Old 12-16-2018, 02:11 AM   #15
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
A Ford Transit or Mercedes Sprinter work very well for carrying a bike. The load height is much lower than a pickup. The bike is inside out of the weather. Either van rides and handles better than a pickup. The diesel models get better fuel economy as well.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-16-2018, 05:54 AM   #16
2012 19' International
Southeastern MI , Michigan
I’d have my wife drive the rig, and I ride the Harley. Problem solved ��
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 12-17-2018, 06:33 PM   #17
2019 25' Flying Cloud
Hendersonville , North Carolina
Towing with a Ford Transit van
The towing ratings on the Ford Transit vans are very low. I checked these out prior to buying a 2013 Ford E150 XLT Premium van with factory tow pkg to pull a 2017 23D. My van is the old style with full frame, 5.4 V8, ect. The tow rating of the T150 Transit wagon (van with factory interior, not a cargo style) is less than 5k LBS. The T250 and T350 are not much better. I went old school because those vans are good to tow with. V10 engines and 6.0 diesel were also available. I am sure the Transit van probably drives nicer when not towing, but the rating was just not enough for me. Transit vans do not have a full frame like the E series vans.
uraljohn is offline   Reply With Quote
Old 12-18-2018, 10:50 AM   #18
1975 27' Overlander
gurnee , Illinois
Originally Posted by suncoasteng View Post
Too much work and too much weight. Let alone the potential for personal injury getting the bike out of the bed of a truck. Just take your bicycles for short trips, then rent a Harley when you get to a destination!
Unfortunately, this is probably the best answer. If your a HOG member you get a large discount on a rental.
75Bob is offline   Reply With Quote
Old 12-18-2018, 11:45 AM   #19
Glock22
2003 25' Safari
Ridgeville , South Carolina
Thank you
I love this site and everyone who took the time to reply. It makes me feel better to know others have struggled with the same dilemma. I will likely go with a used Loadall loading system in the back of the truck. And although I might try it cautiously a few times in my F150, I see a 3/4 ton truck in my future (you're right, she is heavy). I had a Kawasaki Versys that was so easy to load. I think a cover over her when she's sitting at the campsite will keep her happy.
I have read all of your posts multiple times and our local HD dealer has quit renting motorcycle and I'm hearing/fearing other places will be doing the same thing. I was trying to convince the wife I needed a lighter HD to take on trips and she was not so receptive
Much thanks, to all of you
Ron
Ron & Tina
05 F150 5.4
03 25' Safari
RManchester is offline   Reply With Quote
Old 12-18-2018, 12:21 PM   #20
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Originally Posted by Nightmare67 View Post
Here’s how I do it. (Just ignore that road runner. He’s been following me for weeks)
Load-all ramp system. Long and short bed ramp designs.
Link to a video I made showing how it works. Fast, safe and easy.
https://youtu.be/zgrQhVTiDoU
Nice video!! Looks like a great solution.
10Smiles is offline   Reply With Quote
Old 12-18-2018, 12:33 PM   #21
1975 27' Overlander
gurnee , Illinois
Now that's using your head
Old 12-19-2018, 09:18 AM   #22
2018 25' Flying Cloud
Key Largo , Florida
Hauling a harley
We use a Mercedes Sprinter 3500xd with a towing capacity of 7500 lbs (4x4 diesel dually) and tow a 25 ft flying cloud, (our23 ft flying cloud was totaled in a hailstorm 6-14-2018)
I use a ez riser 3-piece aluminum ramp and haul a Harley Softtail, My wife and I full time as of Aug. 3rd 2017.
I am maxed out on my GCVW but have had no trouble putting 35k miles on the rig. I can safely ride into and back out of the sprinter and the whole process adds little time to standard set up procedures in campgrounds and my bike could not be more secure.
We went from a 16,000 lb fifth wheel to a 7,300 lb airstream and would do the same, if we had to do over, Best Decision we could have made for our philosophy of use.
A Design 4 Living on youtube.
FLOmads is offline   Reply With Quote
Old 12-19-2018, 09:43 AM   #23
steelbird312's Avatar
1956 22' Safari
2013 31' Classic
Crossville , Tennessee
Images: 11
Dont do it!
