Old 12-09-2003, 07:23 AM   #225
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Maybe. Patty is going to see if she can clean it first. As far as the velcro goes, we will tend to keep the curtains open since we have these neat shades on the Classic. On the Safari the curtains were a must. So the fact that the velcro isn't correct is not really a big problem.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 12-09-2003, 07:45 AM   #226
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Jack
I stopped my wife last weekend when she started to close the curtains in our Classic for exactly the same reason. The day-night shades are all that is required for privacy and if we don't touch the curtains, they will stay clean a whole lot longer. The velcro could be missing for all I care.
I did close the curtains in the bedroom on a night that was predicted to go below freezing, just as additional draft protection. Ordinarily, they will stay open all the time.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 12-09-2003, 11:41 AM   #227
KIMILI's Avatar
2004 25' International CCD
Salem , Massachusetts
Smile Yabba dabba dooo!!!!
Congratulations Eric!!!
Santa delivered early... or just on time for Chanukah!
Can't wait to see pics
Enjoy your full week with your new baby and drive safe.
take care
Cheers!
KIMILI
KIMILI is offline   Reply With Quote
Old 12-10-2003, 08:07 PM   #228
Hi All,
Finally home from the maiden voyage. To refresh memories (Since I'm new here), my 2004 AS Classic 30foot Slide Out (traded our 1996 AS 21 foot Sovergn) arrived at the dealer on Nov. 14th. Had solor & a Henley Arrow Hitch installed and picked her up on the 19th. One night spent on the dealers lot without a glitch, and we were on our way to a favorite camp spot for two weeks. Must admit we were nervous about towing the additional length, but that soon faded away. She followed beautifully, even thru some pretty nasty weather coming home.
We did run into a couple of problems which I'll list below. These issues I believe I can most likely correct myself.
1. Black water tank sensor not registering at all.
We were told at the dealer that the monitoring system had- had a loose wire fixed at some point. I regretted not asking them more about this, but I just assumed they had corrected the problem... Whatever that was. My guess is that it wasn't recallibrated properly, which I think I can do myself. If anyone has any guidence along these lines I'd appreciate the input.
2. In preparation to return home the 'Slide Out' would not close properly. Must admit this one had me panicing for awhile there! The whole room was slightly tilted, creating a good size gap between the slide out & the trailer itself when closed. Fortunately we discovered that there are levelling bolts beneath the slide out (While open) on each side. A few turns of a wrentch on the left one lifted that side, which enabled the slide out to close as it should. Hopefully that was a one-time deal, but it's good to know those bolts are down there!
Aside from those issues, She's a real dream. We also upgraded the A/C, and found the heat pump very useful. It switched perfectly from HP to furnace when temps. dipped below freezing. We were able to get the 2003 'Cashmere' color scheme, which we like very much. Our previous AS had the cloth couch, which held up to pets & camping dirt beautifully, so we chose the cloth again. I installed a small flat screen LCD TV in the bedroom during the trip, which works out real well. It's pretty yummy back there.
Came home to a household furnace that's bit the dust, which makes me think my Airstream is the place to be these days!!
Mike D is offline   Reply With Quote
Old 12-10-2003, 08:52 PM   #229
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Thumbs up
Congrats on the Airstream, Mike!
Sounds like you got yourself a very nice trailer ... and the problems seem minor. You'll get them settled out.
Who was your selling dealer?
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 12-10-2003, 08:53 PM   #230
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Hey Mike, congrats on the new coach! Great to hear the probs were minor. Do you have any pics to share?
Eric
Old 12-11-2003, 08:00 AM   #231
jcanavera's Avatar
Fenton , Missouri
Images: 143
Mike, there is a small booklet that should be in your Airstream folder that documents the procedure for calibrating your sensor panel. When you first turn on the panel, the unit flashes a sequence of lights. That initial pattern tells you whether the unit was calibrated or not.
The first words out of the dealer's mouth was do not open or close the slide out unless the trailer is level and the stabilizer jacks are down. I'm not sure by your description whether you met those two criteria prior to your problem. I haven't really looked for any other adjustments at this point. I've had the slide in and about about 10 times either at the dealer's lot or at home in the drive. All seems well at this point.
One other trick my dealer told me was to look at the slide out from the outside before I extend it. The gap between the slide and body of the trailer should be equidistant on all sides. If not it means you either aren't level or you have a stabilizer jack improperly set.
Patty has also talked about a small flat panel TV on the wall in the bedroom rather than using that pull down shelf. Any problems in securing that to the wall? What did you use?
I'm curious about your heat pump performance. Did the heat pump initially have to warm up a cold trailer (<40 degrees)? I upgraded to the 15K air conditioner but don't think that the heat pump has enough volume to keep our unit stable once you get into the 35 degree or below range much less bringing a cold unit up to a comfortable state.
Congratulations!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-16-2003, 08:22 AM   #232
Aluminut
2004 25' Safari
. , Illinois
Ok...here is the long awaited info on the fit and finish info on my new 2004 Safari SS production dated 12/03.
Got there yesterday morning and took a look around....the inside had one or two very small things that will be easily and quickly resolved by the dealer. The unit appears far better assembled than my '03. The darn camper is just plain beautiful in every aspect. It is more beautiful that I could have ever imagined. The photos I posted and the photos that you can find on the web just don't do these new units justice.
