Old 07-19-2007, 07:15 AM   #221
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Sorry to hear we have more folks joining the ranks. Keep em coming.
Carol, your exp was not what I had seen when I was at JC. Perhaps it could have been because you were there during the actual camping season when everyone is camping and needs something? Not sure.
Also not entirely sure about the ACF-50 if you can't get the surface scraped as well. I must say, this is a total disgrace to have spent as much $$$ on these and to see the skins and other alum areas on the exterior fail so soon (some as soon as 6 months off the production line).
Old 07-19-2007, 08:49 AM   #222
Cracker's Avatar
Pittsfield , Maine
I have not followed this thread for awhile but starting after my original post (#146) I noted that there were several comments with respect to soaps, detergents, and even Walbernize. With further respect to my trailer, I wanted to add that, with the exception of one wash job done at Jackson Center in 2005 to remove mildew on the roof, I have never used any detergents or cleaners on the trailer - being quite satisfied to simply hose it down and use a sponge to remove any remaining dirt or stains. Call it laziness on my part, or whatever, but the trailer still looks great and the connection between filiform corrosion and detergents should possibly be considered. I agree that it's still a problem if our trailers can't stand up to a good washing - but, if so, we need to find out why.
Cracker
Cracker is offline   Reply With Quote
Old 07-19-2007, 10:38 AM   #223
Aluminut
2004 25' Safari
. , Illinois
I'm with you on this one. The root cause is what I'm looking for, but so far the sound on the other end of the phone is total silence in terms of the factory. I don't think they really know what to do about it. I've heard several things the factory wanted to try. Sanding down the spots and put nail polish on the skin (great idea if you have this everywhere as mine does...imgaine what that would look like), ACF-50 (which now appears not to be the fix we had all hoped), etc.
I have also heard that folks that keep their units outside have had more issues than those inside. There are several educated guesses we all can make, but I'm happy to have the engineers who design and build these things find the answer, even if it means there is no hope for my unit. As long as they find a fix for all the new trailers they build because it's a god awful thing to plunk down $40+k and in some cases, a heck of a lot more to have your finish totally degrade, even as early as 6 months off the production line. I'd love to own another Airstream in my lifetime, but I won't buy another one and will let anyone considering a new Airstream know of this problem, which they can read about on this thread.
I personally think that anyone considering a new Airstream should really consider the fact that the unit they buy, has a good chance of this happening. There are just too many folks, in too many parts of the country to say this is just a fluke. In my case, mine is indoors, somewhat climate controlled, kept clean and each month, it see more and more spider veins appear and the existing ones get worse, and it hasn't been washed since last fall (I only used it 3x last year).
Old 07-19-2007, 12:46 PM   #224
2002 19' Bambi
Lafayette , California
As for possible problems with washing, I was one of those who suggested that detergent might contribute to filiform corrosion with the thought that the surfactants might aid moisture penetration between the clearcoat layer and the aluminum. Since this would be along the edges of the aluminum sheet, the increased edge exposure with the introduction (re-introduction) of the non-covered horizontal seam might contribute to more filiform corrosion.
Despite such a possible technical explanation for some increase in corrosion, there may be an additional factor which I have mentioned on another thread, but will repeat here where it probably belongs.
Not all new Airstreams seem to have this problem. Most with the problem seem to have been built around 2004. It is very possible that Airstream got a "bad" batch of clearcoated aluminum at about that time. "Bad" was surely not apparent at the time of delivery or trailer construction. I do not know how Airstream orders materials, but can imagine that the batch size was probably large. Nevertheless, all of that batch would have been turned into trailers before any problem became apparent.
Is Airstream obligated to make "good" a cosmetic problem? Who knows, but I would remind people of all of those cars with pealing paint in the 1980s. As I recall, there was no major restitution by the car manufacturers.
