Old 04-08-2014, 02:41 PM   #1863
1999 30' Excella 1000
Brookeville , Maryland
Fan may have a point. I wonder if Airstreams in Seattle Washington have filliform problems? I have a 1999 exella classic 30' with minimum filliform. I wonder what upper management changed ie. vender of aluminum , assembly procedure, or clearcoat formula after yr.2000 to cause this problem? The aluminum wheels I bought has more filliform than the whole trailer... they're off a 2011 airstream. If it wasn't for the govt. bail-out... G.M. would be no longer.
streaminwild is offline   Reply With Quote
Old 04-08-2014, 03:54 PM   #1864
Originally Posted by scamp View Post
But how many new airstreams could be sold if they make them properly !
You can only imagin. If the factory was automated they could pass the savings to us. The ralleys would be back to the 50's and 60' numbers. The old pictures show no less than a hundred in attendance. The competeters would shudder to this fantacy.
Old 04-08-2014, 04:45 PM   #1865
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Everyone has their own Airstream quality experience. Ours was beautifully assembled at the factory, and has no corrosion whatsoever going on three years. Everything works. If it doesn't we will fix it.
We inspected ours thoroughly for operation and defects when we bought it. There were none. We treated the shell, fittings, and underbody for corrosion the day we brought it home. I bought an inexpensive Sonin moisture detection meter from Amazon and checked it for dampness in the plywood subflooor, which revealed four leaks in the shell.
We had a trip planned to have reclining chairs, table and cabinets installed in the front of our trailer at Jackson Center factory service so while there we had their 26 point inspection done as well as a Seal Tech pressure leak test. That confirmed the four leaks in the shell and they fixed them under warranty. They replaced all of our exterior clearance lights because of the poor seal design.
We use a quarterly inspection and maintenance plan to check systems, check for leaks, and renew anti-corrosion products. We put a new top quality polish on yearly. If something works loose, we tighten it. If we break it, we will fix it. If we don't like something, we change it. It there's a nick, we touch it up with clear acrylic or paint. And if the roads are salted I don't pull our Airstream on them. I'm guessing it won't be sitting at the beach much either, but that's a personal choice, we have plenty of fresh water at home.
And we use it, been on the road 18 months since new, traveled coast to coast twice and border to border several times.
There are many, many Airstreamers over the past 80 years who have done something similar. Keep the tool kit and maintenance products at hand and use them.
In the time I took to write this I could have treated half the shell for corrosion. That's how easy it is.
Doug and Cheryl
Old 04-08-2014, 05:25 PM   #1866
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
streamin, I am truly beginning to think same, re: a wet climate is actually good for clearcoat preservation. The FaN is also hosed down 1 - 2X per week in the summer because the livestock kick-up some dust. The trailer is also dripping with dew in the morning. It is a trailer that spends most of its life wet.
BTW, people who dwell on this wet coast also have the best skin. I'm not making this up; our dematologists attribute it to the rain/moist air.
So, what is good for the complexion is also good for the Airstream skin - even without Oil of Olay?
Does your trailer look older than your husband?
Oil of Olay commercial - YouTube
Fly at Night is offline   Reply With Quote
Old 04-08-2014, 06:45 PM   #1867
2015 16' Sport
ottawa (greely) , Ontario
To me this is not acceptable four leaks on a two year old trailer ,and replace clearance light gaskets did airstream just start making gaskets for clearance lights ? Kinda crazy yes I know there are maintenance on airstreams but they need to fix this problem not just put the same defective gaskets back on , to me they never fixed the problem you will have the same problem back in less then two years and your floor is wet and rotting out,not to mention other dampness problems frame rusting etc. hate to be negative but can you imagine if car manufactures did this ! There would be a lot of lemons cars out there or they would be out of business .
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 04-08-2014, 06:58 PM   #1868
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
I completely disagree with this statement and you assumptions about why people buy Airstreams or how uninformed AS buyers are. Quality can always be better, but compared to other brands of Travel Trailers Airstreams are WAY better built in my humble opinion. So yes, while I purchased partly based on the allure of the Airstream brand at least 50% of my purchase decision was made on the superior quality of Airstream compared to just about every other kind of Travel Trailer.
Originally Posted by ggoat!!! View Post
However...Airstreams don't sell based on quality control. They sell based on their PERCEIVED quality but mostly on their look and history at this point.
jpons is offline   Reply With Quote
Old 04-08-2014, 07:13 PM   #1869
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I wish our unit arrived and met our expectations for a $100,000 trailer versus the issues that greeted us.
