Old 01-31-2019, 08:26 PM   #1
1996 34' Limited
Aberdeen , North Carolina
City Water Not Making it to the taps/shower/toilet...
Okay.....yesterday the water worked, today it doesn't. I didn't move the trailer, hoses, etc., and yet no water. Any suggestions? It's a 1996 Classic 34 with side bath...
Thank you,
Lara
Lara_From_NC is offline   Reply With Quote
Old 01-31-2019, 08:40 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Frozen hoses? Disconnect the hose from the source, to see if water is running out of the hose bib.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 02-01-2019, 03:05 AM   #3
Long Island , New York
Welcome to the forum, Lara!
Depending on the lowest temperatures of the last few days, and the steps you took to protect the AS from freeze damage, you could have a variety of problems, I am sorry to say.
What have been your low temps, and what winterization steps did you take?
Good luck,
Peter
Old 02-03-2019, 04:56 PM   #4
1996 34' Limited
My apologies for the lack of background data.
1. Temps didn't get below 40F.
2. This is the second time this has happened in the past month. First time it was the day we were leaving a campground; when we rehooked the water up it worked (drove ~60 miles, mostly expressways).
3. This time I leveled the trailer (lowered the nose a bit).
I'm wondering if a check valve has an intermittent fail.
Thank you,
Lara
Old 02-03-2019, 05:11 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
That sounds about right. The spring maybe getting old and going cock-eyed as the water hits it, causing the plate, (that's what i call it) to stick. Release the pressure behind it, give the valve a good tap and try again.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 02-03-2019, 05:17 PM   #6
1996 34' Limited
So I should tap the valve? Time to break out the massive AS manual and locate said check valve....after taking pressure of the valve first.
Thank you,
Lara
Old 02-03-2019, 08:17 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The check valve (if original) is built into the water inlet in a 1996 34'. You can see this in your manual. Look at the schematic drawings on sheets F18 and F19.
https://www.airstream.com/wp-content...-manual-82.pdf
I've had sand and debris build up inside the pressure regulator and block water flow.
Another possibility: Have you drained and flushed the water heater? This should be done each year. Scale and debris can build up inside the HW tank and then get pushed out into the plumbing pipes, valves, and screens, stopping water flow. Remove the aerator from the kitchen and lavatory sinks to clean the screens. The same with the shower head.
Alan
Old 02-05-2019, 11:59 PM   #8
1996 34' Limited
Again, thank you for your advice and knowledge. It's been a busy few days here, but tomorrow is the day I'll attack this issue in earnest. I'll let you know how it goes.
Thank you,
Lara
Towing with a 2015 F-150, 5.0L V8, with tow package; I'm maxed out but not over gross....uphill at 30 mph isn't bad, downhill can get exciting....
Retired C-130 navigator....gosh I miss flying!!!!!!!
Water available at shower and toilet but not at sinks. nantank Plumbing - Systems & Fixtures 2 02-14-2018 03:02 PM
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
still no hot water at the taps the welshman Water Heaters, Filters & Pumps 8 01-20-2008 12:07 PM
Kitchen faucet taps needed michael foster Fresh Water Systems 4 01-13-2008 05:37 PM
