Old 12-05-2012, 06:44 PM   #1303
David Logue's Avatar
allen , Texas
I've got the 08' safari se 25'. It has the filiform corrision on the tail light.
Been to the ocean once, washed the AS when we left. But is was showing up
Before that. Im in north Texas. Can the taillight assy. Be removed, ground down and re-apply some sort of clear coat? It is bad when you pay this much
And get this sort of product.
http://www.argentumsolutions.com/wik...form_Corrosion
David Logue is offline   Reply With Quote
Old 12-06-2012, 05:59 AM   #1304
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Filiform Corrosion - JAMWiki
David,
I believe you'll find that you have to remove interior panels to get the Tlight assemblies off, others have done the repair with them on.
I did the battery surrounds with them still installed.
Old 12-06-2012, 06:34 AM   #1305
Luckyducks's Avatar
2018 27' Flying Cloud
Panama City Beach , Florida
David, if your taillights are like mine (on a 2010 Flying Cloud), they can be removed easily from the outside by just removing the 4 screws holding them on. After stripping the old clearcoat off, you would polish the cast housings, and then either reclearcoat before reinstallation or leave uncoated with frequent sealants or wax applied. A local body shop said he would spray clear on them for $50. I seriously thinking of not reapplying clearcoat. Russ
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
Luckyducks is offline   Reply With Quote
Old 12-06-2012, 06:41 AM   #1306
Luckyducks's Avatar
David, here's an official Airstream document that may help. It's a little old, 2006, but still applies. Your tail light housings should be easily removed. Russ
File Type: pdf Polishing repairing_corrosion_on_cast_aluminum.pdf (117.6 KB, 137 views)
Russ and Linda
Old 12-07-2012, 08:37 AM   #1307
allen , Texas
Thanks for all the good input, I will be using it.
Old 12-26-2012, 05:36 PM   #1308
DGQ
2013 19' International
Corvallis , Oregon
Has anyone purchased the dealer option of Xzillon?
Two new guy questions:
1. Ordered and finally picked up my 19 ft International CCD! I am considering the dealer option to seal with the aircraft sealant. Xzillon, I believe is the product. Apparently there is a five year guarantee against corrosion and "fill", and if does happen I assume the dealer provides the fix. Cost for my 19 foot is 950. Has anyone purchased this option from a dealer?
2. Brought the trailer home and as I live in Oregon it was raining for a few days. After about day 5 I noticed a small drip from the front center window. (See attachment) It appears the leak is at the top seal of the center window rock guard. Is this an easy fix or is this a trip to JC? My dealer (Sutton RV) has been very thorough and accommodating but they are still working the issue after 8 days in the shop. Should I have concerns regarding the water tight integrity of the trailer? Thanks!
DGQ is offline   Reply With Quote
Old 12-26-2012, 05:57 PM   #1309
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Read the warranty carefully as I believe it will say if the product fails they will reapply it for free.They will not fix any filform damage just reapply their product.
A application of a good grade of wax along with corrosive preventive regiment might be a better choice.
Old 12-26-2012, 06:35 PM   #1310
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
DGQ, this sounds like the stuff they used to sell as an undercoat on new cars years ago until everyone figured out it was a scam. Sometimes it was just ordinary wax. Check it out thoroughly on the internet to see what it is.
Lots of bad reviews on Amazon ( Amazon.com: Customer Reviews: Xzilon ) although there are some good ones. Seems like it is cheap to buy and the dealers make is big profit. Modern waxes with polymers will protect the trailer for quite a while (we do it once a year. Check out Griots online for Paint Sealant.
Gene
Old 12-26-2012, 07:21 PM   #1311
Thumbs down Nope....
"1. Ordered and finally picked up my 19 ft International CCD! I am considering the dealer option to seal with the aircraft sealant. Xzillon, I believe is the product. Apparently there is a five year guarantee against corrosion and "fill", and if does happen I assume the dealer provides the fix. Cost for my 19 foot is 950."
IMHO....Don't waste your money....Any quality sealer will do an equally good job. $50/ft is a little steep for wipe on wipe off.
From what I've read, it looks very much like a product we gave up on at the Chevy store I retired from....too many customer problems.