A simple run to Jackson Center is about 1,950 miles EACH way or nearly $800 in diesel fuel for the trip. That makes a beginning price for "free" warranty repairs seem not so free.
And many of our issues were due to a "don't care attitude" like improperly installed alignment blocks for the couch arm rests, duct work collapsed because the cabinet was put on top of crossed runs, sloppy cut ins of the wall covering around the access hatches, dented ceiling material.... the list just goes on. I pointed out both in person and via email to the QC manager while I was at the factory watching snippets of the assembly process the loose rub rail by the center awning brace. It was NOT fixed before the trailer left the factory.
So the corrosion issue is just the decorative icing on the "issues" cake!
Old 04-08-2014, 08:14 PM   #1870
r carl's Avatar
Lin , Ne
I always wondered what happened to the Yugo.
r carl is online now   Reply With Quote
Old 04-08-2014, 08:15 PM   #1871
There's a current thred called ''Should this be the new Airstream''? Carbon fiber trailers may be the next rage. I'm surprised on how many streamers might consider this concept. Thor better look in the rear view mirror if the manufactor rounded the corners off... Fan I'm buying misters for Airstream to simulate the wet coast climate as for me...I would have to do a complete face off restoration.
Old 04-08-2014, 08:19 PM   #1872
2014 23' Flying Cloud
Reed Point , Montana
Just purchased a beautiful red Honda 3000 watt generator today, works perfectly no corrosion issues......I'm sure it will outlast my new AS, very sad commentary on "American Made".
Bigskyrider8 is offline   Reply With Quote
Old 04-08-2014, 09:21 PM   #1873
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Originally Posted by silverwheels View Post
Howard, are you suggesting a class action law suit? It has been addressed here many times, however no one has jumped on the band wagon.
I can appreciate that GREGU's concerns were addressed, but he had to drive to the factory. And that's 100's of miles away for me. Has anyone had any success contacting AS and requesting they front the cost for repairs done locally?
Not suggesting class action at all. In an earlier post I commented how that was discussed here in 2007 and like you said, the idea pops up again ever now and then. Clear coated Aluminum will never be without problems. As owners we should know that and try our best to maintain. But reports such as GregU's show many of our problems could be avoided with better construction care and quality control.
Those of us posting on this thread are voicing our frustrations, our efforts to repair, our attempts to get the company to come to the table with help. We really are a pretty good knowledge base of what happens in the field. My question to the group is, should we, as a group, approach Thor with suggestions that we feel will improve the quality of the product that leaves the factory. Maybe I'm being naive and they don't care, but to blow off a big group of concerned owners would be awfully foolish. Not sure exactly how to do this, but we are many, Lawyers here, business Execs here. I'm thinking someone would know how to approach the company and who to contact. Just an idea, just a question.
Howard L. is offline   Reply With Quote
Old 04-08-2014, 09:35 PM   #1874
Maybe we should have a filliform rally at the plant. I mean Airstream rally.
Old 04-08-2014, 10:32 PM   #1875
dkottum's Avatar
Let me explain the leaks as others may find the same ones. Two were at each end of the optional street side awning arm brackets where water is funneled down like gutter ends. The screws/rivets were sealed but not well enough for this spot. One where the lower entrance door hinge screw had loosened over time. The other at the rear window larch that was not tight enough. They're not shocking, easily fixed and we verify it during quarterly inspections.
Our Airstream is corrosion free. Meantime the Toyota truck we traded recently suffered a well rusted frame and heavy filiform corrosion on its aluminum wheels. The Tacoma we had before that had such a rusted frame Toyota was replacing them so they didn't break in two. We don't have to imagine if car manufacturers did this, we experienced it.
Doug and Cheryl
Old 04-08-2014, 10:58 PM   #1876
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by Bigskyrider8 View Post
"All that glitters is not gold"
Three weeks ago I picked up my new 23' Flying Cloud, brought it home and tucked it in my garage. After reading about corrosion issues and build quality I've spent the last two days crawling underneath mine, cleaning, scrubbing and applying T-9. I've found three panels that have rivets that have pulled out or were never punched through causing the panel to sag about 1/4 inch in spots.....disappointing for sure.
I also found gobs of silicon on the roof seam that has pushed out and appears like sloppy application at best. Is what it is, but............I understand it's not a BMW (I've owned many) or a Ferrari, I've raced many, but I expected better.
Welcome ... understand that the AS is not perfect and often disappointing in QC, but it is still the best assembled that we have found. We had a hit list of over a dozen problems - mostly addressed by ourselves (dealer from whom we purchased is 600 miles away and local does not have a good record with many AS owners) with a few parts supplied by AS.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
