I added a sub, but I used the factory provided wiring. I have no TV.
The garage my unit sits in is shared and connected to a warehouse type structure that is somewhat climate controlled. In summer, the heat usually never gets beyond 78 degrees. Humidity rarely beyond 20%. Winter, mostly zero humidity and temps not much less than say 38 degrees.
I'm concerned about this for several reasons, particularly given the short response I've been able to get from support, Andy from Inland, and so far no response from Mr. Schumann. It would seem to me that Airstream does know there are issues, knows that the coatings are failing, yet it appears to me they are just throwing they're collective hands up saying, you are out of warranty, what do you want us to do about it? This may or may not be what they are doing, but it is the perception. For folks that are still under warranty, they are overlaying panels on top of existing ones, adding trim and/or replacing parts, but the problem is the issue comes back, so any work you have done is NOT a long term fix from what I have seen both first hand and and from folks that have had panels overlayed and/or parts replaced.
Now, with 16 units reporting on this forum (which in my mind would represent a small cross section of ownership), leads me to believe that this issue is far more serious that I ever could have imagined. In a year or two, the value of my Airstream will have taken a substantial hit as it will look like something out of an Elvira movie.
Our trailer was built in July '06. So far we don't have this issue.
How many of the affected Units have T.V.'s or upgraded/modified stereo's?
Being Ludites we have niether and rarely use the factory radio.
Just wondering if thats a factor as improperly grounded electronics were
listed as a cause.
GC,
Not a bad guess, however, most of our "electronics" as well as our refer and heater are on the street side of our 25FB, interestingly, our curb side has more corrosion on the middle seam than any other area. The door grab handle looks like it was dipped in corrosion. I will try to get a picture uploaded today.
Time
__________________ Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
Does anyone have a recommendation for a very small polishing wheel to locally polish through the clear-coat and corrosion? Something which will work on a very small area such as visible in some of the photos-maybe something like a dental tool. Then the small polished area can be touched up with some clear-coat. Mine ish't to that point now but thinking ahead.
Eric: Spent a while googling filiform corrosion aluminum. One point which often recurred was humidity (less than 50% will slow the process). Is there a way to check humidity in your enclosed garage, and run a dehumidifier effectively?
I'm of the thinking that since the bulk of the issue appears to be on the edges and where the rivets are, it seems to me the issue is less of a bad ground, than it might be just as simple as the coating being disturbed, but keep in mind I'm no expert, just an upset and disappointed customer.
Here is a picture of my door grab handle, the other end is even worse.
I just ordered ACF50 and Boeshield in hopes of preventing any corrosion on my month old Safari 27FB.
I don't know what it says but when we got it home EVERY exterior running light was full of moisture. What the heck is going on at the factory?
I can't figure out how to remove the small clear light lens just left of the bottom of the door. Does anyone know how to remove the lens so I can "drain" it. It says "LIFT" on it but it doesn't seem to want to move.
On that step light, use a small instrument size screwdriver and insert into the bottom. Then, lift up while grabbing each side. It should ease out. Mine kept getting water/condensation in it and I used di-electric grease around the perimeter of it to slow water penetration.
As far as a Class Action Suit, I am not so sure. Yes, I have filiform corrorosion on my rig that is 7 months old too. But, what is the fix? Sueing Airstream will not fix your rig, maybe glean some cash but what are you after cash or a fixed rig? I myself see it as a side effect from the precoated aluminum that is made worse by environmental conditions. I for one do not want the interior removed from my rig and the exterior skin replaced due to some corrosion between the clearcoat and aluminum. If you could sand the bad spots down and reclear the whole trailer than that would be decent. (it would be cool if they offered an option of the 60s grade skin w/o clearcoat for the "hands on owner" so that you may polish if you wish.
The way I see it, there is no perfect fix and the manufacturer will always claim environmental conditions caused it. I think a great maintenance regiment is probably the best answer and realize that we do not live in a perfect world.
