Old 09-28-2014, 02:14 PM   #1
Clearance between trailer and TV
I'm planning on purchasing a Classic and want to decide on the tow vehicle (pick up truck). Is there enough clearance so that I could leave the tailgate down in order transport longer items? Any advice you can give is appreciated.
jmeissner is offline   Reply With Quote
Old 09-28-2014, 02:21 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
A Hensley/Propride hitch extends the space between AS and truck to put the tailgate down, but you would still be limited with tight turns.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-28-2014, 02:35 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, it depends on the stringer used. Not going to recommend any specific brand. Plenty of fan boys here to do that.
MICHAEL
Old 09-28-2014, 04:28 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
You cannot travel with the tailgate down. The shank would have to be 2' long.
I can open my tailgate all the way while parked straight, but traveling has turns. When you turn, your tongue jack and propane tanks get closer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-28-2014, 04:34 PM   #5
dznf0g's Avatar
Oswego , Illinois
Especially with a PPP hitch. On turns, they swing to the side and forward, shortening the effective distance between TT and TV.
a much longer shank/stinger would allow this, but is detrimental to sway stability. I, personally, would not consider it. If you need a long bed PU, get a long bed PU (8').
-Rich-
Old 09-28-2014, 04:35 PM   #6
m.hony's Avatar
2013 30' Classic
See?
Name:	ImageUploadedByAirstream Forums1411943487.681312.jpg
Traveling with the tailgate down would result in damage to the tailgate, tongue jack, and propane tank cover.
I have a really long shank, but that is not the purpose of the long shank. The purpose of the long shank is so you can turn the steering wheel all the way in a turn and the weight distribution bars will never get into your bumper. For safe handling and proper weight distribution you want the shank as short as possible.
TAC #MS-10
Airforums #70955
Old 09-28-2014, 04:42 PM   #7
m.hony's Avatar
2013 30' Classic
If you want to haul long items in your pickup bed, get a 6 1/2 or 8' bed, not a 5 1/2' bed like mine.
TAC #MS-10
Airforums #70955
Old 09-28-2014, 05:13 PM   #8
Thank you all very much for your input. I really appreciate it! Now I know what to do.
Old 09-29-2014, 05:04 AM   #9
m.hony's Avatar
2013 30' Classic
Use the Pythagorean theorem to determine how long an item you can get in the truck bed diagonally-
TAC #MS-10
Airforums #70955
Old 09-29-2014, 05:14 AM   #10
1981 31' Excella II
New Market , Alabama
Get a pickup with an 8 ft bed (AKA real truck).
Perry
How important is relationship between vehicle weight and trailer weight? DC Bruce Tow Vehicles 51 07-19-2014 02:12 AM
Equalizer and Tailgate clearance questions for new TV and trailer Westfalia Hitches, Couplers & Balls 15 05-31-2010 07:00 AM
Difference between Dry Weight and GVWR wacnstac Towing, Tow Vehicles & Hitches 6 04-05-2006 07:29 PM
Gap between floor and shell tmcdougald Repairing/Replacing Floor &/or Frame 4 07-19-2005 05:44 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
