03-09-2009, 09:57 AM
#701
Master of Universe
2008 25' Safari FB SE
Grand Junction
Several people have posted they can see no evidence the clear coat is compromised, but the filiform has started. That doesn't mean it isn't compromised because unless you have an electron microscope at home, your eyes aren't good enough to see things at the molecular level.
It could mean the clear coat has enough spaces between it's molecules for other things to get through the clear coat such as salt or water or some other chemical. It could mean the clear coat is not sprayed on evenly and there are slight voids or it is so thin in places other substances can get through. The clear coat may be so inferior that it wears in some places quickly. It seems obvious it is more likely to happen where the aluminum has been cut or pierced, but it doesn't always happen there. Some parts, such as tallights and door handles are even more susceptible. The aluminum, in addition, could be of inferior quality as suggested above.
Why do some people have this problem and others don't? Are different lots of aluminum and/or clear coat involved? Is application of the clear coat done differently at different times or by different people, some of whom are careless?
Without real scientific analysis all this is speculation. Unless we know what process or processes are at work here, any solutions are a process of elimination until someone stumbles, perhaps intelligently, perhaps by pure luck, upon a solution.
I keep hoping someone with the scientific knowledge and access to the right equipment buys an Airstream with the problem and finds this Forum and thread and gets to work. It's possible the answer is known at a manufacturer—Alcoa or the provider of the clear coat. Hiding a product defect and hoping it will magically go away is not uncommon in the manufacturing world and has often been discovered in legal proceedings, but as we know, that is also an expensive process. I'm hoping for the aggrieved scientist to show up.
Gene
03-09-2009, 10:36 AM
#702
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by CrawfordGene
Several people have posted they can see no evidence the clear coat is compromised, Gene
I'm one.
Found these last month high on the rear panels. This area was "clean" when sealed last Fall. No hail or ice falling over the Winter. I inspected the one spot that I missed with the DW's jewelery loupe after first posting this photo and did not find any compromise of the coating. I don't rule out something being there, I just couldn't find it
03-09-2009, 11:23 AM
#703
I'm sure some of you know, this is NOT a new problem. The gentleman I bought my Safari from has a 1965 Globetrotter with the original peeling clearcoat and very significant filiform corrosion. I really don't think that there is a solution to the problem you are discussing here, Weather you are talking about the finish or the alloy. To the best of my knowledge this has been a problem since they started clearcoating back in the late fifties/ early sixties. Any honest finish producer will tell you that finishes are not a completely protective coating. There is always transfer of moisture through clear finishes.
The issue here is that it's happening WAY TOO SOON! It is a defect, in my opinion, if it shows up significantly in about the first eight to ten years of a trailers life. If I had a two year old trailer with the corrosion I see on Sherries I would be filing a small claims court suit for the maximum allowed in your state. It would only take a few losses in that arena for airstream to take serious notice of your problem.
Sorry for your loss, Rich
03-09-2009, 11:52 AM
#704
Master of Universe
Grand Junction
I can't tell you what other states do, but here if you file a claim in small claims court against a large corporation they will get it transferred to county or district court so their lawyers can appear. Small claims court is a good solution for many small claims between individuals, but isn't set up for these kind of claims.
Gene
03-09-2009, 12:18 PM
#705
1967 26' Overlander
Winston Salem
, North Carolina
If there was no coating applied to the skin, how long would the shine last???
The units still need washing and waxing yearly.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
03-09-2009, 01:44 PM
#706
I understand that each state has their own laws regarding small claims, but if you want to get any redress at all you have to pursue it. This thread is huge, and it has been going on for years, yet there is apparently nobody taking any legal action that I have heard of. Obviously the first step in the process is to file a warranty claim, so the company will have something to dismiss/ ignore. After that the next step is to PUSH them into paying attention, which, for any business means legal action. I understand that trying to make this a class action suit is really not in the cards, but that would be the third or fourth step in the process, not the first.
In California it is not possible for a corporation to have a claim moved out of small claims and into another forum. They have to deal with you there. And who here thinks that a civil court judge would look at the pictures we see here and dismiss it as "normal wear? I think it's probably the only way to address the issue that would make AS stand up and take notice. After all, they are in business to make profit, and if you take a small bite out of it you will become much more important in their eyes.
The fact that they were previously replacing and repairing these problems shows that they took responsibility for it in the first place. This is just a tool to get them to accept that responsibility again, as they well should.
