07-14-2015, 09:26 PM
#521
2015 25' Flying Cloud
Bend
, Oregon
Great write up. My only comment would be a 25ft with 11k, versus 27ft with 15k is not comparing apples to apples.
I don't care which is better, but for the forum...
I have a 25ft with ducted, I think that is a 15k unit on the top, I promise to check! If anyone in Portland has, say a 2014 25ft, rear bed with the same type of unit on the roof, then we could get together and repeat the test. I have a 3100w generator we can use for the rest.
If anyone is interested to set this up send me a message
07-14-2015, 10:37 PM
#522
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro
, North Carolina
In Farmington, pulling in after about 300 miles in 90+ degree heat, the inside temp dropped from 89 down to 78 in less than 30 minutes with the two AC units on my Serenity 30RB. My older 2009 27 FB, single unit could not have gotten the temp below 80 in the sun.
My conclusion, ducted air is much more efficient, primarily due to the thicker roof insulation, less heat loss through ceiling.
Of course two always cools faster than one, but on the generator, one unit pulls it down quickly as well on my new Serenity.
Just my opinion, but I suspect there is a problem with the previous post, would suggest checking outlet temp when AC is running to be certain it is indeed working.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
07-15-2015, 05:59 AM
#523
2004 30' Classic Slideout
Fenton
, Missouri
Ducted Air
That test pretty much concours with my dealer's assessment who said that the ducted air unit tends to cool down a heated trailer more slowly due the distribution of the air throughout the trailer. Those with the non ducted units have the blast effect where the air output is more localized thus cooling the central area of the trailer first and then spreading outward.
My SOB had ducted air and exhibited the same tendencies.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-15-2015, 07:26 AM
#524
2006 25' Safari
St. Augustine
It would be best to have the same unit and same sized trailer but I do not believe it is going to make that much difference. The BTU rating is not really a sound level rating and the larger trailer would need the extra BTUs to cool anyway, especially with the additional window area.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
07-15-2015, 08:39 AM
#525
2006 25' Safari
St. Augustine
BTW, we checked to make sure all ducts were open and checked after about 10 minutes that, in fact, cooler air was blowing out of the ducts. I did not post to attack ducted units or owners of such. I have been intrigued with the possibility of ducted quiet air; however, a comparison is/was in order perhaps if for no one else but me as I kept wondering. I still like the quieter level of sound and now I know how much quieter. As far as GSMblue's comment that they are not the same unit, etc that is true but as far as I am concerned it is what I have and most likely the same unit is no longer used that I have anyway- like many others who traded up from one unit to another but also making comparisons to what they knew to the new AS. Naturally one study is just that, one study but it supports the fact that ducted air is quieter, at least on the ends where people reside most by 6-7dB but in the center area it was as noisy per se - no big surprise and no wounding of product claim. Low fan speed is better for both and closer in levels comparatively but I have found that not too often in high humidity could I run my AC for long on low without a freeze up.
07-15-2015, 08:56 AM
#526
Bend
, Oregon
rodsterinfl - really appreciate the efforts you went to for the greater good!
FYI: I do think in 94F heat my AS takes too long to cool down... While in central OR last week, it struggled to get us down to 72F and was running a lot...
07-15-2015, 09:43 AM
#527
2008 25' Classic
Full Time
So the ducted versions don't have a panel under the AC to divert all the cold air straight down into the trailer. All of the air goes into the duct work?
Kelvin
07-15-2015, 10:02 AM
#528
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Previous actual test ... nearly a year ago ...
Originally Posted by rodsterinfl
Ducted versus Non-Ducted: An actual test- Yesiree.
After months of waiting, I have the data to compare the difference between the standard non ducted (my AS) to a ducted unit.
What?
*** From my actual test data post mid way (pg 11-14) in this thread (and others) on 8 - 11- 2014 *** search is your friend
comparing the same model, same length, and same location .... only the A/C was different: ducted vs. non-ducted.
... relevant post ... written first person as someone who has lived with the new 2015 AIRSTREAM ducted air for a month ... not speculation or he said, she said ...
