Old 02-28-2016, 08:15 AM   #1
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Batteries not Charging
Began intermittent trouble yesterday with jack power. Was on shore power for a night after 5 hours on the road. Batteries are dead but water level in both are fine. I'm stumped.
2 x Interstate Deep Cycle SRM-24
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance, Equalizer 1000, pulled by a 2018 GMC Sierra 1500 SLT 4x4, Crew Cab, 5.3L V8 ECOTEC3, 3.42 axle, 8 speed auto WBCCI #6111
beachbouy is offline   Reply With Quote
Old 02-28-2016, 08:18 AM   #2
1974 Argosy 20
Kooskia , Idaho
Did you have the USE/STORE switch in USE when you were plugged in overnight? That is necessary to charge the batteries.
Old 02-28-2016, 08:22 AM   #3
Displaced Beach Bum
beachbouy's Avatar
At this point I cannot honestly answer... I do not know.
Old 02-28-2016, 08:57 AM   #4
Displaced Beach Bum
beachbouy's Avatar
Shouldn't the jack operate when the AS is plugged into the running TV?
Old 02-28-2016, 09:45 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Your jack positive cable is directly connected to the batteries, so if your batteries are dead, the jack will not operate.
As for the TV, it depends on how much current is coming thru the umbilical to the batteries.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 02-28-2016, 03:00 PM   #6
Displaced Beach Bum
beachbouy's Avatar
OK... Connected to shore and batteries read just fine... fuse by battery box fine.
Old 02-28-2016, 03:46 PM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
So is it just the power jack that's not working?
If so, they do fail. My motor died on our 5th night, when it was less than a month old.
SeaLevel is offline   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 08:12 PM
Coach batteries not charging jdgreen227 Batteries, Univolts, Converters & Inverters 0 08-10-2009 04:00 AM
Batteries Not Charging With Generator timkim Batteries, Univolts, Converters & Inverters 5 08-09-2009 06:30 PM
Batteries not charging while driving wildwoodrver Electrical - Systems, Generators, Batteries & Solar 36 08-22-2008 05:33 PM
Motor Home batteries not charging myfirstrv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 17 06-20-2008 10:58 AM