Tim A. is offline   Reply With Quote
Old 07-24-2007, 07:14 PM   #225
Aluminut
2004 25' Safari
. , Illinois
I agree to a point. There have been units 6 months old (2006 model year if I recall correctly). I'm not as interested in my unit being fixed as Airstream finding the answer as to why this is happening. This is unacceptable given the high cost of these units.
Old 08-02-2007, 06:04 AM   #226
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Wheels are peeling on 2007 Safari
Just returned from a 3 week trip with our 4 month old Safari. The wheels were perfect before we left but while checking tire pressures on the trip I noticed that each wheel had a piece or two of clearcoat the size of your palm peeled off.
Like some others have said, unless you can get the clearcoat to bond to the wheel, maybe it is better to just have an unfinished service that will be uniform.
I'll just add this to the list of defects for our visit to JC.
SilverCottage is offline   Reply With Quote
Old 08-02-2007, 04:55 PM   #227
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Corrosion 2003 Classic
This is only a portion of what we are trying to deal with. What to do??? Does anyone have a reliable fix. How do we make a repair without damaging the surrounding area??
Still learning how to navigate the site>hope the photo's uploaded properly!
Well it looks like the photo's are there. Being a 2003 any attempts at repair will be done by yours truly so any help would be greatly appreciated. I could post quite a few more photo's but I think ya all get the idea> I find it hard to believe the number of posts about this problem. I guess I should be happy that the wheels have not been affected<><>yet.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 08-02-2007, 08:00 PM   #228
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Corrosion
We have been having the same problem with our 2004 Classic. Corrosion around the battery compartment doors. Corrosion on the entry door hinges. Corrosion around the tail light assemblies. I have been carrying my dremmel with the small buffing wheel and polishing compound to remove. Then I spray with clearcoat. So far areas I have treated seem to be OK. I am more concerned with the rust that has formed on the galvanized rear storage drawer, the galvanized power jacks and the galvanized hose clamps for the LP gas lines. and the storage area behind the LP tanks. This really makes me worry about possible frame rust and other areas I can not see.
Larry
fltlevel510 is offline   Reply With Quote
Old 08-02-2007, 09:07 PM   #229
Thumbs down Corrosion 2003 Classic
Larry;
Had the same concerns with the rear slide out. Have drilled several drain holes to keep it as dry inside as possible.Also found some snap together dry-lock plastic flooring material at Home Depot that helps keep it dry. Would be nice if the if it retracted far enough to keep most of the water out. As for the stab jacks I just spray them down with an oil based undercoat during spring get ready,as well as most other unprotected undercarriage metal. Those entry door hinges worry me though, the corrosion is pretty bad and I sure would hate to brake thru the clearcoat, I have tried polishing several small spots around the entry door handle with fairly good results. But I really think this is going to be a never-ending maintainence concern.
On the LP lines, I have found some of the plastic zip-ties that will go around the line and have a tab with a hole that can be secured with a stainless rivet,just have to crawl under and get it done. I got used to checking the undercarraige on a regular basis with our "63" Safari. You may have to replace one or two every spring, but it's better than the lines failing!<><> Bob
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 08-03-2007, 09:06 AM   #230
corrosion
Bob,
My solution to the rear drawer rust was to remove and have coated at the local LineX bedliner shop. I also removed and coated the streetside tool/storage box and the curbside box where all the water connections are made. This has worked very well. I painted the stabilizer jacks with POR 15 and seems to be holding up well also. Maybe I just need counseling for my compulsive behavior??
Larry
Old 08-03-2007, 01:18 PM   #231
Send a message via Yahoo to dhe9
white spiders
hello,
must confess i did not read all 17 pages of this post but wondering if the clear coat can be stripped off and the '03 posished as the older ones are?
this may be the only solution to the spider webs showing up.
david,
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 08-03-2007, 02:10 PM   #232
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by ROBERT CROSS
Larry;
Go with these to secure your gas lines - they are stainless steel with a rubber protective strip. Made for wire runs - they are strong and look better. Click on link for a source, I have no connection to them.
