Old 06-24-2015, 04:12 PM   #2157
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Should've said I didn't want to take any chances
Hiho Silver is offline   Reply With Quote
Old 06-24-2015, 05:00 PM   #2158
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Ok thanks, I want to play my cards right. I am guessing that the wires would need to be cut and spliced so they can pass through. I'm thinking about having the dealer do it, then take them back off so I can treat the screw holes and any other filliform under the existing mounts. Then after that's done caulk them .....per Howard
DoublTrouble is offline   Reply With Quote
Old 06-24-2015, 05:20 PM   #2159
They didn't cut the wires when they put them on
Old 06-24-2015, 05:22 PM   #2160
They were worried about going to wire loose when they took the old ones off
Old 06-24-2015, 05:26 PM   #2161
They said that sometimes when they pull the old ones off that the wires could break and be hard to fish out. They did seal the new ones, don't think u would want to take them
Back off, or I wouldn't. I'm not 100% sure but I think the wires were not cut
Old 06-24-2015, 07:46 PM   #2162
Thanks. Trying to visualize it. I guess if you turn the assembly the right way it might fit through the base. I will call JC tomorrow and discuss the issue with them. Maybe it's best for me to do the work myself and fix it right the first time, corrosion X and nyalic then new bases and caulk them. I am feeling a bit of wonder though. Why do I have to do this with a new AS?
Then I console myself or try to anyway. It's a cool trailer you know, work the bugs out......
Old 06-24-2015, 10:03 PM   #2163
Slympicins
Slympicins's Avatar
2015 27' Flying Cloud
Sevierville , Tennessee
That was my question as well. You pay $70k for a top of the line trailer that they know has issues with this corrosion and yet they don't change up their manufacturing process to cure it? Anyone have any ideas why they don't correct this issue?
Slympicins is offline   Reply With Quote
Old 06-24-2015, 10:10 PM   #2164
Well, maybe I'll be able to ask that question tomorrow.
Old 06-25-2015, 08:19 AM   #2165
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
I doubt you will be happy with the answer, but please let us know what you hear.
Thanks!
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 06-25-2015, 09:09 AM   #2166
The word from JC is sent some pics well see how we can help.
This is the filiform bible from Ohio. So far they are listening and seem to be willing to give some help.
Filiform corrosion is a natural process that occurs in aluminum. Although we try to combat the issue with a coated aluminum and we have had better success in recent years after switching to the coated aluminum, over time, some problem areas can arise. These are usually seen where the body panels flex during transit and where the clear coat has been chipped. Once the corrosion has started, there is no real way to completely remove it, other than to replace the affected panel. That being said, there are things you can do to combat the spread of the issue.
For treatment of corroded areas you should take the following steps (all the products mentioned below are available through our online store)
1.****** Remove the clear coat over the affected area. We recommend using a plastic scraper to prevent any damage to the aluminum.
2.****** Clean the affected area with denatured alcohol.
3.****** Using the product Corrosion-X (part # 90102W) applied to a soft cloth, wipe over the affected area, clean any excess off of the area.
4.****** Using the acrylic touch up pen (part # 90000W-03) go over the affected area to cover where the clear coat was removed. (for larger areas, you can also use a spray acrylic)
To prevent the issue in the future, Iíve attached an aluminum coating care guide that should help. We recommend washing the unit frequently and applying a protectant at least twice a year. You can use anything that is clear coat safe. You can also use the product T9 Boeshield (part # 90012W) on the seams and any other areas that may have an issue in the future. You just spray it on and it creates a protective layer on problem areas.
Exterior care:
http://www.walbernize.com/
https://store.airstream.com/product-...d-maintenance/
https://store.airstream.com/product-...sories/page/5/
Parts:
http://www.airstream.com/service/manuals/
http://airstreamsupply.com/
http://inlandrv.com/
Old 06-25-2015, 09:48 AM   #2167
2015 28' Flying Cloud
Melbourne Beach , Florida
You can expect corrosion on the rear aluminum brake light castings after around 6 months in FL.
Best recommendation is to live with it. If you grind it off it comes back.
Kingsmen 33 is offline   Reply With Quote
Old 06-25-2015, 10:30 AM   #2168
Thanks, we know, a fix is in this thread. I can "deal" with that. The skin is my main concern ....
Old 06-25-2015, 05:50 PM   #2169
Kingsmen,
Somewhere in here are pictures of the tail lights that were sanded , polished and re clear coated. Robert Crosse and Howard L. are incredibly in touch maybe intimate is a better adjective, with this topic. I will personally call them the "gurus" of all things, leave it at that. I think you'll find a step by step in this thread, I tried to find it for you but I'm a little worn at this point.
Old 07-01-2015, 05:02 PM   #2170
Kingsmen,
You will find some discussion here around post # 1089, 1114, 1141 to begin.
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
