Old 07-02-2018, 10:08 PM   #1
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
Entry Door - Don't slam it!
https://www.airforums.com
cbburke is offline   Reply With Quote
Old 07-02-2018, 11:34 PM   #2
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
entry door part 2, don't slam it.
Sorry for the first entry. Here is the real post.
When we traded our 2014 Classic for our new 2018 Classic we acquired a new problem. The entry door will not close properly. The dealer's answer was to "slam it" Not true. The door is/was not adjusted properly. Specifically the frame bolt it mounted to high so it hits the door latch wrong. The result is it was necessary to slam it to close it.
At this years International ever coach in the dealers display along with every coach on my dealers lot had the same problem. The bolt is mounted to high.
There is a You Tube video that describes how to adjust the entry door.
Or you can print this 14 page instruction from Airstream on how to adjust the door. Attached.
Charlie
File Type: pdf Main Door Adjustment-ilovepdf-compressed.pdf (3.54 MB, 56 views)
Old 07-03-2018, 04:36 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
On a new AS...
...If it couldn't be installed properly the door should have been 'bent' with a piece of wood at the factory or on the dealer PDI? 😳
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 07-15-2018, 01:51 PM   #4
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
I spent 13 years at an Airstream dealer adjusting doors. The current door problems go beyond a piece of wood.
Old 07-15-2018, 01:57 PM   #5
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
A true skill!
It took some figuring out to align a screen door that was off a bit. Equal, yet Opposite Expectations, describe it at best.
13 years. You have the patience of a hungry mountain lion.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 02-20-2019, 12:56 PM   #6
Dick tracy's Avatar
camas , Washington
Perfect
Now I can impress my wife even more than I already do
and just in time, going to visit our AS tomorrow
Dick tracy is offline   Reply With Quote
Old 02-20-2019, 02:29 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Even when properly adjusted ... a visit from someone (or a gorilla) who doesn't realize that the doors are aluminum ... you may have to realign several times. But it is worth it when you get it "just right".
We have eventually had to "adjust" every AS door that we have owned ... the real trick is to get the screen door properly adjusted with the main door ... so, either get "in" with your dealer / service department or learn to adjust yourself with a great deal of patience. Two of our dealers did not adjust the doors to our satisfaction or did not know how.
2015 25' Eddie Bauer International Sp Ed
2017 GMC Yukon SLT; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 02-20-2019, 03:52 PM   #8
Mollysdad's Avatar
If my AS is sitting perfectly level, such as a parking lot or the floor of my storage unit, it closes with a satisfying, "chunk".
However, if the campsite is even a tiny bit out of level, maybe an inch, the door won't close fully, it closes but won't lock.
That's when a firm pull is required.
I'm thinking the chassis is getting torqued slightly and causing the door to misalign, but I don't want to screw up the perfect fit when level.
Mollysdad is online now   Reply With Quote
Have to Slam the Door on a New AS? ltorgy Windows, Doors, Locks & Vents 53 04-26-2017 08:09 PM
Why do I have to slam the heck out of my door?? MOS General Repair Forum 32 03-10-2016 11:15 AM
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
