Old 04-05-2012, 07:40 PM   #1163
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Greetings. I posted earlier that I was starting the process of dealing with massive corrosion at the belt line. Now, I have "brass wheeled" one side and it looks better. I need to ask for types of sealers that might be recommended. Many have used the stainless paint on small areas and it looks great. I ordered it and plan to use it on open areas like others. The belt line is a larger area. What might be recommended for that? Local business people recommended Krylon Fusion for plastic as it would bond to both metal and the clear coating edge. The retired service guy who maintained planes said to use a self etching coating epoxy (clear). I am not sure if I should use clear or aluminum color. Most of the area will be covered up by the belt line extrusion that I ordered from AS but some may show. Ideas? Nail Polish just sounds so temporary to me. I plan to coat it trim it and then seal the top with arcyl-r.
Old 04-06-2012, 06:08 AM   #1164
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Rod,
Iv'e tried brush-on automotive clear, Thomas' water based clear,(came with the stainless paint) and a quality nail polish. Believe it or not the nail polish has lasted very well, 4+yrs on some spots, damn hard stuff. More difficult to blend but does last.
When used sparingly the stainless paint & clear worked well around my entry door handle bezel, you might try that first on the belt line corrosion. It's water based and easy to work with, can be wiped clean to get rid of the opp's. This pic is three years after application.
POI....use small artist's brushes to avoid dropping hairs in the paint.
Name:	LIQUID STAINLESS STEEL 353.jpg
ID:	155123   Click image for larger version
Name:	Stainless Paint, Filiform 003.jpg
OOP's
Old 04-06-2012, 06:36 AM   #1165
cms4140's Avatar
Birmingham , Alabama
How about this?
A "maintenance" item per the AS online store - High quality clear coat in a convenient pen applicator.
https://store.airstream.com/product_...roducts_id=428
-Chris
cms4140 is offline   Reply With Quote
Old 04-06-2012, 07:08 AM   #1166
I believe that was discovered to be a Ford clear.
OOP's
Old 04-06-2012, 07:42 AM   #1167
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I keep the Airstream store clear touch-up handy. Easy and convenient, puts on a decent thin layer.
doug k
Old 04-06-2012, 08:50 AM   #1168
2006 25' Safari
Here's a pic
Ok, this is my first pic of what I have to work on. The end caps are the worst of it. This is a before shot at the dealer in February:
Old 04-06-2012, 10:35 AM   #1169
Rod,
Wow...I can see why your using the brass wheel brush.
I believe the belt moulding will cover most of it though.
Make sure the corrosion is sealed well before installing.
Double stick tape on the back, correct?
Consider using blue painters tape as a guide along the rivet line and to hold it, easier to make sure it's level and get an idea just how much of the corrosion might be visible after install.
Clean the panel's real well with mineral spirits before & seal the edge of the moulding with acryl-r after install.
Good Luck...keep the pic's coming.
OOP's
Old 04-06-2012, 11:34 AM   #1170
2006 25' Safari
Will do on the picks and the acryl-r. I have been working like a banshee. This week I got the HDMI cables fished through and hooked up my new electronics. Nice. Ran both TVs with blue-ray just 'cause I could and wired the backup camera through the trailer again but this time it is working better. I will finalize that job, replace the 7-pin connector, paint the propane tanks, replace the microwave with one that fits then get on the corrosion. I have the belt-line, certain areas like the stove vent and the wheels to do on that job. Once that gets done it will be looking good- can't wait!
Old 04-08-2012, 06:00 AM   #1171
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Originally Posted by Rbphoto
I got approval from Randy McNeeley Airstream Customer Support Team and C&G Trailers in Los Angeles removed,treated with corrosionX and installed new running lights.
RB,
Thanks for the reply. When you say they "removed" do you mean they sanded the affected spots or they removed and replaced the entire aluminum panel(s)? I'd like to know before I make my call to customer service. Also, how receptive were they to rectifying your issue?
We just pulled our trailer from storage and there is corrosion at every running light and other areas. The airstream is not even a year old yet!
Don
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 04-09-2012, 06:34 AM   #1172
Don
Don,
If you haven't already...
I would advise starting a phone and paper trail to JC, expressing your concerns.
There IS a chance you will get a positive result, despite the warranty disclaimer.
OOP's
Old 04-09-2012, 08:50 AM   #1173
Rbphoto's Avatar
La Quinta , California
Images: 21
Originally Posted by DMT View Post
RB,
Don
They removed running lights, spot treated the areas with corrosionX and replaced the running lights. They were not very receptive to doing this and I think because it was only 6 months old they relented.
Rbphoto is offline   Reply With Quote
Old 04-09-2012, 09:32 AM   #1174
dkottum's Avatar
We would like to know how these newer LED running (clearance, teardrop, whatever)lights are removed. One has said they snap on, another they must be broken to get off.
Anyone know ?
doug k
Old 04-09-2012, 10:14 AM   #1175
DMT
DMT's Avatar
Don
Don,
I intend to next week. And I will not take no for an answer either. Stay tuned....
Don
Old 04-10-2012, 07:45 AM   #1176
Rbphoto's Avatar
Images: 21
Angry
Anyone know ?
doug k
They have to be broken off.
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