Now for the not so good news. The dinette bases were soaked. Somewhere water got into the unit. Funny thing is that there is no trace of water except by the dinette seat bases (which makes me think that the A/C that was piled with snow might have let some water in when they washed it as the ice dam could have created a lake around the A/C unit on the roof). The seat toward the back was the worst while the one toward the front (side dinette) was not as bad. I do not believe it was a factory issue Q/C issue at all. I am leaning toward the dealer possibly not winterizing it correctly or something. Actually, I spoke with a few folks at Jackson Center while I was on the factory tour and the travel trailer production manager started to look into it...he actually knew my unit as it just left the factory about a week ago...
At any rate, here is what the deal is as of right now....
The dealer and Jackson Center are going to find out what went wrong and fix it. There is no doubt in my mind that this will happen. As a matter of fact the production manager and the customer service manager both were on the phone to the dealer to see where they were at and trying to assess where the water came from and resolve the issue. Keep in mind the unit passed the water inspection test just about a week ago before the dealer got it.....
The dealer also said that since I came down, I could leave my Bambi there at no charge until this is resolved and here is the really nice part...when the problem is found and the unit repaired, the dealer is going to have the unit brought 300 miles to my house! I was pretty floored!
Based on the info Kimili posted (and thanks to Brandi for reminding me), I did NOT sign the papers to take delivery. This will all be done after the unit is fixed and Q/Cd.
The water thing does bother me a bit, but I trust that between Jackson Center and the dealer (approx 25 miles apart) that this will be resolved. But I have to say, the unit other than that as far as I could tell is pretty flawless.
I want to stress to you all that we watched the QC folks on the line. The woman that was going through the units has a bible size book she goes through. The unit passed all inspections last week when it left to go to the dealer. When more info becomes avail, I'll post it.
Airstream as well as the dealer are not finger pointing, but both assuming charge to find an fix the issue.
I can't wait to get the new twinkie home...she is a real beauty.....words nor pictures will do it justice. I feel this is a small problem to overcome.
Here are two pictures of what was found.
BTW, Don the tour guide said it looked as if they left the door open when they washed it. I think that is most likely the case or something like it. At any rate the dealer did not feel comfortable with me taking the unit and I am glad that this happend now rather than when I got it home.
Until we have more info, there is really nothing I can say except that I am extremely please with how this is being dealt with by the dealer and the folks at Jackson Center who by themselves got involoved in this and I am extremely pleased with how the interior looks and works (which was one of my issues with my '03). I think if I don't wreck it, they may burry me in it someday!
Eric
Old 12-16-2003, 08:23 AM   #233
Aluminut
2004 25' Safari
. , Illinois
Here is a pic of the dinette seat closer to the back.....
Old 12-16-2003, 08:24 AM   #234
Aluminut
2004 25' Safari
. , Illinois
...and of the one closer to the front....
Old 12-16-2003, 08:35 AM   #235
jcanavera's Avatar
Fenton , Missouri
Images: 143
Wow, from the pictures obviously water was on the floor and wicked up into the fabric. My bets are on the airconditioner and possibly water not draining through the provided drain. I'm guessing snow or ice in the drain cause it to come in right through the throat of the A/C unit, hit the floor and gravity angle migrated it to the dinette. Especially if you see no water trail or find wetness higher up.
I can't see this trailer getting through the water test with the A/C unit mounted and then something like this happening. Its probably a freak thing. The good side to this is its up in factory land and they can replace the fabric.
Thanks for the factory pictures! I'm sure you will get some answers to this pretty quick. I'm sure your dealer will not want to hold this on his books too long. Kudos to Brandi for keeping you sane in the process....you know how us guys are with our trailers!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-16-2003, 08:51 AM   #236
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
Eric .. I think you may be right about the water coming in through the AC.
I'm impressed with the way your dealer and the factory are handling the situation. Also, it sounds like the factory is taking the QC situation seriously. Those are all positives in a negative situation.
I'm sure everything will work out to your satisfaction and you will have many many years of enjoyment.
Porky
TrailerGypsies.com
-- Willie Dixon
Old 12-16-2003, 08:56 AM   #237
ctdair's Avatar
Oh my , Sorry to see that , I will go make a check of my snow covered trailer . If it was snow ice backing things up I dont want the same thing. Rest assured Airstream will make it right , I have delt with The dealer You purchased from , on My Safari And they will back You up. Of course I think You should request complete new dinnete not just cleaned and dried.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 12-16-2003, 09:01 AM   #238
Aluminut
2004 25' Safari
. , Illinois
I agree with you both. Impressed all around. I just can't see the shell leaking, the shell has been and still is IMHO the best built part of the trailer. They even seal the inside seams as well, so it has to be a window, door or vent left open or the A/C unit. Worst case, a water line, but if you really think about it, the unit was winterized and the liquid would not be frozen and would have had a different texture than water.
Pork, I may have been inside your trailer. I didn't recall who the dealer was that you went through, but Don had said to me if I knew or had the VIN and it was on the line, I could have taken you some snapshots of your unit. Heck if it was on the line, I might ahve anyway! Was yours a Classic Limited?
It was pretty bad with loosing sleep just before going to get it, but now that I've been in it, I'm just beside myself in anticipation of it arriving here in the drive! It is one well constructed coach and the inside, it is truely the Rolls Royce of interiors. I loved my Bambi and it was hard to see it go as we drove off, but this new Safari is just plain comfortable and has lots of space for stuff!
Eric
Quality of new AS: 2004 22' SAFARI lee 2004 Safari 7 01-02-2005 07:13 AM
Looking for NOS replacement Shower curtian track and curtian riders TiredIron General Interior Topics 8 03-14-2004 09:43 AM
idle ?s about quality of space, life suspiria_2 Full-Timing 21 10-22-2003 06:53 PM
59 vs 67 interior quality JimC General Interior Topics 2 05-19-2003 07:26 PM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 08:04 PM
