Old 02-11-2008, 10:06 AM   #323
Toasty's Dad's Avatar
2004 16' International CCD
Cincinnati , Ohio
Just a Data Point
I offer the following strictly as my own experience, and NOT as a judgement of anyone or advice to them. But if anybody out there happens to find value here.... you're welcome.
I've followed this thread for a long time, been concerned and thought carefully about what if anything I should do about the corrosion issue.
Our own little baby has some evidence of filiform - door grab handle, door hinges, small threads of it around some rivets. The badly afflicted taillights were replaced at AS's expense in the last month of warranty, during some other repairs.
After a couple of years of dings by stones, bits of dried wax I've missed, stubborn tar and bugs, miscellaneous scratches, I simply don't find my corrosion to be either that objectionable or even that obvious. Toasty still looks just gorgeous to me.
As long as the accumulation of corrosion remains <= the accumulation of such "natural" blemishes and does not extend into the main body of the panels, I'll be able to live with it; even forget about it.
When I cease the skin examination, step away, and see all that sun-splashed aluminum shine, I'm a happy guy. YMMV.
jon
Toasty's Dad is offline   Reply With Quote
Old 02-12-2008, 07:57 PM   #324
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down
Originally Posted by flyfisher
Spilled battery acid outside the battery compartment will look exactly like your one picture.
OK....?
And the door hinges....? no acid there.
Have seen the same thing on new units at several different Dealers. Both
filiform and plain old oxidation.
Just can't rationalize the grin and bear it approach
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-07-2008, 02:23 PM   #325
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Anyone a member of Good Sam? They have a whole group that deals with RV issues.
Old 03-07-2008, 03:00 PM   #326
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
jon
This is my experience as well. Before we bought our 2001 Safari last fall, I carefully went over the trailer looking for evidence of corrosion. The door handle and hinges are pitted, and the aluminum wheels needed refinishing and some non-stainless steel hardware needed replacing, but I couldn't find any evidence of corrosion on the skin or around rivets. The trailer looks new - my neighbour couldn't believe it was 7 years old.
Maybe we just got lucky, but if so I shure hope my luck continues!
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD Hensley DirecLink McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 03-27-2008, 11:01 PM   #327
2007 25' International CCD
Corvallis , Oregon
Great! Just Great!!!
I just purchased my last Aristream a couple of month ago. So excited and still am but simply disgusted about this filiform issue. I checked my trailer over thorougly when new. Rusted tail light bezels and clearence lights but nothing on the skin. I always wash before I store. Now a couple of months later and I'm finding the little "worm tracings" on the rear panel seams. The trailer is a 2007 International CCD SS. I also noticed that the leveling jacks had noticable rust on them at delivery. Does Airstream put these trailers through a salt bath? Help guys! Please Help! We purchased a $60K trailer are we going to be faced with this disease. I have read through most of the threads but is there anything of late that works. What should I do? Either with warrenty or by my own measure. I could take some pics? Thanks in advance.
nine9three is offline   Reply With Quote
Old 03-27-2008, 11:04 PM   #328
Corvallis , Oregon
Sorry just missed out on my profile which I will change. The 92 sovereign went to a nice gentleman in British Columbia. That trailer by the way had zero issues with filiform!!!! What is different in todays manufacturing process?
Old 03-28-2008, 09:43 AM   #329
Corvallis , Oregon
bump
Old 03-28-2008, 12:38 PM   #330
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Antique Slot Machine aluminum corrosion
I know, an aluminum slot machine from 1918 to 1949 seems a distant relative to an aluminum trailer. But, there is a common element between them is the white corrosion.
I found that the low end mechanical slot machines stored in cool and humid areas were the ones that would get this corrosion. There was no way to polish the pitting on the polished surface. These were originally clear coated at the slot machine factory. Even aluminum floor scales produced by Pace and Watling would get this white corrosion.
A metallurgist at a major university might be able to explain the process. I just used these machines for parts. There was no way to restore the original finish other than bondo to fill the pits and paint over it all. I suspect it is the quality of the aluminum being used in the process and the humidity of the environment of storage.
