Old 08-22-2005, 11:19 PM   #1
Talking Help with Year and model of Airstream
I recently looked at an old airstream with 15 panels on each end with flat windows. The trailer title has the year listed as 1950 and the length is 28' with two axles. The confusing part is that this trailer does not have a pipe frame? I was under the impression that pipe frams were on all trailers through 1951? Does any one have any photos of the models offered in 1950?
Looking hard
Lookinghard is offline   Reply With Quote
Old 08-23-2005, 12:37 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
While this 1950 Cruiser may not be an exact match to the one you are looking at...it does state that the "early ones were pipe-frame, later were conventional chassis" in 1950. Also this 1951 Cruiser shows the 15 panels...
You can see there was a 28' called the Whirlwind in 1950 & 1951...but no pictures are currently in the archive...my guess is that you have a very late 1950 Whirlwind, do you have the serial number?
If you end up getting this trailer, let RJ know...he may want to add your pictures to his website.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 08-23-2005, 08:15 AM   #3
Ss #
Shari
The Serial Number is 5020.
Old 08-23-2005, 09:31 AM   #4
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
A 1953 29-ft. Airstream Liner
Lookinghard:
Serial number 5020 sounds like a 1953 29' Liner with tandem axles. Overall length is 29', body length is 26', and weight is 3980 pounds (those are rounded, not actual, numbers). If the front window set has two vertically hinged outside windows and a fixed center pane, then its a 1953 Airstream notwithstanding the year on the state title or registration.
My data shows the 1953 29' Liners began at s/n 9000. But during the year they must have changed to begin anew at 5001, as the 1954 30' Liners begin at s/n 5100 and your 5020 is in between, proof tandem axle trailers exist with 50XX serial numbers.
Is the back end on the trailer you are looking at sloped out a foot at the bottom or purely vertical? If sloped, its a 30' Liner; if straight vertical, its a 29' Liner.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 08-23-2005, 10:16 AM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by 47WeeWind
Lookinghard:
Lookinghard,
Can you post a picture. The serial number of my Double Door Liner is O 5006 and I thought that it was a 1954 made in Ohio.
Fred,
I have the two small vertical windows and a large center fixed window, do I have a 1953. RJ's site has pictures of the 1954's only and not 53'. It also states that the 53's were 32' long. My Liner has an internal dimension of 25' 11" with a 22" tongue. Pictures of mine are available on RJ's site, my 1954 Liner thread and Tom Patterson's site.
The empty weight of mine is 3020.
Bill
Just my personal opinion
Old 08-23-2005, 12:29 PM   #6
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
Originally Posted by wkerfoot
Lookinghard, can you post a picture. The serial number of my Double Door Liner is O 5006 and I thought that it was a 1954 made in Ohio.
Fred, I have the two small vertical windows and a large center fixed window, do I have a 1953? RJ's site has pictures of the 1954's only and not 53'. It also states that the 53's were 32' long. My Liner has an internal dimension of 25' 11" with a 22" tongue. Pictures of mine are available on RJ's site, my 1954 Liner thread and Tom Patterson's site. The empty weight of mine is 3020. Bill
Hi Bill:
I had assumed, without knowing, that Lookinghard posted the complete trailer serial number and that it did not have an "O" prefix. If it does have an "O" prefix, then the trailer he is looking at would have been built in Ohio instead of California, as I had assumed, and my answer would change quite a bit. Your post raises another possibility, but I'll wait for Lookinghard to indicate whether or not serial number "5020" has an "O" prefix before changing my initial answer to his inquiry.
Lookinghard, is there an "O" prefix to "5020"? Please advise, & thanks.
Bill, your double door Liner "O 5006" ["O" for Ohio] was the sixth 30' Liner built in Jackson Center, Ohio for the 1954 model year. The three light [window pane] Hehr front window set, with two vertically hinged side windows and a fixed pane center window, was used for a few years around the mid-1950s, so they are not specific to 1953 alone. However, they were not used in 1950/51 so they can distinguish a 1953/54 trailer from a 1950/51 trailer, which is why I asked Lookinghard about them.
Airstream Life
"From the Archives"
Old 08-23-2005, 04:43 PM   #7
Ss #
There is no "O" in the serial number. What cought my eye was the plate had the main street address in LA. Most other airstreams I have looked at do not have the main street address? The back does not slope, it is vertical. And the front window does have a fixed pane in the middle with two verticaly hinged side windows?
Looking Hard
Old 08-23-2005, 06:14 PM   #8
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
Originally Posted by Lookinghard
There is no "O" in the serial number. What cought my eye was the plate had the main street address in LA. Most other airstreams I have looked at do not have the main street address? The back does not slope, it is vertical. And the front window does have a fixed pane in the middle with two verticaly hinged side windows? Looking Hard
Thanks, Lookinghard. The absence of the "O" in the Liner serial number indicates "5020" is a California built trailer, so I'll stick with my original reply. The "O" was added to early Ohio built trailers only because they, too, at first used serial number plates having the 1755 No. Main Street, Los Angeles, California factory address. Many Airstream serial number plates from late 1949 to around 1960 used the 1955 N. Main St. address. But a second California factory opened in 1950 at 12804 E. Firestone Blvd. in Norwalk, Calif., so a second serial number plate with that address was used fom 1950 to 1958, when the city name for the same street address was changed to Santa Fe Springs, Calif.
The sloped back was a new feature introduced for the 1954 model year, so the 13 panel vertical rear Liner you are looking at is most likely a 1953 model.
Airstream Life
"From the Archives"
Old 08-23-2005, 09:34 PM   #9
15 Panels
Sounds Good. By the way, the rear is not 13 panels, it's 15 with no slope. Does that change anything? Thanks for all the info!
Old 08-23-2005, 09:35 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Lookinghard,
Pictures would really help.
Bill
Old 08-23-2005, 09:38 PM   #11
RichardT's Avatar
The 13 panels are the segments that make up the curved part. The panels on either side are not counted.
RichardT is offline   Reply With Quote
Old 08-23-2005, 10:29 PM   #12
How do I upload a photo from my harddisk?
Kevin
Old 08-23-2005, 10:33 PM   #13
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Kevin
Kevin,
At the bottom of the reply to thread there is a section called Additional Options. There you will find Manage Attachements. Click on that and a new box will open for you to find the pictures on your hard drive. The pictures must be less than 100K. Locate the file, click upload, then close. Submit Reply and you are done.
Bill
Name:	The Liner is home.JPG
Old 08-23-2005, 10:37 PM   #14
This is all I have. I counted the panels on the front and back and there was 15.
'78 airstream trailer lbf78SvgnInt31 General Interior Topics 4 10-21-2006 12:09 PM
exterior finish durability vs. model year Kirby Stone Exterior Restoration Forum 16 08-08-2003 09:34 AM
Location, year, model! Pahaska Our Community 0 07-13-2003 09:57 AM
Looking for my perfect Airstream. again MikeF Our Community 3 12-20-2002 08:50 PM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum Admin, News and Member Account Info 2 10-15-2002 06:38 PM