Thanks, Rich
03-09-2009, 08:23 PM
#707
2007 23' International CCD
vero beach
Hey THANKS everybody for all of the support and very good suggestions. While I am now the official "Filiform Poster Trailer"....geeze.....at least now I have some direction for contacting Airstream, contacting Bates RV, removing this mess myself, and knowing I have a whole bunch of intelligent Airstreamers helping me out. THANKS!
03-09-2009, 09:03 PM
#708
2003 25' Safari
Kissimmee
Today I tried removing several corrosion spots with fine Scotch Brite. Much of the corrosion did come off, but the aluminum dust tends to discolor the immediately surrounding clearcoat. I cleaned it the best I could with mineral spirits, and brushed on a little Krylon clear paint. It does not look very good, but it's no worse than when I started. Maybe it will slow down the cancer a little.
Dan
03-09-2009, 10:56 PM
#709
Huntington Beach
Great posts
Thanks, Rich
VIKING,
I agree with both of your posts. The small claims action is on my list since California does have a very good small claims system. My corrosion started in the first year and was noted on each service visit at our local Airstream Service Center. Each time I requested the problem to be repaired under warranty, and at first the simple problems such as the tail lights, license plate lamp and door hinges were replaced under warranty, but when we got to the panel corrosion...denied, they offered to cover it up with a beltline trim if I paid the labor...I refused. All of this is in writing with one final letter direct to Corporate at Jackson Center requesting repair under warranty. All of this was done within the two year warranty period. I keep hoping the small claims limit is raised so the real cost of the damage can be fully covered. My corrosion is horrific, sherrylyne's pictures are mild in comparison, and as you suggested, I am pretty sure a judge would agree and then some.
We are going to keep our Airstream, it (not sure if it is a he or she) deserves a good life, and even though there are some imperfections, we are not going to let some corporate baffoons ruin the legacy. America needs it's icons, now more than ever.
Thanks for everyones input and collective mindset, and a special thanks to Silvertwinkie.
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
03-10-2009, 05:33 AM
#710
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Point to remember here, Scotch Brite is glass and will scratch glass, not to be used to clean the bugs off the windshield or filliform off the Airstream.
03-10-2009, 12:50 PM
#711
holland
, Michigan
Originally Posted by cakey
As somebody who is seriously looking to buy a new 28ft Airstream 684 UK type . This has really started to concern me. Sherry`s corrosion is shocking on a 2007 model and airstreams stance is of a company that, either does not care or cannot afford too. If they think people do not wise up before they buy , time to smell the coffee . Thanks for the info may have saved me a lot of grief .
I hope your consumer laws are tougher in Europe. DO NOT buy the damn thing new. If possible find a used one, hammer them on pricing, all of our recently made units value will be dropping like a rock. I can not think of a better time to buy used, Armed with this information, and the economy, well happy hunting. You may need a good body shop/ repair center like inland rv to strip and repaint the thing, or just it let it go. The world is going to be full of silver tubes with blotches going down the road.
03-10-2009, 03:25 PM
#713
Master of Universe
Grand Junction
Small claims courts, usually a division of a county court, have pretty low limits on damage awards. Your damage may be far more and if you win in small claims, you may forfeit the amount over the award limit. County court recovery limits are also low in many states and also may not cover the full amount of the damage. You also have to know the jurisdiction of the particular court. A warranty claim may not be within the jurisdiction of a small claims or a county court. I know this stuff is obscure to most everyone, but be sure to ask the court clerk about it. The general idea of a small claims court is to help the plaintiff fill out some forms and they should be able to tell you what can be filed there, but if they are wrong, you may be up the creek. A small claims or county court may not have the authority to order the dealer or the company to do anything. Their jurisdiction may be limited to money awards only. For example, in Colorado, such courts have very little authority to issue an injunction and not in this type of case. Only courts of general jurisdiction (district courts here, circuit courts in some states, other names elsewhere) have such jurisdictional authority, but it depends on the state. You will need to show what it would cost to fix this. Since it is difficult to know what will solve this, how much money will cover the repair? Or can you show how much the damage reduces the value of the trailer—pretty hard to do without expert testimony—and would seem to need some understanding of product liability law. There may be more claims than a warranty claim, but that calls for some research.
You will need copies of your purchase contract and the warranty and hopefully some record of any corrosion claims made by you to the dealer or company. Can you show what it would cost to repair the damage? Would it mean replacing all the aluminum? Is the state's Lemon Law involved? The Lemon Law may mean, and I don't know as they are different in every state, you have to follow its requirements before you can file a suit.
There may be statute of limitations issues—they are different for different types of claims and can be very confusing. Experienced lawyers get this wrong at times, though Colorado may have the most confusing limitations of all. So, it's best to act fast, but also to know what you're doing.
