Old 08-24-2014, 12:09 PM   #2101
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Doug, the sealant you talk about at the panel edges, I take as the AcrylR used to seal the overlaying seams. On my trailer, there are some edges that are covered with the gray sealant-though not completely. Other edges look to be wiped completely clean. It was at the clean edges, even with the sealant showing, where the edge creeping Filiform started in several places.
Name:	ImageUploadedByAirstream Forums1408902997.596397.jpg
So, I can say with certainty my trailer edges were not treated. Plus, remember, Cust serv said they did not coat the edges. The rivets? There are just too many that show a thread or two of white squiggle to suggest any coating is applied prior to riveting. A corrosion X coated rivet would be the ticket there. Or a quick spritz of corrosion preventative at the holes prior to riveting would work.
Howard L. is offline   Reply With Quote
Old 08-24-2014, 12:25 PM   #2102
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Thanks Howard, I would agree it is an overlapping edge sealant rather than a protective treatment.
Doug and Cheryl
Old 08-24-2014, 12:35 PM   #2103
Durango , Colorado
I am picking up a new airstream soon and have a question.
After applying corrosion-x to the edges, is it OK to wax with a sealant wax to help protect the edge or will the sealant wax remove the corrosion-x treatment?
RVDreamer is online now   Reply With Quote
Old 08-24-2014, 12:58 PM   #2104
Howard L.'s Avatar
San Antonio , Texas
Doug's the corrosion x guy, but I don't think waxing will remove anything. I do recommend using a small touch up artist brush and run a thin covering of clear coat on every exposed panel edge first. Once dry then put on your corrosion X and wax.
Old 08-24-2014, 03:56 PM   #2105
Durango , Colorado
What product do you recommend for the clear coat?
Thanks!
Old 08-24-2014, 04:25 PM   #2106
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Don the factory tour guide told me he uses liquid Turtle Wax on his Airstream.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 08-24-2014, 04:58 PM   #2107
dkottum's Avatar
Followed your recommendation today and used Airstream Store's acrylic touchup pen (hard felt-like tip) to put two coats of acrylic on all the panel edges. Took less than an hour and I'm an old guy.
Will continue my quarterly treatment of CorrosionX to the panel edges, panel rivets, and exterior fittings and hinges. About an hour.
That gives us two layers of protection, plus an annual wax.
Doug and Cheryl
Old 08-24-2014, 05:14 PM   #2108
Howard L.'s Avatar
San Antonio , Texas
Thanks!
RV, I use Nyalic. It's a clear liquid polymer. Google their web site to learn more. But, any clear coat will work. You are just making sure the raw edges are permanently coated and will not allow corrosion to start there and you only do this once. You then are looking for the corrosionX to soak in behind the rivets, belt line trim the seams and those same edges to further deter Filiform. That C X and whatever polish you want to use should then be part of maintenance on a regular basis.
Name:	ImageUploadedByAirstream Forums1408921979.941769.jpg
Old 08-24-2014, 09:03 PM   #2109
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Airstream clear coat marker vs nylac? I think before you said you'd spray nylac into the spray top then pain on with small brushes as shown in photo?
Seems like the market would be easier?
PharmGeek is offline   Reply With Quote
Old 08-24-2014, 09:12 PM   #2110
Howard L.'s Avatar
San Antonio , Texas
For just a touch up or two and the edges, yes the marker would probably do fine. But, remember, I've done some larger areas of repair and those have been with spray. The spray can will provide you with the product to use both ways. Individual choice on product and application method, just get those edges done with something. Not everybody is lucky like M.Hony who has yet to see the first white squiggle.
Old 08-25-2014, 12:46 PM   #2111
interstateflyer's Avatar
2017 25' International
Los Osos , California
I bought an aerosol can of Nyalic to apply to the cast aluminum parts on my new trailer. Nyalic Tech support suggests a three step process for surface preparation.
1. Dupont Prep-Sol to remove wax and other contaminants.
2. Dawn detergent.
3. Denatured Alcohol (not isopropyl)
I can't find Prep-Sol for sale to the public anywhere in the U.S. Has anyone used another product successfully for this step?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-25-2014, 01:20 PM   #2112
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Go to a bicycle shop and buy a can of Clean Streak. It removes any trace of wax or grease.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 08-25-2014, 09:45 PM   #2113
Howard L.'s Avatar
San Antonio , Texas
2. Dawn detergent.
When I ordered the product, sales said just sand and clean real well. Prep sol was good to use but not necessary, so I've not. However, you are probably smart to follow all instructions you can. The product adheres well to everything I've applied it to. When I repair a small Filiform line, I lightly scratch the squiggle with a needle, dab some corrosion X in the area and let soak for a few minutes. Then I wipe clean with a dry clean rag and touch up with Nyalic right over the C X film that must still be there in the scratched squiggle. A minute amount of C X is sealed inside and the Nyalic adheres perfectly. But again, except in a case like that where you do not want the oil to be cleaned away, there is no such thing as over cleaning and prepping.
If you are applying to new cast pieces and no Filiform has formed yet, you don't need to sand the original clear coat away unless you want to. Just sand it lightly with 1000 grit, clean well and spray, or brush the Nyalic on. It will over-coat just fine.
Old 08-28-2014, 01:00 PM   #2114
dbj216's Avatar
1986 34' Limited
1966 24' Tradewind
Conifer , Colorado
I read this thread with interest. I wish Airstream would focus on building the best aluminum shell travel trailer possible. They are unique, an American icon, light weight, and beautifully finished inside. Most folks know them as long lasting trailers. Airstream designers are very good at luxury small space living. I agree with others that Airstream should have discovered this filliform corrosion problem during their pre-production testing. Further, they should have made a corrective action as soon as complaints from customers started coming in.
So Forum members have developed and shared filliform mitigation techniques that keep it in abeyance. And I have also read mitigation techniques against leaks and floor rot. OSB floors anyone? I submit metal frames should not crack or rust in this day and age. Why not use the best tail light housings and marker lights possible? I submit Airstream can improve the trailer so these problems are mostly eliminated.
Airstream should build a top line travel trailer that lasts 50 years. If the pricing of Airstreams was 10% higher, would customers not buy? We willingly pay a huge premium over SOBs to get Airstream "Cadillac" quality. Or is it "Bentley" quality. A 10% adder to materials and workmanship to elevate Airstream out of these complaints would be worth it in my opinion. Back up your progress with the best warranty in the industry.
You probably have heard about Yetti coolers. Here is a "bear proof" ice chest that cost nearly $300 for the small size. It will keep your beverage cool for a long time. It typifies a very high end product. Airstream should have that mindset in my view.
My 86 doesn't have filliform corrosion, but it doesn't have clear coat anymore either. It does have beautiful hickory cabinets that have stood up well through the years. And the drawers don't come open while towing. Those cabinets are what sold the trailer. Premium quality.
"We won't make changes, only improvements" says Wally Byum way back when. Good advice today.
David
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
