Old 10-14-2008, 07:12 PM   #547
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree and somewhat disagree. If best practices are being followed by both companies, and this is just the way it is, that should be noted to the customer, in which case, I'd find it shocking anyone would by a $30k+ unit with the ability of this to happen starting as early as 6 months off the assembly line.
If either or both are not following best practices, then there should be some restitution for current owners with this problem, particularly if you are still under warranty.
From the sound of what 2Air posted, new attempts at controlling this issue is being done. How successful it will be? I suspect we'll all know once the new models that are being purchased (if they are being purchased in this economy) and folks post here.
I think the answer, at least as far as I am concerned is that the coatings need to be replaced if disturbed at the time of production, however I am keenly aware that Airstream got out of the clear coating business. Which then brings it back to the coating. If the coatings were in tact, then most of the issues we're talking about here might not be as severe. A clear coat or plastic coat over the bare alum would prevent this from happening if kept sealed...or at least that's how I see it and I welcome anyone to show me how this might be incorrect.
Any way you look at this though, it's just not good by any means.
Old 10-14-2008, 07:36 PM   #548
CanoeStream's Avatar
St. Cloud , Minnesota
Good input Marshall!
Having worked a fair while to understand that epoxy encapsulation of wooden boats is destined to have membrane penetration somewhere, everywhere -- I really can't believe that clearcoat won't be compromised when draped around an edge or subjected to any number of sand impacts at speed.
One can almost say that there is no such thing as a pure aluminum surface in our atmosphere. Aluminum is softer than glass but use a coke can to scrape frost off your windshield and you'll scratch the glass. That's because the surface of the can is actually a very effective abrasive, aluminum oxide. (thanks carguys) It would be interesting to learn how this certain oxidation plays into the manufacturing process and adhesion of clearcoat.
(not related, but I know so little...) SS passivation and the galvanic series still need more learning on my part:
http://www.airforums.com/forums/f4/c...tml#post221887
http://www.airforums.com/forums/f381...tml#post402523
Corrosion Control - Galvanic Table
Except I still think that Eric's issues come down to whether it's possible at all to have a permanent bond of clearcoat to aluminum. The results with new trailers would suggest no durable coating and that the expected 6, 8 or 10 year failure might be linear and already start before year one. It's time they came up with better solution or else make clear statements if that's not achievable.
5 meter Langford Nahanni
Old 10-16-2008, 09:03 AM   #549
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by mswartz View Post
However, the atmosphere provides sufficient supply of chlorides to help initiate metal corrosion even away from sea- and road-spray.
In much of the world, there is sufficient atmospheric pollution from industrial processes and fuel-burning sources, not to mention airborne dust carried up to several thousand kilometers, to provide atmospheric chlorides for corrosion to start.
Therefore, I believe the main question (and the subject of a new thread may be) whether Alcoa and Airstream are using best available industry practices throughout their production cycle to avoid corrosion formation.
If Alcoa and Airstream ARE using best available practices, then it would be reasonable to conclude that there is nothing that they can be expected to do differently, and when we make the choice of buying these trailers we are implicitly acknowledging this.
Marshall, thanks for your well stated post. While some pollutants have been cleaned up since the 1970's, a lot haven't, and now we get stuff from a rapidly industrialized China reaching the US.
If someone were to sue Airstream or Alcoa, the defense would be they were using the best practices available. The argument would then turn to whether there were other, better practices and whether the defendants knew about them, or should have known about them, or whether they could have discovered them with reasonable effort. It's not enough to show damage. No doubt worldwide pollution would become an issue as well as more local questions—such as the amazing increase in MagChloride in recent years and how it affects everything. So far as our implicit acknowledgment that there's no better process, the plaintiff will argue prospective buyers should have been warned.
Gene
Old 10-16-2008, 09:14 AM   #550
2011 25' FB Flying Cloud
Anywhere & , Everywhere
And its all academic as they say since there ain't gonna be any lawsuit and Airstream couldn't care less.
