02-14-2015, 07:25 AM
#21
Normal
Have you found a source for the odor?
Maggie
02-14-2015, 07:34 AM
#22
1976 31' Sovereign
Missouri City
Has anyone tried this product RV Shocker ClO2 Odor Eliminator
RV Shockerâ„¢ ClO2 Odor Eliminator
Don Hardman
1976 31' Sovereign
02-14-2015, 05:11 PM
#23
1976 31' Sovereign
Missouri City
Originally Posted by TomKirk
After you've tried everything else, rent an ozone machine for a few days. O-3 is toxic, so you'll hafta move out while it's on.
There mustn't be any sparks of any kind. Be sure to turn off all propane and all electric. Close all windows and doors. Go on vacation for a few days.
They use these in car dealerships for stinky used cars. Ever wonder why a used car can smell so fresh?? It's the ozone machine.
Good luck.
Tom
Something like this?
http://www.amazon.com/Enerzen-Commer...=ozone+machine
Don Hardman
1976 31' Sovereign
02-15-2015, 10:14 AM
#24
1977 31' Sovereign
Lynnwood
[QUOTE=adonh;1581020]Something like this?
Yep - You're on the right track.
But what I had in mind was an "industrial-strength" machine that a car dealer or professional detail shop would use; a really heavy-duty rig you would likely rent at a tool rental store. Compare this machine with what the pro's use.
Tom
02-19-2015, 07:12 AM
#25
AirstreamBCC
2006 25' Safari
black canyon city
Hi Jay,
I am looking on youtube for how to videos for the gray water vent, there is something in my rv, in the the access panel to the right of the frig that looks like your picture, could this be it or is it located on the roof? Also, you mentioned you purchased at hardware store, I assume it would have to be in a rv section that the hardware store may have otherwise rv prodocts store? Thanks in advance!
02-19-2015, 09:59 AM
#26
2002 19' Bambi
Northwestern Ontario
, - on the backside of the map and just above the big green spot
Here is a picture of how the vent ties into the rest of the plumbing in our Bambi. This shot is taken through the outside access door into the storage space under the bed. The plumbing you see coming from the left drains from the shower and then on past the vertical section of pipe that you see and down through the floor (not seen) into the grey water tank. The vent simply screws into the top of that vertical section of pipe.
The location of the vent may be different in your trailer but the basic plumbing configuration should be the same - at the top of a short vertical section of plumbing that is tied into a T shaped fitting located on the floor of the trailer. The plumbing schematics in the Airstream manuals that came with your trailer might help out.
In our trailer that vent is reachable (with a bit of a stretch) from the access door where I am taking the picture - otherwise I would have had to remove the floor of the bed (seen above the vent) to get at it from the interior of the trailer. It should only be hand tight.
Once you get a whiff of what the inside of that vent smells like you will know if you are in the right ball park .....
Take the old one into the hardware store to make sure you get the right size - I believe the vent is threaded for a 1 1/2 inch fitting but best to be sure. This is a basic plumbing part - it is not RV specific - you will find it in the plumbing section of the hardware store.
Hope this all makes sense - that it is helpful - and that you can get your musty smell chased down and eliminated!
Good luck!
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
02-20-2015, 06:17 AM
#27
AirstreamBCC
2006 25' Safari
black canyon city
Thanks so much jay. I found it and will remove and see if that is the source. I really appreciate the follow up.
#28
AirstreamBCC
2006 25' Safari
black canyon city
Hi Maggie, still working on it unfortunately
02-20-2015, 08:32 AM
#29
Normal
Bummer!
Sounding serious, unfortunately.
Keep us posted.
Maggie
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
musty odor
Elaine and Bohdan |
Dehumidifiers & Ozone Generators |
20 |
12-08-2015 12:18 AM |
musty carpet odour from leak
anniem |
Upholstery, Blinds, Walls & Interior Finishes |
5 |
09-01-2014 07:34 AM |
Musty odor: water damage?
Ssmookler |
General Repair Forum |
9 |
08-17-2014 08:41 PM |
Mildew and musty odor
gamakai |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
5 |
09-27-2012 02:05 PM |
Old Musty Smell
rebelstand |
General Interior Topics |
29 |
07-08-2011 04:51 PM |
