Old 07-16-2004, 06:55 PM   #1
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Airstream VIN Translator
I originally posted this on a thread about motorhome production numbers. But then I realized that this translator should work for all post 1982 trailers and motorhomes so I reposted here:
I was inspired by this thread [motorhome production numbers] and decided to create a little .NET web application called the "Airstream VIN Translator". It will translate the Airstream VIN for your MH or Trailer (1982 or newer) for you. Just enter in your number and click the "Translate" button.
You can try it out at: http://216.26.139.91/AirstreamVIN/AirstreamVIN.aspx
I translated mine and it's pretty accurate:
1A9BGAU3XGJ010705 Translates to:
Mfg, Make, Type: Airstream Class A Motorhome
Type: Corner Bath, Modern Design *10/1/01
Series: Motorhome, Front Gasoline Engine, Chevy
Body Type: Semi-monocoque, 96" narrow body, continuous curved, shiny aluminum Shell, contoured window glass, fames and doors
Length: 34’ to less than 35’
Axle Configuration: Triple Axle
Check Digit: X
Model Year: 1986
Site of Manufacturer: Jackson Center, Ohio
Sequential Number: 010705
Try it out....it's fun!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 07-16-2004, 08:36 PM   #2
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
Cool ASP .Net App!
That is very cool! I'm learning Visual Studio .Net (and ASP .Net) and can really appreciate the effort that you put into your program! Keep up the good work!
Curt
somefun is offline   Reply With Quote
Old 07-16-2004, 10:21 PM   #3
JohnG's Avatar
Nice tool.
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-12-2005, 01:44 PM   #4
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Just found this old thread - way cool link!
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-08-2006, 06:03 PM   #5
noiva's Avatar
Chesapeake , Virginia
Images: 46
VIN Translator
Below is what I got with the Airstream VIN Translator:
Everything looks correct, except the 370LE was only built with a FORD engine and transmission. The rest of the info. looks good. Also, the sequential number fits with those already posted, i.e. 11220 fits right in between the previous years and the '90 model on the list.
Tim
Type: Center Bath, Split
Body Type: Semi-monocoque, 96” wide body, continuous curved, painted aluminum shell, contoured window glass, frames and doors; double door.
Length: 36’ to less than 37’
Check Digit: 0
Model Year: 1989
Sequential Number: 0 11220
noiva is offline   Reply With Quote
The Agony And The Ecstasy Of Airstream Ownership - 2004 Classic flyfisher 2001 - 2005 Classic 33 07-27-2005 06:45 PM
2005/2006 International Rallies Over59 WBCCI Rallies & Events 21 06-24-2004 10:55 AM
Where do you shop for Airstream stuff? cwbastian Commercial Listings 4 05-16-2004 01:30 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