Electrical
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-03-2007, 02:33 PM   #233
Aluminut
2004 25' Safari
. , Illinois
Originally Posted by dhe9
hello,
david,
socal
Yes and no. Yes, the pre-coated aluminum can be stripped, but I've been told by many folks that you cannot get the new Airstreams to shine like the old ones (mirror finish). Best we can hope for is to strip down the shell and re-coat it or paint it.
Old 08-03-2007, 04:16 PM   #234
A Multitude Of Corrosion Problems
What I have found since joining the Forum is there are a lot of Streamers out there with vary similar problems and at lot of different, but vary good solutions, now that is cool!!!
Another concern we ran into when it was time to change some burnt out clearance light bulbs on the "63" Safari, steel screws in the aluminum can be vary difficult to remove. Six bucks of stainless hardware solved the problem. It was one of the first things I did when we got the new rig home. I really don't mind doing this stuff, but you would think that the Factory might consider a few upgrades along these lines.
Thanks to all and keep on Stream'n!!!
This photo is for dhe9 SEMPER FI
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 08-16-2007, 08:11 AM   #235
Aluminut
2004 25' Safari
. , Illinois
I was thinking this was mainly an Airstream issue (the rims), but I just had all 4 of my GM 3/4 ton rims replaced under warranty on my 2004 Suburban, so it is an issue that does go beyond Airstream, though I still am under the impression that the skins on the Airstreams that have this same issue are clearly an Airstream manufacturing issue that to date, I've heard no solid fix that could keep it from either happening or significantly slowing it down.
Old 08-16-2007, 04:18 PM   #236
lewster's Avatar
Naples, FL , Hood River, OR
I tried some ACF-50 per the factory rec. on some of my small spots. It didn't touch them as far as removing the corrosion.
OK, so I removed the nasty white stuff with a super fine fiberglass brush and then coated it with ACF-50. I have not seen any filliform return there yet, but I still have my doubts. The spots at this point are definitely noticeable.
Next step is the Corrosion-X Aircraft formula. We'll see how that does.
Stay tuned for the next report in a few weeks!
Old 08-16-2007, 06:06 PM   #237
2007 25' Classic
Hydes
One thing that I discovered that works really well on bringing galvanized metal back to a better than new finish is Naval Jelly. Work in all over with fine steel wool. If you let it dry it leaves a white residue so you have to wipe it down with mineral spirits. Question :the screws that hold the rear tail light lenses rust right away, I've replaced mine with stainless steel but the original screw is a very course thread and even the course stainlees screws from Home Depot aren't course enouhg to hold in the tail light plastic housing.Anyone have a suggestion for a replacement in stainless??
craftsman is offline   Reply With Quote
Old 08-16-2007, 06:53 PM   #238
Santa Clarita , California
I also have spider webs and corrosion on the hinges like the ones shown in post #227. I assumed that perhaps it was from the p.o. storing the trailer under a cover or some such thing, but apparently not. I've applied a couple coats of wax to try and keep it at bay, but wasn't anticipating doing anything beyond that to remedy the situation. I'll have to keep a closer eye on it.
Roadmaster39 is offline   Reply With Quote
Old 08-16-2007, 08:30 PM   #239
2002 19' Bambi
I suspect you just need a larger screw. I assume these are sheet metal screws. If so, you probably need a size 8 if your Home Depot screws are size 6 or a size 10 if they are size 8. If Home Depot does not have various sizes (and by size, I do not mean length), try a couple of hardware stores or a marine supply store.
Old 09-15-2007, 01:57 PM   #240
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
After plowing through 18 pages on corrosion I am wondering if there was any resolution? I am interested in buying an Airstream, but wondering why I would expose myself to this grief?
It seems the problem began midway in 1999 and got worse in 2002. It also seems most of the complaints are from states with winter salted roads and near the ocean. I suspect ocean salt carries further inland than one would suspect. Maybe the problem can happen to anyone whose trailer was somewhere there was salt on the highways, perhaps being transported from the factory.