I use this every Spring. Easy to use and it gives you a chance to inspect things as you go.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-26-2012, 10:16 PM   #1312
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Unlikely to prevent corrosion. Spend less money on a annual paint sealer as mentioned by Bob. Then treat all the cut edges, rivets, and exterior fittings and wheels with CorrosionX quarterly, just dab or spray it on and wipe it off good. As soon as you can, spray all the exposed steel (frame, axles, tank straps, stabilizers) under the Airstream with Boeshield T9 which will leave a thin protective coating of paraffin wax on them.
The leak should be easy to fix but it can be tricky to find the source. Leaks can happen inside the shell layers and drain down between the vinyl flooring and plywood subfloor. The first indication of this is often a soft spot (rotten wood) in the floor. The only defense is one of these, used quarterly. I found a leaky door hinge on my our trailer with it, no other indication. Probe through the vinyl at the floor edge under doors and windows.
Sonin 50211 Rapitest 10% to 28% Pinless Analog Wood, Concrete, Plaster, Carpet, and More Moisture Meter - Amazon.com
doug k
Old 12-27-2012, 06:17 AM   #1313
West Hill , ON
This thread is about corrosion, but regarding your leak, we had some leaks at both front & back windows on our 08 19' SE. They were very hard to find and we exhausted 2 dealers before finding them ourselves. Look for incorrectly sealed rivets in the window drip rails, even small imperfections in rivet seating or poorly applied sealant. We had to remove factory applied sealant and re-fill "extra" rivet holes and recover some others, but this worked for us.
grabob is offline   Reply With Quote
Old 12-27-2012, 10:25 AM   #1314
dkottum's Avatar
David, the filiform corrosion problem isn't so much about the aluminum, it's about the clear finish they put over it and the method used. Airstream had to quit spraying clear coat on their trailers some years ago because they no longer had the safe facilities to do it.
The panels are prefinished at the Alcoa factory, then Airstream cuts and drills them for fitting and riveting together. It is at these cut and drilled edges where the filiform begins, then travels inward.
Moisture and salt are the elements causing it, Arizona trailers have almost none, coastal trailers plenty. Remove one of these and little will happen. That's why Products like CorrosionX and Boeshield T9 are effective; they create a barrier, but is must be renewed as it wears off. That's really not a home remedy but a maintenance practice that is effective. If the filiform is widespread, it must be removed and new clear finish put on.
It is unfortunate Airstream and its dealers do not provide recommendations for regional care of these trailers. Or perhaps find a way to finish those cut and drilled edges before assembly, but I suppose that becomes a facility problem. I see they do sell CorrosionX and Boeshield T9 in their store, as well as a number of finish sealants. I've got a pretty good supply and use them regularly. I think this works up to some point depending on where your trailer is located.
There are members here such as Robert Cross who have been successful removing filiform and documents their methods nicely. They are examples of how you can keep your Airstream nice as new in spite of this persistent problem.
I'm from the rust belt where fenders are expected to rust off the car, and I've lived on the coast where my aluminum widow screens and frames turned to powder. This is another case of us foolishly putting metal into these environments, Nature at work, and our frustrations trying to beat it. I just don't think lawyers are a solution to all our problems.
doug k
Old 12-27-2012, 10:50 AM   #1315
Nevada City , California
Wurth paint
I would try the rattle cans of Wurth clear coat. I've used it over their paint on alloy wheels on some old cars. Does a good job and small packages.
Jackfre is offline   Reply With Quote
Old 12-27-2012, 11:22 AM   #1316
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
ive been interested in this thread as we are pondering an AS purchase in the beginning of 2014....
you all have put alot into this thread and provided a great deal of info...I feel IF we go the AS route, we will at least be more prepared to monitor for and stymie any corrosion....
We live 4 hours north of the gulf of mexico in Birmingham, AL....but we will take at least on week long trip to the beach per year, but likely more than that including short weekend trips...so assuming I would end up going the AS route, I want to be that much more careful about this.
I have a year to think about it.....
Has anyone within this thread compiled a lengthy all inclusive list of possible to do's and do nots to do the best we new comers and anyone can to prevent, mitigate, or cure these problems? I have gleaned alot from the thread, but perhaps a summary of the high points would help?
Like at this point is there a checklist that AS should/would give to new owners to do the best we can to prevent this and or mitigate? What would this checklist say?
Thanks!
PharmGeek is offline   Reply With Quote
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 07:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 10:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 01:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 08:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 01:06 AM
