Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 02-25-2004, 02:42 PM   #1
jaco's Avatar
Profile:
Question Calling all 70's decade(70-79) EXCELLA 500 owners
I have a 1974 Excella 500 and have found very few other owners of my model. (There are 2 on this list that I have seen).
It is very frustrating!
The 1974 Airstream Service Manual (blue soft cover, 296 pages) that I have (original) shows all the models of that year...but no mention of the word Excella. Of those 296 pages probably less than 100 apply to any particular model. It is an all inclusive style minus the Excella. The manual was actually printed in 1973 which of course is when the 74model is actually started in production.
I first thought that maybe the 74 was the first year for the Excella 500 and that perhaps it was not concieved til after the printing deadline....but obviously 74 is not the 1st as otheres have posted here about prior Excella 500's notably a 71 I recall.
I have used the manual often since much of the data is the same for certain parts and accessories. The diagrams for the 31ft rear bath Sovereign model are what I must use and most are identical in most respects, but not All.
There is an 1974 Excella 500 Owners Manual (brown hardback, 72 pages, copyright 1974).It's not very repair useful , mostly vague use instructions.Still glad to have it.
I have also found and downloaded a copy of a 1974 Airstream Sales Brochure
http://www.batmo.com/tclife/original/brochure/home/
Amazingly there is no mention of Excella in the brochure. All other models are there.
There are numerous remarks scattered thru forums that a big change took place sometime in early 70's. Best I can tell either in 73 or 74 or maybe spread across several years. (Changes involve axle rubbers, floor channel shape, grey water tank, frame weakness, & perhaps more). Accuracy of most of these claims is unverified and some could be just rumors.
Do any of you have the 1970,71,72,73,75,76,77,78 or 79 service manuals?
Does it cover all models like my 74 manual? How many pages?
Is an Excella model in it?
There of course is an answer to the Excella Mystery, but I haven't been able to solve it. I suspect that percentage wise there are fewer of them (us) around, due to lower production numbers, but this is just a guess. Any 70 era Excella info would fill a void in this and all the forums that I have explored.
Any help or thoughts or ideas or complaints welcomed.
jaco is offline   Reply With Quote
Old 02-25-2004, 06:33 PM   #2
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I have not only a '77 Excella Service Manual but I also have a large dealer '77 Service Manual that has each page coated in some type of protected material. Both have 13 chapters covering areas of the trailer but the dealer manual is twice the size of the other manual and has more material.
The dealer Service Manual has a section at the end of some of the chapters that is specific to the Excella such as Brakes, Chassis, Electrical, etc.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-25-2004, 09:21 PM   #3
jaco's Avatar
Profile:
David I was meaning to PM you. After I posted the above I searched and found a thread about manuals that had almost the same questions that I asked, by another 74 owner, Hex. I see him post at VAC sometimes and plan to try to contact him thru there.
I also saw your reply there mentioning the Dealer book.
I am trying to establish whether my 74 has much or anything in common with your 77. If so I would pay you to copy that manual for me. Would you consider that?
I need details about a telescoping pocket door and the hose reel assembly as well as other items. My Armstrong AC apparently is from another year. At least the shroud does not match the one Inland shows for 74, so I don't know whether the AC is off or whether the wrong shroud has been placed over it.
While searching I found another 74 Excella owner in Mississippi but he quit posting 2 years back also. But in his last few posts he decided his Excella was a 79 instead of a 74 my luck. Seems 74 Excella owners vanish off this list like Whitewater FOBs in Little Rock did.
Old 02-25-2004, 09:35 PM   #4
davidz71's Avatar
jaco,
Sure, I would consider it. It does show the parts list and pictures of the water and electrical reels just fine. I had to repair a water leak in the line coming from the water reel because there is a 90 degree filling that froze and had to be replaced. I had to go in through the streetside wardrobe closet, remove drawer tub, and interior plastic wheelwell coverings to get to the fitting. After replacement I insulated it with stuff you fit over pipes since there is no insulation in that part of the trailer.
Look at my photos and compare your Armstrong shroud to mine since it is original. Andy's do not appear to have the screens in them and maybe that is what makes it appear to be different, I don't know.
The accordian shower door is shown in the manual also. Let me know what you want to do and I will try to help.
Craig
AIR #0078
3.73 rear end
Old 02-25-2004, 11:16 PM   #5
startrekker2001's Avatar
Profile:  1978 31' Excella 500
Palm Bay , Florida
Images: 34
1978 Manuals
Send me your snail mail address and I will send you the 78 Excella owners and service manuals on CD. They are in .jpg format so they are viewable on any PC. There is no charge for the manuals or the shipping.
