Old 06-20-2015, 05:23 PM   #2143
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Originally Posted by DoublTrouble View Post
2nd
Spend the money for the Classic Ring Bases. Stop filiform, install as per AS instructions. You'll be in business.
Howard L. is offline   Reply With Quote
Old 06-20-2015, 07:15 PM   #2144
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Howard,
Are you referring to these?
http://airstreamsupply.com/New-Airst...product_id=918
DoublTrouble is offline   Reply With Quote
Old 06-21-2015, 06:06 AM   #2145
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Those are the ones I have. Working great.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 06-21-2015, 06:17 AM   #2146
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Me too, look good and no problems
Hiho Silver is offline   Reply With Quote
Old 06-21-2015, 07:53 AM   #2147
Howard L.'s Avatar
San Antonio , Texas
Howard,
Tear drop light aluminum casting curved
That's it. Before AS switched to the new black gasket under the running lights, an owner with the filiform "light base" problem could get AS to donate the Classic ring bases along with the labor and fix the problem via. using the rings to cover the corroded area. In 2013 or 2014 they came out with the new improved gasket that was to avoid the problem of the base laying in direct contact with the skin clear coat.
Why don't you see if AS will do the same for you. If they provide the bases, You do the work, you would be done with the problem for good. You also caulk the bases with Acryl R, Par Bond, etc. when you are done and that insures the lights reman water resistant.
Here is your present gasket.
Old 06-23-2015, 02:54 PM   #2148
2008 534 International
Mill bank HX6 3EQ , Yorkshire
You mention if you are going to paint it, paint it with a/s silver ala big al's trailer. I am based in England and get all the problems mentioned in this thread....can you pls be more specific about the paint you mention....name manufacture type colour etc. thanks very much
Paddygwalker is offline   Reply With Quote
Old 06-24-2015, 09:36 AM   #2149
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
Corrosion problems with new Airstreams
I bought a 2004 Safari with very bad filiform. In some spots it was over the rivets almost 1/4". My solution was to sand and cover. I ended up using hammertone spray paint. The edges were slightly ragged, so black pinstripe solved that and really cleaned it up. I'm very happy with the new look😀 Now I have to attack the bits around the cutouts, but it's so much better to not notice it on the belt line. Click image for larger version
Name:	ImageUploadedByAirstream Forums1435160074.358808.jpg
ID:	241485Click image for larger version
Name:	ImageUploadedByAirstream Forums1435160096.532138.jpg
sb55 is offline   Reply With Quote
Old 06-24-2015, 09:44 AM   #2150
Howard, Hiho, GettinAway,
I am wondering if those cast aluminum ring bases should go on dome marker lights as well. Do they work up there with the curve?
Old 06-24-2015, 09:45 AM   #2151
SB55, that's actually a cool idea for beltline.
Old 06-24-2015, 11:32 AM   #2152
2012 30' Classic
Homosassa , Florida
The dome lights have a different base.
Tater is offline   Reply With Quote
Old 06-24-2015, 01:23 PM   #2153
Thanks Tater
Old 06-24-2015, 02:39 PM   #2154
When I was in JC they put them on all the exterior market lights, everywhere
On my 2014 Flying Cloud 27 FB
Old 06-24-2015, 03:37 PM   #2155
Curious, we're you having an issue under some, most or all and did they foot the bill?
Old 06-24-2015, 04:11 PM   #2156
I think Mine was one of the first ones with the new gaskets But I had read about the problems here on the forum and the trailer was new and I didn't want to take any
I asked but they would not do it for free. We agreed on a discount.
They look good too
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
