Old 04-25-2014, 07:15 AM   #15
Images: 59
There isn't a difference between a residential range and RV service, unless the yard plug is an obsolete, no longer code compliant, three wire system where the ground and neutral are combined.
I haven't seen one of these systems in a long time. If that's what the OP has, it should be replaced with a compliant 4 wire receptacle.
It wouldn't work with the recommended 4 wire 50a/30a adapters anyway.
Old 04-25-2014, 07:25 AM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I guess I did not articulate that point effectively!
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Sovereign electrical update / question krowsea Electrical - Systems, Generators, Batteries & Solar 4 09-06-2004 08:27 PM
Electrical Question Alex Electrical - Systems, Generators, Batteries & Solar 5 01-10-2004 10:12 PM
Newbie with an electrical question Whistling_Gypsy Electrical - Systems, Generators, Batteries & Solar 3 12-28-2003 06:24 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