Vic
Vic Smith
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 02-26-2004, 07:30 PM   #6
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
jaco,
I know what the problem is...you need a 1975 Service Manual! I quote from the "Foreward"( I'm not kidding either) "This manual includes illustrated parts lists,.....for Airstream 21, 23 T& D, 25 T & D, Land Yacht, and 27 T & D, 29 T & D, 31 T & D, International Rear Bath and Center Bath models and the 1974 Excella " It has the floor plans, the information on the electric reels, etc. BTW I have a 1975 if you need a couple of scans, email or PM me. Eventually I plan to put the whole thing into PDF.
Aaron
WBCCI #2449 AIR #2495
Old 02-27-2004, 12:56 PM   #7
davidz71's Avatar
Well Jaco,
You can't ask for more help than that can you? The forum comes through again.
Craig
AIR #0078
3.73 rear end
Old 02-27-2004, 03:20 PM   #8
jaco's Avatar
Profile:
Wahoo that is great news. I will be in touch, but first will attempt to score a complete Manual to at least look at.
That is really strange that it was done that way. You did not mention the 1975 Excella 500 (which is not my problem yet) but I just wonder if it is described only in the following years 1976 manual etc.
But my 74 manual says nothing about any Excella not the 73 or the 74. We need someone with a 73 Service Manual to check and post in.
My Excella has a build date of April 74. I now wonder if the Excellas were not produced til later in each model year. Model year being approx Sept - August.
I remember that Chevy and GMC trucks used to come out with a special "limited" model only about halfway into the model year. The GMC was called the Royal Sierra and I cant recall the name of the Chevy clone maybe Royal Cheyanne or some such. Now of course the truck makers have more "signature" special models than I can keep up with.
Don't know if the Excellas were considered "limited" (available only within a short window of time each season) models or not.
I'll stay on this mystery and hopefully someday these type of factoids will help others.
DavidZ71
you bet this discussion group comes thru more times than any other I think. However the guy Hex, that originally asked a very similar question way back never seems to have gotten this answer. I hope he sees this if he still cares.
One problem here is that the posts that are pushed off the forefront too soon might get missed by a fellow with the answers.
Don't know the alternative to that yet, but I am soooooo happy that Wahoo found this thread.
Old 02-27-2004, 03:36 PM   #9
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
jaco,
Forgot to mention my Service Manual has 361 pages in it
Best I can tell the Excella shares most of the systems with the International with the exception of the obvious up grades like the power reel, water hose rel and the second sliding door. Does yours have the "Dishmaster" and the Vacumn?
Aaron
Old 02-27-2004, 03:42 PM   #10
markus's Avatar
Profile:
73 service man checking in ~
My 73 service manuals "forward" is just like
Wahooncs' except it has no mention of a
Excella at all. Not any were in the manual
does it even mention the word.
My 31 international is also an early model,
it did not come with a grey water tank, I believe
that was added latter in the year.
hope this helps.
~mark~
markus is offline   Reply With Quote
Old 02-27-2004, 03:53 PM   #11
jaco's Avatar
Profile:
Wahoo
Mine has the vac, which is just unnecessary fluff IMO but if it had the Dishmaster (which I would love) it has been removed.
The front sliding pocket door is a nightmare. It actually telescopes into itself as it is pushed back into the pocket. The female section is jammed and I cannot re insert the male which gives me about a 14 inch hallway entry. I have spent hours trying to figure it out. Of course could yank it out in a heartbeat, but am determined to not damage it.
You did not say whether the 75 Excella is also shown in your 75 manual. Is it?
What color is the cover on your manual? (is it original or a copy)
Is it Spiral Bound with a plastic comb?
Markus
Thanks for the post. Now I wonder if there was a 73 Excella 500?
Old 02-27-2004, 05:13 PM   #12
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Originally posted by jaco
Wahoo
jaco,
My manual does not mention a 1975 Excella, just the 1974. It has a blue cover, and is plastic comb bound. It orginally had a blue comb, but it was in such poor shape I had to redo it. I re did the owner's manual at the same time. It was a glue binding.
Aaron
Old 02-27-2004, 05:34 PM   #13
RickStream's Avatar
Profile:
1974 Excella
I have an Excella from 1974 and will help with this subject when I can!
Rick
RickStream is offline   Reply With Quote
Old 02-27-2004, 06:31 PM   #14
davidz71's Avatar
jaco,
Not long ago I posted a question on electrical disconnects so that I could disconnect my portable 20 watt solar panel from the battery system before getting underway. Several forum members gave me some suggestions, which I checked out but they weren't quite what I imagined.
I had hunted the internet before posting then tried again. I finally ran across exactly what I needed. I posted my findings so that it might help someone in the future if they were thinking the same thing and did a forum search.
Craig
AIR #0078
3.73 rear end
