Old 06-15-2015, 09:47 AM   #2129
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
If you've gone through the thread much, you see the basic solutions for helping to control the problem. There is mention of repair on small areas. That works pretty well, but even the silver spray touch up I've done, does not match perfectly and would not look good on large areas. Since your later model is not Alclad aluminum, thus not going to shine silver if stripped and polished, I would paint it if the corrosion was everywhere. Replacing panels would seem to be big $$$$$. Or, just drive on and forget it. Nothing structural with filiform.
Howard
Howard L. is offline   Reply With Quote
Old 06-17-2015, 09:28 AM   #2130
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by Paddygwalker View Post
I have a 2008 534 International with all the corrosion problems mentioned. The local AS guys in the UK suggest replacing panels or spraying with paint. Your thread is really interesting. Can someone pls give me the best proven solution to remedy the corrosion issues whilst maintaining the appearance. Thanks
Good advice here.. Paddy... Would need to see pictures, at least, of your situation to try to help.
Replacing panels???? really?.. nah. I have removed the filiform corrosion, done my best to 'recondition' the surface to blend in to surrounding, then recoated with Nyalic. Get the 'kit'...
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-18-2015, 07:17 AM   #2131
Mill bank HX6 3EQ , Yorkshire
Hello CWF
Thanks for your response. I have copied photos below as requested. You will recognise where and type of corrosion I am sure. You mention get the kit etc but may need more spec as I will need to source from England, although I am sure my bro in Boston can help. Thanks again....Paddy
Paddygwalker is offline   Reply With Quote
Old 06-18-2015, 11:58 AM   #2132
Howard L.'s Avatar
San Antonio , Texas
Hello CWF
Paddy, I don't recognize that panel shown. Also, is that you're only problem area? A separate tray such as that can be painted silver very easily and look just fine.
Howard
Old 06-18-2015, 07:43 PM   #2133
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I may have missed something.
Is it recommended to remove all of the AS decals to minimize filliform risk?
ID:	241046   Click image for larger version
DoublTrouble is offline   Reply With Quote
Old 06-18-2015, 09:40 PM   #2134
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here ya are, Paddy...
NyalicŪ
The stuff appears to be used in UK..... So should be able to buy....
Channing
WBCCI# 30676
Old 06-18-2015, 09:43 PM   #2135
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
I would remove stickers.... Carefully.... Be very careful as the underlying "clear protection coating" can be damaged.
Channing
WBCCI# 30676
Old 06-18-2015, 10:43 PM   #2136
Goo b gone, is it OK with clear coat?
Old 06-19-2015, 06:58 AM   #2137
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
On one spot it worked ok.. On another it gummed it up. The longer it sits the more likely to mess with the coat. Why are you wanting to use it?
Channing
WBCCI# 30676
Old 06-19-2015, 08:40 AM   #2138
Just want to gather w ha t I need to get the stickers off since I'll be working on it in a campground thus weekend
Old 06-20-2015, 09:05 AM   #2139
A sad day. 4 months from production. Last night I noticed the dreaded white, evil filliform rearing its ugly head from behind my curbside rear marker light.
As I looked around the rest of the lights I noticed that this light in particular seemed to be missing the gasket! So it looks compared to the other side.
ID:	241147   Click image for larger version
Old 06-20-2015, 12:51 PM   #2140
further along o Father's Day weekend, Two things are obvious. 1 In my case the gasket was not adequately shaped and the plastic housing must have rubbed through the clearcoat slowing filiform to start. 2 each screw hole I've checked has the beginnings of filliform. Under the first lens the issue is aggravated by a metal bur from the screw hole.
Old 06-20-2015, 12:54 PM   #2141
1st marker
Old 06-20-2015, 12:55 PM   #2142
2nd
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