I'm not trying to discourage anyone, though it is discouraging. You do have to consider: What level of court works for this? Where is that court, i.e., where do I file it?—probably in the county where a dealer which is an agent of the company is located. What authority does the court have to take the case?—a statute perhaps, as well as the jurisdiction of a court. What am I trying to prove and how can I back that up?—photos, documents, witnesses. What is my goal?—a court order for someone to do something, money, or both. Not everyone is good at litigation, including some lawyers, and it's good to know your personal limits. Asking an experienced professional how to proceed may be a good idea.
Gene
03-10-2009, 03:37 PM
#714
2003 25' Safari
Kissimmee
I understand not using it for bugs, but corrosion? What makes this different than sandpaper? sand = glass
Dan
03-10-2009, 04:38 PM
#715
holland
, Michigan
Originally Posted by Silvertwinkie
What really hits home is all of this is those 60 through 80s units look better than my 2004!!!
03-10-2009, 05:05 PM
#716
Aluminut
2004 25' Safari
...and most of them didn't show issues, some as early as 6 months off the factory floor either.
03-10-2009, 06:05 PM
#717
I don't think that you can really arrive at a "solution" or "correct the problem" with an issue like this. Corrosion is a fact of life for every AS owner. The Muthaship can't "fix" this. The best they can do is to stop making new trailers with the same old problem. Maybe they can't return to the same finish or application as they once used, but I would bet that they can do a helluvalot better than they are now! I would hate to see Airstream disappear. They are an American Icon. I hope that they can be convinced to pick themselves up out of the gutter and get back to the prominent position they once held.
My position on finishing is based on what I've seen here and on the road. I never want to have a trailer that has the filiform creeping all over it, or the blemished look of peeling clearcoat. I don't want to spend all of my "free" time polishing or sanding, or applying clearcoat. I want to hitch up and go, and be satisfied with what I have. I might polish mine once every year, or every five years, or maybe just once, but it will age more gracefully and with less maintenance if it doesn't have a clear finish on it.
As far as the issue of legal action, I did not mean that by sueing them in small claims court that you would recover your losses. I don't believe that it's possible to recover enough to make this worthwhile. My intent in saying that was that if enough of you who have this issue take a small bite out of their profits, it might be the tipping point to get them off their asses and acting on the real issue of PREMATURE CORROSION on new trailers. AND, in sunny California you can sue for a maximum of $7500.00, which would get you a stripped finish and the initial polishing job on an average sized trailer!
Someone asked a few posts ago about the longevity of the polish job on aluminum. I can't answer that very well myself because I'm just starting to polish my first one. What I have heard and believe to be correct is that the initial polishing is the hardest to do, and that the higher the polish, the longer it lasts.
I also heard that the more you polish, the bigger your biceps get!
Now that I believe!
Thanks to Silvertwinkie, for getting this started with a simple question. Bet you didn't know it might grow into this.
Happy Streaming evryone, Rich
03-10-2009, 06:47 PM
#718
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
Well was at a Airstream dealer in TX getting a little repair job done on my trailer today and while it was being done I checked all the Airstream's on the lot for filiform. I may have found the first 2009 Flying Cloud that I've seen with the problem. It had what looked like it on 2 of the curved panels but it was very slight so far and I can't swear to it. There was another FC there that seemed to be clean. But a number of the other trailers had the problem including a 2008 Sport that had a large spot next to a rivert - on this trailer I couldn't find any on any of the curved panels. There was a 2005 Safari that they had just sold used that had lots on both front and rear curved panels and around some rivets. Wonder if they pointed it out to the buyer? So if that actually was filiform on the 2009 FC it means that Airstream hasn't solved the problem yet.
03-10-2009, 06:59 PM
#719
Aluminut
2004 25' Safari
Nope, I didn't, nor did I even consider that the corrosion that I first saw would grow into what was recently pictured in post #685. Got a PM from someone also said their unit also looks like SheryLynn's in post #685 and started just like mine.
The fact that an 09 may have it, just leaves one speechless.
In reality, the thanks should go to DMac, he posted the problem well before I even got my unit, which started to get the dreaded issued about a year after I took delivery.
03-10-2009, 07:05 PM
#720
Anywhere &
, Everywhere
Couple of things I forgot. They had 3 Basecamp's and one of those had it - the first I've seen on a BC but there aren't many of them around. Also had a Panamerica and I really looked this one over close but couldn't find a trace. But they are pretty new so I suspect it's just a matter of time.