There is no need to cycle the fan in 90+ weather to cut noise; see the numbers below. It is really quiet! We leave it on high for most of the cooling time (thermostat set to 72); however, if you might want the fan to cycle on and off with the compressor - set it to auto (either the fan or the A/C). There is no switching between ducted and any other alternative for A/C or bypass ... ducted is the only option we have with a single A/C unit for the heat pump. The furnace is still the familiar unit behind the axles at floor level with flex hose to various outlets near the floor. But talk about a nice even temperature from one end to the other with the ducted air! WOW !
Ducted Air Conditioning; Sound Level Numbers
Originally Posted by mefly2
Of course these sound level readings for this central air 2013 will be relative...but from a SmartTools sound meter app on my phone, I measure: 63 db at 6' while seated at the cushion juncture of the dinette; all a/c vents are open and fan on high. Directly under the main a/c vent and in front of stove: 84-85 db. Sitting on the bed: 65 db. So, as would be expected, the sound level drops inversely by the square of the distance (if you could hear that accurately).
Note that reducing the fan speed lowers the 6' reading to 59db; significant but not quiet nor sufficient flow to keep us cool (75) when the outside temps climb in bright sunshine.
For comparison ... Normal conversation at 3'= 60-65dB
City Traffic (inside car) = 85dB
As promised ... we finally took a break from enjoying / playing in our EB w/ ducted air to get the following ducted air conditioning sound level background readings;
* fan on high, compressor running *
Seated at the cushion juncture: 54-55 db; down from 63 db / 59 with fan on low; reduction of 8-9 db.
In front of stove directly under inlet for ducted air: 60 db; down from 84-85 db; reduction of 24-25 db !!!
Sitting on the front bed: 54-55 db; down from 65 db; reduction of 10-11 db.
Even by this unscientific means, those difference numbers are significant and dramatic for sound reduction.
The ducted air is also very effective in cooling (and heating) both ends of the trailer (and even the Head).
It is really now quite amazing that we can be sitting in cool comfort and listen to Pandora or a movie at the same time as the AC is on with the fan on high. I can now talk to my wife when she is in the galley area under the ducted air intakes and not even need to raise my voice to communicate. It eliminates the stress of the loud A/C background noise when inside the AS trying to do much of anything other than sleep... we spent much of last weekend just sitting inside of the Eddie Bauer listening to the quiet while the outside temps were above 90 F. Do we like the ducted air and is it worth the depreciation on our trade in ??? YES !!! Emphatically; however, YMMV
07-15-2015, 10:23 AM
#529
Small Town
Agreed; see my post above. Otherwise, too many variables are introduced for objective comparison. Subjectively, we know that ducted is quieter and more efficient at cooling as well as warming (via heat pump).
07-15-2015, 10:42 AM
#530
2006 25' Safari
St. Augustine
Yes, see your repost and found it at #184. I missed it somehow. I was working for so long trying to find a ducted model (took nearly three months) that I did not return to read all the posts posted since.
Your figure under the older unit intake is high but the equivalent to a whisper (26db) Was the unit blowing down on the instrument? The main thing is that it is quieter but we are beginning to measure that difference. Some have said it was completely silent, others no different. We would probably find some differences between padded and non-padded ceilings as well as there is a bit of vibration involved. I agree with you except for the efficiency part as it is indirect airflow distributed/divided that has to equalize first as I experienced yesterday. I had the heat pump and removed it for the new air distribution unit. The nice thing though is that there is no adjustment of airflow or very little needed as opposed to a non-ducted unit (I have to close the vent directed at the front to equalize the rear temperature).
07-15-2015, 10:55 AM
#531
Small Town
Rodster-
Some have had luck with the new adjustable individual opening / vent covers to control and equalize the flow. We have not yet found the need for the spendy little buggars.
And, yes, the ducted models are now the "hot" item on the dealers lots ...hard to find in some cases. There is a new found demand for the 2015+ models with ducted.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Ducted Air
Bassrats2 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
5 |
04-27-2014 05:52 PM |
Non ducted VS Ducted
ianburnett |
3 |
12-01-2012 11:24 AM |
Ducted or Non-Ducted A/C
tesstoaster |
2 |
06-22-2012 01:43 PM |
Ducted AC
chetos |
19 |
12-13-2011 09:29 PM |
Cool air ducted from below trailer
truckasaurus |
Roof Vents, Skylights & Fans |
8 |
03-05-2009 09:35 AM |
