Old 02-13-2015, 06:45 AM   #1
AirstreamBCC
2006 25' Safari
black canyon city , Arizona
Help with musty smell
Hello everyone,
I am new to the forum. I live full-time in a 2006 Safari. I had a musty smell in the cabinet below the frig and then. I had a mobile repair come out, they replaced the sureflow valve that was leaking (where the hose goes into the rv for water). It was leaking between the aluminum skin but manifested itself by a drip outside gray tank cover. This was over 6 weeks ago and the musty smell remains, sometimes, better sometimes worse. Now I smell in the coach too. I had the repair service come again and he found nothing.
Any suggestions on what might be my problem?
I appreciate any help!
Shelley S
shelleysnyde is offline   Reply With Quote
Old 02-13-2015, 06:58 AM   #2
SteveH's Avatar
Common Sense , Texas
May be mold from the water leak. Do everything you can to dry out the inside, use Fabreeze on the fabrics, open a box of baking soda and leave in the suspect area, and pour some vinegar in a shallow pan and leave it out.
Regards,
Steve
Old 02-13-2015, 07:26 AM   #3
JConsroe's Avatar
2005 28' International CCD
Salem , Virginia
I suggest getting a moisture meeter and probing the floor to see if you have some wet floors in that cabinet or elsewhere. Then get access to a dehumidifier and direct the airflow into that cabinet. Follow up with a couple silica get packs to keep it dry.
JConsroe is offline   Reply With Quote
Old 02-13-2015, 07:33 AM   #4
Lily&Me's Avatar
Normal , Illinois
I have just had that problem under the rear bench where I keep a small pantry of food.
There had been condensation from very cold temps early in this trip.
I emptied everything out, cleaned the area thoroughly and inspected for mold and mildew.
I found and threw away several boxes of pasta which had gotten damp and molded...ugh!...because I had failed to empty them from the boxes into ziploc bags, as I usually do.
Finding no surface mold or mildew, I wiped it all down with my favorite cleaner...PineSol ....and put my small space heater to the area for several hours.
Seems to have resolved the problem. Getting it thoroughly dry is the critical part.
Good luck,
Maggie
Old 02-13-2015, 08:16 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
A couple of charcoal briquets crushed and in a plastic dish works well also as well as coffee grounds.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 02-13-2015, 10:15 AM   #6
AirstreamBCC
2006 25' Safari
Thanks for replies
Thanks for the replies everyone, appreciate. I am going to try the baking soda, as I can't use chemicals. If it doesn't go away (headache as we speak) unfortunately next step is tow to shop (there should be a $$$$$$$$$$$$$$ emoticon!
Old 02-13-2015, 10:18 AM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Dry rice works great too. Just unceremoniously dump a big bag over the area. Over a couple of days it will absorb most of the water. (works to dry out a cell phone too)
Ozium makes one of those canister moisture/odor eliminators. Makes it smell nice while it dries out. Bueno Suerte. And Welcome!
NavyCorpsman is offline   Reply With Quote
Old 02-13-2015, 10:25 AM   #8
Vintage Kin
Fort Worth , Texas
Clean as directed. Check with moisture meter. Dry with forced air and/or low humidity. Rent or borrow an ozone generator to use with HVAC fan.
If you haven't treated for insects lately, then do so prior to 0 treatment.
Old 02-13-2015, 10:37 AM   #9
Lily&Me's Avatar
Normal , Illinois
The odor in mine gave me a headache, too.
You've checked thoroughly for something actively molding/mildewing??
It sounds like an active problem rather than just dampness....just speaking from my own experience....because it is getting worse.
Maggie
Old 02-13-2015, 10:46 AM   #10
AirstreamBCC
2006 25' Safari
Hi Steve, I have never heard of a moisture detector, is it something industrial you rent, buy? Will do online search too.
Old 02-13-2015, 10:47 AM   #11
AirstreamBCC
2006 25' Safari
Hi Maggie, can't find any moisture, very frustrating, maybe something else is going on besides result of valve leak, having friend come to take wood seat off bench near the area to see if we can find anything.
Old 02-13-2015, 10:48 AM   #12
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I think Bruce in his "bwoodtx" post means for you to use dry coffee! Just sayin'.
Cannonball is offline   Reply With Quote
Old 02-13-2015, 10:49 AM   #13
AirstreamBCC
2006 25' Safari
by forced air do you mean ac? MIne is roof unit, I'm in Arizona and now in high 70's low 80's so can't run heat. I will try a small fan and put in area. thanks
Old 02-13-2015, 10:51 AM   #14
Lily&Me's Avatar
Normal , Illinois
That's a good idea.
Get some heat and air in there....leave it all open for a day or two if you can.
Keep us posted.
Maggie
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
musty carpet odour from leak anniem Upholstery, Blinds, Walls & Interior Finishes 5 09-01-2014 07:34 AM
Musty odor: water damage? Ssmookler General Repair Forum 9 08-17-2014 08:41 PM
Mildew and musty odor gamakai Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-27-2012 02:05 PM
Old Musty Smell rebelstand General Interior Topics 29 07-08-2011 04:51 PM
