Old 03-28-2012, 05:46 AM   #1121
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Good luck Rod, persistance pay's.
Regular inspections and maintenance is the best way to stay on top of it.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
"Tahawus"
Old 03-28-2012, 06:54 AM   #1122
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by ROBERT CROSS View Post
No solution....
What I do...
Remove the filiform.
Seal the areas with brush on clear, larger spots I have used Thomas' Stainless paint.
The areas I've addressed, have not gotten worse. But you must inspect regularly for new outbreaks.
Wash and seal regularly.
Ck out some of my posts for more details.
Acryl-r is a self leveling sealant used on narrow seam gaps.
CorrosionX is a filiform treatment, (I no longer use), have had better luck with WD-40.
Other's have different method's...I just do what works for me.
It's all here on this and the other corrosion threads.
Bob,
Just curious - I assue that the WD-40 and clear coat are separate and different approaches to dealing with the problem?
What I mean is that I am guessing you cannot put clear coat over WD-40?
I just sanded and painted my door hinges and battery box door frames with Thomas's Stainless paint. I guess it is cheating a bit but I didn't want to invest all the time to try sanding and polishing.
The corrosion was pretty bad on these parts on our trailer - possibly due to the salt used on the roads? I'm not sure if it is the same sort of corrosion as the filiform that appears on the skin - just seemed to be large blistering areas of white corrosion.
I'm fairly happy with the job that the stainless paint did, we'll see how it holds up - sure looks a lot better than it did before anyway! Also easy for me to touch up if I need to.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-28-2012, 07:11 AM   #1123
"Just curious - I assue that the WD-40 and clear coat are separate and different approaches to dealing with the problem?"
Brian,
You assume right.
Iv'e started using a dental scaling tool to remove the filiform completely, much more precise, then cleaning thoroughly with mineral spirits and cover with clear.
I use the 40 to wipe down the affected seams periodically, also great for cleaning the stainless segment protectors.
How did the Stainless paint turn out for you? Pic's?
I also considered using it on the hinges and battery surrounds but ended up brush painting the hinges and polishing the battery surrounds.
RLC
John Prine
"Tahawus"
Old 03-28-2012, 08:22 AM   #1124
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Bob, CorrosionX has worked well for me stopping small lines of filiform because it penetrated the filiform and prevented expansion.
You have had better luck with WD40. How has WD40 worked better than CorrosionX? (WD40 is a lot cheaper but has a lot more solvent as I understand it.) I can see where the CorrosionX penetrates filiform lines because they change color from a bright white to a gray color.
Our new trailer doesn't have any yet but no doubt it will. As a preventative measure I treated all edges and rivets with CorrosionX and continue from time to time. My experience was with our last one.
doug k
Old 03-28-2012, 10:27 AM   #1125
Thumbs up
Doug,
I just felt the X was suspect as far as stopping the corrosion, also as you noted the color change was a little drastic for me.
I use the 40 to soften the filiform before removal with the dental scaler, then clean well with mineral spirits before covering with clear or water based Thomas' stainless paint.
Here is an example of the stainless paint around the entry door handle which was done three years ago.
The after pic's were taken last Fall. I'm pleased/happy how well it's held up.
After washing I usually wipe down any suspect seams/areas with the 40, mostly to displace any water that may seep into the seam. It hasn't affected the sealer I've been using on the panels in lieu of wax.
I do plan to test a carnuba wax this Season to see if it's an improvement over the sealant.
Name:	LIQUID STAINLESS STEEL 351.jpg
ID:	154538   Click image for larger version
Name:	LIQUID STAINLESS STEEL 353.jpg
RLC
John Prine
"Tahawus"
Old 03-28-2012, 10:59 AM   #1126
cms4140's Avatar
Birmingham , Alabama
Doug,
I recognized that picture.... I would point out that the metal is already discolored to a dark gray/black once you get underneath the white junk. The X just seems to make that discoloration more pronounced upon application. I have doctored that spot and others a little more with the X and think it has stopped the growth. However, I think I will try layering a bit of T-9 on this one just to see what happens. At this point...it's all experiemental for me.
Chris
cms4140 is offline   Reply With Quote
Old 03-28-2012, 11:18 AM   #1127
Chris,
It's too bad, thats what we're all doing......experimenting.
Keep us posted.
RLC
John Prine
"Tahawus"
Old 03-29-2012, 06:12 AM   #1128
Charlotte , North Carolina
Been reading this post with interest...'cause I thought AS trailers were damn near indestructible...more or less 'the Rolex of trailers'
Okay corrison problems aside...if you had your choice of any trailer/RV on the market, would you still choose an Airstream?
mack-in-nc is offline   Reply With Quote
Old 03-29-2012, 06:20 AM   #1129
ABSOLUTELY....don't let the post's here dissuade you.
Sure it's a PITA but so's a boil and even that heals eventually.
RLC
John Prine
"Tahawus"
Old 03-29-2012, 06:50 AM   #1130
So this like more of a 'cosmetic' issue? This corrosion is not "Airstream Cancer?"
Old 03-29-2012, 06:51 AM   #1131
Wingeezer's Avatar
2005 30' Classic
Bob,
I can never remember how to attach pics, but I will try!
I was reasonably happy with the way the stainless paint worked, about teh only problem I had was that I ripped off the masking tape too soon ( I did this work while we were traveling in Florida!) and it lifted a bit of the SS paint which was still soft so I had to touch it up where that happened.
I will re-do it at some point, in the meanwhile, I think it looks a lot more presentable than it did before. Hinges came out about the same.
I think the corrosion we had in these areas was worse than most I have seen looking at other AS trailers during our travels.
Brian (Currently in Asheville NC on our way home!)
Name:	Batt frame before.jpg
Name:	Batt frame after.jpg
2005 Classic 30'
Old 03-29-2012, 07:39 AM   #1132
Gainesville , Florida
Yes it is cosmetic. jim
Old 03-29-2012, 11:36 AM   #1133
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Never think they are indestructible
Our old 68 doesn't have any of the corrosion problems of late but she sure does have a lot of beauty marks......even though she has a polished coat....but I still like the style of the Airstream.....with all of her issues.....would do it again....and have....we have purchased 3 and still have 2...paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 03-30-2012, 04:38 AM   #1134
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
We are picking up a 2011 FB FC today! Traded the 19 Bambi.. We had a lot of the white crud on the Bambi. It bugged me to look at it, but that was about it. I did all the steps with Q Tips, and the corrosion stuff, then kept it coated with the special AS stuff. It didn't spread the four years we owned it..
It also didn't make any difference when pulling it, sleeping in it, or trading it in. We are obviously happy w AS, or we wouldn't be getting the second one.
Jeff
GettinAway is offline   Reply With Quote
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
