Who out there has a newer Airstream (say from 2001 through the current model year) that has the dreaded white spider veins AKA: form fill corrosion?
I know that Dmac had this and I do recall others saying they their shells had issues. I'm wondering now how widespread this issue may be. IMHO, this issue started on my trailer back in spring of 2005. The factory replaced all 4 of my rims and both cast alum tail lights. Not only has the corrosion come back on all 4 rims and both cast alum tail lights, but it now appears to be all over the body on both the exterior alum skins and the outside door trims.
A conversation with support in Jackson Center suggested that I lightly sand down the spots and apply clear fingernail polish to it. Do you know how bad my Safari would look after that given all the locations where this is??!!?? Asked what they felt was causing this because others also have seen this and I got no response.
If there are a number of us out there, perhaps it's time we grouped together. I can't believe a $50k RV (and in some cases, a heck of a lot more) is doing this at only 1.5 years old and is 10x worse now a 3.5 years old. Anyone know how to start a class action if there are enough of us??
Reason: Title is more appropriate to thread content
BTW, my unit is stored indoors in a somewhat climate controlled garage (barely gets colder than 38 degrees). It is outside maybe 3-4 weeks a season. It is washed and Walbernized 2x a year and all bug and bird droppings are quickly washed off. The Safari does not sit on bare concrete and has not been abused in any way FWIW.
I feel your pain, Eric. It's bad when I feel it is inevitable with my unit. It's got to be daunting to apply clearcoat to complex shapes with seams, rivets, pebble dings, etc. I know Jack Canavera has mentioned his solution several times: Clearcoat peeling on my '02
Proved it to myself by using the search -- There are many hits if you search on the word filiform.
BTW, my unit is stored indoors in a somewhat climate controlled garage (barely gets colder than 38 degrees). It is outside maybe 3-4 weeks a season. It is washed and Walbernized 2x a year and all bug and bird droppings are quickly washed off. The Safari does not sit on bare concrete and has not been abused in any way ...
With what you have outlined, the only thing left to do is to vacuu-seal your Airstream in a giant seal-a-meal bag between trips.
FWIW, filliform corrosion, in my opinion, starts from assembly stresses at the factory. Once ALCOA's clearcoat is breached, the clock is ticking. Unless oxygen can be kept away from the affected areas, corrosion will result.
The vintage way of spraying clearcoat on everything after assembly appears to last longer. In all fairness, this method had its drawbacks though.
I had the filiform corrosion on my taillights and door hinges, entry handle as well as many areas of the "beltline" area. The dealer has a procedure for the recoating of the cast pieces (and they look fantastic might I add). As far as the miscellaneous rivets pieces and beltline areas the warranty fix was to add the classic lines extruded aluminum beltline trim to my Safari. It looks better than I thought.
I have a new "white worm" coming out from under the ventline vent cover that I am going to try to use the clear coat touch up on.
How far will the corrosion go, that is my concern.
The exp with my unit suggests that it will become more and more widespread all over the unit. I too have it on the beltline as you do. Problem is adding that trim piece only masks the issue. Eventually you may find that the white lines grow beyond that cover up piece.
I owned a 03 Bambi and it didn't have this issue, but this '04 is now everywhere...started small like yours and it's clearly expanded.
I really am serious about a class action lawsuit thing if there are enough of us. If it's just a handful of us, I suppose I'd caulk it up to hey, it happens, but if there are dozens upon dozens, upon dozens of us out there with the same problem, we shouldn't be silent and we should just take this on the chin because then, clearly there is a problem with either the manufac process or, a problem with the finish. I don't know, but since Airstream built the thing, it would seem like they own the problem.
Everywhere my Safari has been, one of 2 cars have been there with it. Acid rain, etc would have shown up on either tow vehicle. No salt. Trailer was even delivered before it snowed here, though it did see snow after it was built and delvered to the dealer in Ohio. After that, the unit has not seen snow and has been kept indoors all winter, only coming out long after the salt is gone.
Cleaning consists of Armor All Car Wash and Walbernize 2x a year. The same stuff I used on my 03 Bambi for about a year.
If it is just a handful of luck folks like me, then there isn't much of a case, but if enough folks come out and say, yea, I have that, then maybe, just maybe there is a case here.
The corrosion is rampant on our unit. It appears to be a faulty product and nothing is being done about it except Airstream continues producing the same product. A class action may bring an end to this. When people ask what it is I tell them and it is a problem with Airstream and their skin. Don't buy one.
I'll check mine and post the results. Off the top of my head, the corrossion issues I've seen are the license plate light (requires frequent waxing), the Safari emblems seem to need frequent applications of WD40 to slow corrosion, the top of the rear bumper displays some deterioration, the wheel well mouldings have some crazing or checking, the clearance light screws are rusty. I have not noticed the corrosion lines starting at the rivets or edges of the aluminum panels. My trailer has been parked outside for over two years about 14 miles from ocean. I have only used this trailer for 2 nights of on the beach camping. The only wax product I've used on it is Meguiar's Quick Detail (except for rubbing out scuff marks).
Speaking of anodes, etc. the trailer is powered off electrically when not in use.
If I start to see this issue on mine, my first thought will be to try some kind of penetrating oil such as the aerospace protectant or WD40 on the nearby rivet. Not to improve the damage but to attempt to stop the progress of the corrosion.
Ok, so we have 4 possibly 5 so far. I know Dmac has the issue too, so we then have 5, possibly 6. Anyone else, please add your name to the list.
Lewster, I'm not sure where these little tidbits come from but I seem to remember from my marine days that multiple smaller anodes will do a better job than one big one. Again this is coming from memory and mine is good...just short for the most part.
Twinkie, shutting off the electric will not stop galvanic corrosion. This is caused by dissimilar metal contact.
I like the idea of a couple of sacrificial anodes in out of the way spots.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom & PuttLab
"I'm not an expert. But I did sleep in an Airstream last night."
I have a 'fix' for your rusty marker lights, and it is NOT expensive either!!
__________________ Lew Farber -Certified Master RV Tech (currently on Forums sabbatical) WBCCI #1456/VAC (assoc) #1456 AIR # 10325 CHARTER MEMBER: FOUR CORNERS UNIT