This can be a combination of causes—salts used on roads and ocean air can carry salts almost everywhere. Coatings have changed over the years.
I am reminded of the changes in interior paints. Paint changed significantly around 2000 as I found out when I painted some bare wood and the paint pealed. Now it is necessary—even with latex water based paint—to use a primer before painting. Are there similar problems with the clear coats used since 1999? Maybe they do not cover or protect well compared swith pre-1999? There is a lot of discussion is using water based vs. oil based polyurethane on furniture and house interiors, although I don't know who's right. I continue to use oil based polyurethane because it is so forgiving and lasts even though the offgassing is ugly for several days. I also just sprayed my log house yesterday with oil (not a lot of fun! Preparation takes about 12 hours, spraying 90 minutes) because I know it works.
Another thing that has changed is the massive amount of magnesium chloride on roads in wintry states since the late '90's. How does mag chloride react with aluminum or the specific clear and other coats used on it? Calcium chloride (and sometimes mag chloride) is also used on dirt and gravelled roads to keep dust down—you don't have to live in a wintry climate to experience that. Perhaps even the most minor exposure to these salts can penetrate the various sealers and show up weeks, months or years later. Perhaps there is enough salt deposited on roads in Ohio (where the factory is) that even in summer some gets on the units as they are transported across country. Perhaps a team of PhD metalurigists and chemists can answer this.
Other thoughts: I use a pressure washer full blast on my Toyotas without problems to the clear coat, but it may bond differently to the underlying paint. One can reduce the pressure considerably of course on a trailer.
Someone mentioned more corrosion on the curb side. That is probably because during rain the roadside is washed by cars coming the other way and tends to remove some of the grime and salts. Of course, you get more nicks on the roadside, so there is a cosmic balance in this. Towing the trailer backwards half the time would even out things, but unrecommended.
I read once that cars stored in a heated garage had more corrosion because of the rapid changes in heat vs. cold. Of course, this only applies in wintry climates and for people who take their Airstreams in and out frequently, but may be factor for some people.
And about class actions. Yes, there are bad lawyers who get all the money and poor remedies for clients. I'm a retired lawyer and enjoyed pursuing unethical lawyers who screwed their clients, partly because I get tired of being insulted because some colleagues are bad people. Class actions on the federal level have been made very difficult because large corporations got to Congress a couple of years ago. Yet, the threat of litigation can move a company like Thor to take action and there are good lawyers out there (I'm retired and glad of it, so I'm unavailable, but when I'm wronged by a corporation I know my letterhead gets a quick response, most of the time). Considering the value invested in an Airstream plus the grief in maintaining it, investing in an (ethical) lawyer seems well worth it.
Since some of the parts experiencing the most corrosion may be different metals, this may be a problem. Ask a plumber what happens when you connect copper pipes to steel pipes. It creates an electrical issue which results in leaky joints and a brass connection is used between the metals. I think I have various metals right, but the principal is correct. Some metals have to be isolated from each other with a nonconductive substance (rubber or plastic would work on tailights for example).
I think the root cause is more complex than most of us can grasp just because it takes years of education and experience in rather obscure sciences. People with airplane experience may have the best handle on this because concern about falling out of the sky tends to result in solutions. I doubt Thor has the right scientists on salary to figure this out and have circled the wagons and have acted irresponsibly out of uninformed defensiveness—always the most expensive way to deal with a problem, but also the most common one. Alcoa should know answers, but doesn't seem to want to. Thor is the primary responsible party and there may be remedies beyond warranty claims, especially if claims were made and recorded before the warranty ran out. A product liability lawyer may be able to help. If I had a $50,000 unit that looked like the ones in the pictures I would be enraged.
This discussion certainly makes me look harder for an older Airstream, something I doubt Thor will like.
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 1 07-10-2019 09:45 AM
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 07:30 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 10:48 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 01:58 PM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 08:34 PM