Now that I gave your attention, I, too, worked through this samw situation years ago. SUMMING up, I now gave a Duramax HD wirh winch powered carrier to load thw FLHTCU.
The 1500 will make you think everything is great until you get several hundred miles from home, and you're overloaded rear tire or tires pop! Not funny. A 2500 or larger truck is pretty much required, a good load distributing hitch required (most factory hitch receivers are mush) to distribute load to the front axle. E rated tires, max speed at 70 with normal at 65 to prevent heat buildup and allow for evasive actions during emergencies is wise.
I have done this exact thing towing 31' Airstream many thousands of (happy)miles with no regrets. Common sense prevails- if in doubt, dont do it!
steelbird312 is offline   Reply With Quote
Old 12-19-2018, 09:45 AM   #24
1970 25' Tradewind
Chicago
I have a medium roof Transit 250. Have the 3.5 eco boost get cargo version with drivers side door. 6900 lbs towing. Use 2 ramps for loading. One to walk and one for bike. Can’t tell my Tradewind is behind.
Madmarke007 is offline   Reply With Quote
Old 12-19-2018, 09:45 AM   #25
SailAS's Avatar
2007 25' Safari FB SE
Sugar Land , Texas
I have several bikes and ALWAYS take one with me when I drag my 25 FB Safari. My BMW and my Harley are about the same weight but the truck handles two bikes & the trailer quite well but then I have an F350 SRW diesel.
I use a power loader that I built out of a surplus Uhaul loading ramp ( good for 2500 lbs with a couple of rails mounted in the bed ( with rollers like they use for moving material in warehouses). I mounted a Harbour Freight 5,000 lb winch in the front of the bed and simply put the bike in a wheel choke mounted on a "dolly" that rolls up the ramp. Then pin the dolly to the ramp and winch the ramp into the back of the truck.
It cost me a bit over $500 for the whole rig and works great.
I think you'll be a bit "over limit" with a F150 but a 3/4 ton would do the trick.
Also here in Texas ( and in some other states) you can tandom a trailer behind the AS.
Cheers, D
Dwight & Ellen + (the Beagles)
2011 F350 SRW King Ranch, 6.7L, 3.55 ELD, Ranchos, Hellwig w/ Reese Dual Cam & 1200# bars. 2007 Safari 25 FB SE (stock - well sort of)
SailAS is offline   Reply With Quote
Old 12-19-2018, 02:36 PM   #26
Blog: ameliaairstream.com
perri's Avatar
1970 27' Overlander
Fillmore , USA
Kris and kimmie towed their massive, heavy Avion to tour Alaska (from Los Angeles). They have a big diesel pickup and use a ramp and a winch (behind the cab?) to take their motorcycle with sidecar along, on a platform in the bed, under which they stow the ramp and more gear. I don’t know if they’re on this forum; doubt. They take the moto-sidecar with them often when they camp.
perri is offline   Reply With Quote
Old 12-19-2018, 05:49 PM   #27
USNA79
2018 28' International
Clayton , North Carolina
Originally Posted by GMFL View Post
Going to be tough to put that bike in the bed of that F150 and then pull that 25’ trailer. A 3/4 ton would be in order.
P.S. I’m not trying to be the 3/4 ton truck guy. It’s just the payload of that 150 will be beyond maxed.
My calcs show a F150 with max payload set up can handle my 900 lb Indian, 200 lb winch based loader, tongue weight of 28ft AS, and 600 lb of people and gear. Am I missing something?
Tmdumbauld is offline   Reply With Quote
Old 12-19-2018, 05:58 PM   #28
USNA79
Any problems/concerns with raising the CG of the bike by the height of the loader deck?
Harley Airstream, West Coast Choppers Colonial Airstream Commercial Listings 42 01-16-2015 04:02 PM
Will a Harley Davidson Dresser fit in a BaseCamp? rickdesign Base Camp 11 02-04-2011 10:22 AM
Jay Leno, Harley Davidson, American and Airstream wheel interested Our Community 11 05-29-2008 04:04 AM
Off the Harley...and, into a Silver Bullet! Chief Member Introductions 9 08-01-2007 04:56 AM
Airstream/Harley dealer in NH Barbara Peerenboom Commercial Listings 17 11-13-2004 05:50 AM
