Old 10-11-2015, 12:48 PM   #2255
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Filiform corrosion - updated
For the past 8 years, I have kept filiform corrosion under control by using Boeshield T-9, along with quality wash & wax products from Meguiar's.
The recent photo of my iconic "Dragon" filiform (seen below) shows that it has not advanced from its first photo seen in Post #399 (6/6/08) of this thread.
See more photos and details... and how I do my annual wash and wax (step by step) in my updated History Safari Express post, "Wash, wax and treat II".
Name:	DSC_0061 %22Dragon%22 filiform 2015.jpg
ID:	250187   Click image for larger version
Name:	DSC_0055 Boeshield T-9.jpg
SilverGate is offline   Reply With Quote
Old 10-11-2015, 08:56 PM   #2256
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
SilverGate, your original posts on filiform treatment and prevention were perhaps the most important we have read to maintaining the appearance of our new 2012 Airstream.
Based on your reports, the first thing we did when we brought the trailer home was treat it for corrosion, all exposed raw metal on the shell, fixtures such as light bezels and hinges, and underbody steel. We have used different products, CorrosionX on the shell and Boeshield T9 underneath, but it's the ongoing regular treatment that matters.
The result of this and avoiding corrosive environments such as winter road salt and ocean salt air has been a totally corrosion-free Airstream after four years outdoors and extensive travel through the country. Thank you for this and the updates.
Doug and Cheryl
Old 10-18-2015, 09:27 AM   #2257
2008 534 International
Mill bank HX6 3EQ , Yorkshire
I am trying to remedy some of filiform corrosion issues. As I am inthe UK with a 2008 trailer getting locally sourced material is not always the easiest. I have got Corrosion X but am wondering what clear acrylic coating to then put on top...also the finish. Would VHT be a good solution?
By the way, with the rear light surrounds, screwing them inplace with iron/steel screws is almost guarranteed to create corrosion. I am on the hunt for aluminium screws!!
Paddygwalker is offline   Reply With Quote
Old 10-18-2015, 09:56 AM   #2258
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Just a thought: would stainless steel screws do the trick? They are pretty easy to get, though they cost a little bit more than standard steel or galvanized ones.
Rocinante is our 2014 International Signature 27FB
Old 10-18-2015, 10:45 AM   #2259
Gainesville , Florida
Huh!? Where are you going to put screws? Did I miss something?
Old 10-18-2015, 01:37 PM   #2260
2016 25' Flying Cloud
Nanoose Bay , British Columbia
Corrosion (?) on running light housing
My 2016 FC25 FB Twins is less than 4 months old and is developing what looks like corrosion on all the housings on the marker lights. It is brown in colour, blotchy without uniform shape and sort of looks like freckles one might see on a person's face. It's on the flat surfaces and along the edge where the housing turns 90 degrees towards the lens cap. It's not staining. See pic. It's unlike filiform corrosion in appearance (no filiform on my unit that I can see). It's on nearly all of my running light housings. Has anyone seen this, what is it, and what's the fix?
Name:	Running light.JPG
Gary Nijman
2016 Flying Cloud 25 FB Twin
2002 GMC 2500HD SLT Duramax
gnijman is offline   Reply With Quote
Old 10-18-2015, 09:06 PM   #2261
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
First Google: will stainless steel screws corrode aluminum
TheCabin is offline   Reply With Quote
Old 10-18-2015, 09:27 PM   #2262
Rivet Slave
Rocinante's Avatar
Ok, so that would be a "No." Looks like galvanized steel would probably be better than SS because of the zinc coating, and aluminum would better still. Live & learn.
Old 10-19-2015, 11:32 AM   #2263
Rivet Slave
Rocinante's Avatar
Corrosion problems with new Airstreams
Hmm two firms in our area that specialize in fasteners say they haven't been able to get aluminum screws for years, and that they only have zinc-plated or SS. No galvanized screws either, though those would have a thicker zinc coating.
Maybe you'll have better luck than us. If you find some, please share a link.
Old 10-19-2015, 11:43 AM   #2264
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
Looks like Rust to me. My marker lights mounting rings are completely brown from this rust. Watch the license plate light holder go that way too. Chrome rusts. Have been looking for replacements (probably easier than waxing continually) preferably in a hard plastic or rubber composition...
Tomzstream is offline   Reply With Quote
Old 10-19-2015, 07:34 PM   #2265
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Don't use steel screws with zink or galvanizing. Stainless will work just fine in the AL. Dip the screw first in "Never seize" or a loctite /C5 A copper.
Howard L. is offline   Reply With Quote
Old 10-19-2015, 07:36 PM   #2266
Howard L.'s Avatar
San Antonio , Texas
Those running light rings have ways been made of plastic. Unless something changed in 2016, it's not going to be rust.
Old 10-20-2015, 05:38 AM   #2267
2007 23' Safari SE
So Howard, What do you think is happening here. Mine have no chrome-like appearance at all anymore. They darkened to the point that I don't see any shine just dull, almost black. Not that noticeable. Is it a chrome like paint that is pealing? Or is it in fact rusting through to the plastic? Would it be possible to sand lightly and use a chrome like spray paint?
I haven't ever taken one apart and had considered replacing mine, but I haven't found the rings themselves.
I have taken apart the rear taillight assemblies which are Chrome surrounds mounted to the Aluminum base (the latter was fraught with filliform BTW). And the chrome there is pitted with rust, very similar to the photo above, just further advanced. Looking to replace those as well.
Old 10-20-2015, 07:40 AM   #2268
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
@gnijman
On a 2016, the bubbling of the plastic appears to be a factory defect and I would think AS would replace these.
This should not happen unless there was an unusual exposure to an environmental hazard.
Just my opinion....
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