Al - K4GLU is offline   Reply With Quote
Old 10-16-2008, 01:27 PM   #551
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That's pretty much the whole deal: I have a friend with a less than five year
old coach that looks thirty; the word was they screwed up on prep & clear
coat. Airstream did not cop to any of it; he sold it at a massive loss.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-19-2008, 05:58 PM   #552
San Diego , California
I live about 4-1/2 blocks from the Pacific Ocean. I suppose that I get some salt air here. So it is salt and oxygen. I just spent this weekend washing and doing my semi-annual waxing. Something very interesting occured to me---the filiform is pronounced on the belt-line/waist-line, however it is non-existant on the upper seam. My conclusion is that whatever Airstream is doing on the waist-line seam they aren't doing on the upper seam. (Or vise-versa). I don't know if this epiphany has been covered before, but it is very interesting. Why not above, yet it happens below. I would assume that the exposure is at least the same on the upper portions of my trailer. As for the Corrosion-X/Boeshield-9 application, I have both and prefer the Boeshield-9. I apply it with a Q-tip wherever I see or suspect filiform. It seems to give a wax type coating. I also have filiform around the taillights---like many others.
Randy Bowman
OB Bambi is offline   Reply With Quote
Old 10-19-2008, 10:32 PM   #553
2002 19' Bambi
Lafayette , California
Originally Posted by OB Bambi View Post
I live about 4-1/2 blocks from the Pacific Ocean. I suppose that I get some salt air here. ---the filiform is pronounced on the belt-line/waist-line, however it is non-existant on the upper seam. My conclusion is that whatever Airstream is doing on the waist-line seam they aren't doing on the upper seam. (Or vise-versa). Why not above, yet it happens below. I would assume that the exposure is at least the same on the upper portions of my trailer.
Randy Bowman
Somewhere in this long thread I believe I mentioned that salt near the ocean is in aerosol form as a natural consequence of wave action. That means you can consider it as essentially very fine dust which can blow inland much further than only 4 1/2 blocks. That dust settles everywhere and happily dissolves in water, whether that water is, for example, rain, wash water, or overspray from sprinklers. As to why the lower part of the seam is more affected by the resultant salt solution, the probable answer is fairly simple: gravity. The salt solution runs down off the top of the seam and happily collects on the lower part. If that solution then dries and the process repeats itself, you can end up with quite a nice deposit of salt to help oxygen eat its way between the coating and the aluminum.
It is not just that the salt helps the oxidation. Once there is a place where the filiform has lifted the coating off the aluminum, any salt solution, which seeps into the thread of filiform corrosion, dries and crystallizes (a normal process) thereby lifting the coating further off the aluminum and allowing more oxygen in. That process will repeat itself with each wet/dry cycle.
Tim A. is offline   Reply With Quote
Old 10-21-2008, 09:46 PM   #554
I have no overspray from sprinklers and absolutely NO filiform above. I can't believe that it is salt spray on the lower portions only. If I had a tiny bit of filiform on the upper parts of my trailer I could buy that idea, but there is NOTHING in the way a filiform above. Sorry to shoot down your theory. Seems like another answer is out there.
Old 10-21-2008, 10:03 PM   #555
2002 19' Bambi
Sure there may be another answer. Despite that, the aerosol form of salt is simply dust composed of extremely small salt crystals. When you wash your trailer or it rains, that dust will dissolve in the wash water or rain and run down the sides of your trailer. It can then collect on the belt seam. Repeat that process several times and you will concentrate salt at that location. I say "concentrate," but that is not saying that there are large white crystals of the stuff there.
Then again, there may be another answer.
Old 10-22-2008, 10:18 AM   #556
Silvertherapy's Avatar
2008 27' International FB
Shoreacres , Texas
Bambi,
The person I talked to at Airstream told me that the belt line seam is the only place where the panels are trimmed or cut to fit during assembly, therefore it makes sense to me that the reason the filiform mostly shows up on the belt line is because it is the only place where the Alcoa coating is disturbed during airstream's manufacture, so you would think that they would do something to protect that cut edge !!!
Silvertherapy is offline   Reply With Quote
Old 10-22-2008, 12:40 PM   #557
Aluminut
2004 25' Safari
. , Illinois
Originally Posted by jdh350 View Post
Bambi,
Ding, ding, ding, ding, ding, ding, ding....bingo! Give this post an award!
Old 10-22-2008, 01:37 PM   #558
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Happy belt moulding.
Hi, other than looks, I'm glad we ordered the Classic belt moulding trim on our Safari.
Name:	My Picture CD 080 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-22-2008, 09:16 PM   #559
jdh350: That makes sense to me. I also agree with you that if that is where the coating is disturbed, then they should take steps to cure the problem, especially since they know that it makes alot of us ticked off.
Thanks, Randy Bowman
Old 10-22-2008, 10:01 PM   #560
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
I did post a year and a half ago saying that I wasn't that turn on with new AS. Though we bought one 6 months after my post.
I have corrosion.
but check also that : http://www.airforums.com/forums/f142/check-your-as-potential-leak-45915.html#post630414
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