I am watching this problem closely. Here in Colorado with the dry air might be a plus, but my experience was with aluminum slot machines was the humidity was a big factor, and the lower end valued machines had the problem most often.
Ray Eklund is offline   Reply With Quote
Old 03-28-2008, 12:53 PM   #331
_
Originally Posted by nine9three
... What is different in todays manufacturing process?
hi 993
the how and why are covered well back in the 20s/30s posts and summarized again in 63...
including links to how filiform is different from basic surface corrosion.
the difference in manufacturing is covered there too...
i'm not aware of anything NEW for treatment.
i'm trying some other products and processes, but don't have anything to report yet.
cheers
2air'
Old 03-28-2008, 07:02 PM   #332
Ray Eklund's Avatar
1950's Seeburg Jukebox Aluminum Trim
I am sorry to butt in one more time at a right angle to the discussion.
A university grad student in metallurgy can use this for a thesis or research project in the department. He would need a sample of unaffected aluminum and affected aluminum. There is a metallurgy department at the Colorado School of Mines in Golden, Colorado if someone is motivated enough to contact the school and have samples to examine (303-273-3000 General Information). Once you know the cause, then you can discuss resolutions for the problem!
Seeburg Jukeboxes have aluminum trim in the 1950's. They had a process to treat the aluminum used (high quality) that seemed very difficult to penetrate/wear and just as difficult to polish off this thin clear finish with a high speed buffing wheel and polishing compound (white brick). I understood it... as exposing the aluminum to an acid that created a clear film on the aluminum's surface. Durable, but the parts were small, so an aluminum skin of an AS might be cost prohibitive using this process.
As a last comment. I see beer cans tossed by hunters in the woods of the West from the 1970's and up that might have no paint left, but the aluminum is not corroded. Aluminum is not used at 100% purity. It is alloyed. Magnesium is added to aluminum to make a strong alloy, which could be the culprit of AS corrosion. Just some ideas to work with.
A metallurgist would have the possible options and an answer quickly.
Old 04-01-2008, 09:27 AM   #333
Aluminut
2004 25' Safari
. , Illinois
I agree a metalurgist would be able to do this...it's a shame the factory hasn't seemed to grasp this considering so many units, even ones still rolling of the lines could be having this issue.
One thing about the 50's jukes and such, remember that the EPA stopped most of the really good stuff that did work but was an environmetal nightmare. I think that is one of the reasons Airstream got out of the clear coating business, the EPA and environment issues.
Old 04-02-2008, 05:48 PM   #334
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
So get this, after driving 1200 miles to pickup my new trailer from a distant dealer, a quick pre-delivery inspections show filliform corrosion on the front AND rear cap seams.
Un-freaking believable. Several other trailers on the lot show similar corrosion. The few 2007's, like my 'new' trailer, are much worse than the 08's. The dealer has been helpful, but there is little that they can do, since this is Airstreams problems and even with a call today, stands firmly by their stance of no warranty on the skin for corrosion and no assistance to the dealer to fix the problem.
Maybe it's a good thing that I haven't signed the papers on this trailer.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 04-02-2008, 06:22 PM   #335
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Chris, what a bummer! Maybe that's why is was so reasonable in price.
Gene
Old 04-02-2008, 07:02 PM   #336
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Chris,
Stand your ground. Don't buy it and make sure the dealer has a chit chat with Airstream.
One way to start this process of solving the filform nightmare, is for not only you to turn this unit down, but as a group of Airstream enthusiists, let anyone who is considering buying a new AS know about this problem.
I'd also now start a thread called "PRE-WARNING TO ANYONE CONSIDERING A NEW AS" or something like that.
Someone with better writing skills than me should do this. (Twink?). And keep bumping the thread to the top every now and then.
It's time that Thor and Airstream live up to this problem and burying their head in the sand. This thread is almost one year old as of this date and so far there has been no progress.
This might help.
Or at least get someone to put a contract on my life....
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
