at least some documented failures. These systems are also extrememely heavy compared to their much less expensive counterparts. They may "steal" close to 100 lbs. from your available payload. For many folks who care about staying safe, that's just not weight that they have available. Finally hitching up can be very difficult with these systems. It can take lots of fancy maneuvering to mate the TV to the TT. How much time do you really want to spend at the campground trying to hitch up? I've found that much more than a few minutes can start to bring out the highly-opinionated crowds...
Airrogant is offline   Reply With Quote
Old 09-28-2014, 05:08 AM   #18
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Pro Pride gets my vote. Support from Shawn @ PP is excellent. One tends to support the product that they own. Having had experience with several brands in the past I heartily endorse the PP.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 09-28-2014, 05:12 AM   #19
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
How much money do you have?
If money does not limit your decision, get the ProPride. Hensley and ProPride work on the same principle. ProPride seems like the "new and improved" Hensley. Sean at ProPride used to work for Hensley.
All styles/brands have merit. Reese Dual Cam users love them. I understand why.
I have had an EazLift- a very simple effective design and the least expensive-
I now use an Equal-i-zer. It is a very simple design snd it works well, but if I had $2,300 I would but a ProPride hands down.
The best part about the Equsl-i-zer is the ease of use/hitching and unhitching. Also, Equal-i-zer's customer service is top notch.
I expect customer service at ProPride or Hensley would be good, also.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-28-2014, 05:29 AM   #20
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
I have this: Reese unit, Strait-Line Weight Distribution System w Sway Control - Trunnion Bar - 12,000 lbs GTW, 1,200 lbs TW
I think if properly set up, ball tilt, tension on the trunnion bars, etc., this hitch provides excellent resistance to the most common problem I have encountered, that is the pulling of the trailer to the road side as one is being passed by a large truck, i.e., semitrailer truck. And, as I like to tow about 62-64 mph, I am passed a lot on the Interstate highways. The condition is exacerbated when a cross wind is present.
With my current adjustments, giving me weights on my axles of about 4400 front, 4300 rear, and a bit over 7000 for the trailer, I rarely have any pull from a semi.
As I said, the correct set up is critical with any hitch, and this may not always be the first set up tried. I have made adjustments in truck stops with trunnion bar tension, length of the sway control contact points, and number of chain links hanging down.
The final result is the weight data above.
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Help on Hitches clown Hitches, Couplers & Balls 4 09-23-2003 02:31 PM
Towing Hitches deblue Hitches, Couplers & Balls 0 08-20-2003 11:02 PM
"Quality S' hitches? drboyd Hitches, Couplers & Balls 1 07-07-2003 08:51 PM
differences in reese hitches Craig Hitches, Couplers & Balls 7 06-15-2003 07:01 PM
Blue Ox Hitches... crazylev Hitches, Couplers & Balls 4 03-12-2003 11:01 AM
