Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 10-21-2003, 01:35 PM   #1
rcaldwel
Profile:  1994 30' Excella
New Smyrna Beach , Florida
front couch comfort
we're considering a safari 25' and wanted to know if anyone has any first hand experience sleeping on the front couch. Is it comfortable enough that guests could get a decent nights sleep. Big enough etc.
your replys would be very much appreciated.
thank you,
Bob Caldwell
rcaldwel is offline   Reply With Quote
Old 10-21-2003, 01:39 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Bob,
we slept on teh front pullout in our tradewind on hot nights, because it's cooler up there. It seems to me there is more room up front than in our rear pullout.
We have a 25ft. tradewind. Might be different in a new trailer.
Uwe
Old 10-21-2003, 01:44 PM   #3
JodynJeep
JodynJeep's Avatar
Profile:
Images: 57
It is comfortable enough for the avergage person. I have never pulled mine out - but just slept on it in couch mode and it was fairly comfortable - enough room for someone 5'11 to stretch out on.
Jody - Jody's Website
JodynJeep is offline   Reply With Quote
Old 10-21-2003, 01:54 PM   #4
gwsullivan
gwsullivan's Avatar
Profile:
My brother and his wife spent one night on my couch and said it was okay. They are relatively small peolple. The couch is long but quite narrow.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 11-03-2003, 06:22 AM   #5
ctdair
ctdair's Avatar
Profile:
Had 25 Safari 6 sleeper and son and later 2guests complained about the hole? that is between the seat and rear cushion when folded. Upgraded to classic with the leather look couch and it has a flap of material spanning this gap , have had 2 different guest couples and no complaints. If leather look couch is option in safari I would definetly se if it has this flap. Overall I am way happier with the leather look than the standard cloth
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2002 Dodge Diesel 4x4 Dually
ctdair is offline   Reply With Quote
Old 11-03-2003, 07:34 AM   #6
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
We're ok with ours
Have a 1967 Tradewind with two beds on either side of the hall and the front guacho is where my wife and I sleep. Theres a big thick cushion that fills the gap between the couch backrest and goes under the little ledge under the window. This then lays down flat when the bed is pulled out. We noticed that when the bed is pulled out there was no a piece of plywood that covered the part of the bed closest to the front window so I cut another piece that I slide over the slideout rails when the bed is extended. When the bed is pushed back in this plywood rides on top of the other piece that is permanently attached. It only raised the cushion height by 1/4". It is still an adjustment going from our king size bed at home to this bed and the dog is the first to get kicked out. Sometimes I'm second.
Tin Hut is offline   Reply With Quote
Old 11-03-2003, 06:06 PM   #7
docbluedevil
docbluedevil's Avatar
Profile:
We have a Safari 28 W with a L-sofa front couch (80"). I believe the length is longer than the sofa option (74") when converted into a bed. A pillow-top (even the cheap foam types) will make any configuration of sofa (and bed) into a more comfortable experience, but the L-sofa gives you several more inches. The sofa though is probably more comfortable to sit on than the firm foam cushions of the L-sofa. Depends on what you prefer more. A more comfortable sofa or a more comfortable bed.
Abe
Airstream: 2004 Safari 28W
2005 Chevy Suburban 2500 8.1L
docbluedevil is offline   Reply With Quote
Old 11-04-2003, 11:15 AM   #8
mcostanzo
mcostanzo's Avatar
Profile:
Six Sleeper Sleeping . . .
Our oldest daughter uses the couch as her bed and she finds it very comfortable. We use an open sleeping bag under the sheets as a pad to soften it up a bit. I've napped there and it is plenty long enough for one adult (I'm 6').
Our younger daughter uses the dinette bed and is quite happy with that space. It is also long enough for a 6-footer. The seat and backrest pads are pretty firm, so we soften this one up with a thick sleeping bag used as mattress pad, too.
My wife and I struggled for a bit with making our bed comfortable. We started with one of those mattress toppers, then added an inch layer of that small egg-crate-style foam from Macy's under that. Eventually we went to a foam store and bought a 4" layer of that special foam that adapts to your body shape, which we put under the other stuff. ALL OF THIS is sitting on top of the factory mattress and we are now very comfortable in our bed. Some long-sided fitted sheets control all of the various layers. It is real soft but also surprisingly supportive.
Mike
mcostanzo is offline   Reply With Quote
The WORST Couch EVER!! HELP! Tin Can Crabs Upholstery, Blinds, Walls & Interior Finishes 29 03-04-2004 02:07 PM
Rearrage couch from side to front jlovelady General Interior Topics 0 09-14-2003 07:16 PM
replacing front couch with futon gatorsharon General Interior Topics 15 08-02-2003 12:02 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 03:58 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
