Old 05-02-2012, 05:12 PM   #1
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
Airstream Bike Rack - License Plate???
Needing a means to travel with bicycles, we have decided that the Airstream Bike Rack is the best compromise. It is light weight and well fastened to the rear of the trailer. (See Airstream web site).
The problem: bikes may obscure the license plate - especially if we use canvas bags to protect bikes from road grime and water. So, what to do with the license plate? I guess we can put it on the bumper, but don't most states require plates to be lighted at night? Airstream does not seem to have addressed this, with the otherwise-very-well-done bike rack.
What have others done?
Charlie
aircampr is offline   Reply With Quote
Old 05-02-2012, 05:43 PM   #2
tdmaymac's Avatar
2011 27' FB Flying Cloud
Moschelle , Nova Scotia
I'm taking delivery on one of these racks tomorrow. Thanks for the heads-up as I hadn't focused on what this might do to the display of the license plate.
tdmaymac is offline   Reply With Quote
Old 05-02-2012, 06:52 PM   #3
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
We have the rack and it seems to have pre-drilled holes (though they weren't quite perfect in our case, so we drilled another one) to mount the license plate to the rack itself. I hadn't considered the lighting issue, however…
KerriO is offline   Reply With Quote
Old 05-02-2012, 08:20 PM   #4
2005 30' Classic
Burlington , Ontario
I'd be surprised if any LEO really took exception to the license plate issue, but if you are concerned, it should be easy enough to remove the plate from the trailer and secure it to the rack and add a light.
I doubt I would bother until/unless I was stopped for it - but then, that's just me!
I carry our bikes on the front of our truck. I need to remove the front plate to install the bike rack.
When we have the bike rack installed, I just remove the front plate and carry it with me in the truck - been doing it that way for at least ten years!
Having said that I'll probably get a ticket this year!
Brian.
Old 05-02-2012, 09:11 PM   #5
dznf0g's Avatar
Oswego , Illinois
I wouldn't worry about it either. It's probable cause to pull you over, but who cares, unless you have open liquor or the bong is fired up, the LEO will probably just remind you that there is an ordinance to display you license plate.
I really doubt a ticket would be issued.
-Rich-
Old 05-02-2012, 10:59 PM   #6
aircampr's Avatar
Images: 21
OK, well I guess we will just see what happens. Maybe it is a non issue...
It would not be too hard to move the plate, but running wires for a light seems a bit much.
Thanks for the comments.
Old 05-03-2012, 05:53 AM   #7
2005 30' Classic
If you really wanted full visibility of the plate plus a light but no wiring issues, I'm sure you could easily rig up a little battery operated LED license plate light for night time driving
Brian
Old 05-03-2012, 07:29 AM   #8
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Is there any issue with obscuring, partially or otherwise, the lights with the bikes?
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 05-03-2012, 11:13 AM   #9
dznf0g's Avatar
Oswego , Illinois
That, I Suspect would be a bigger issue, as it affects safety. I could see tickets for that one.
I always used a bike cover on my old SOB, but the lights were far enough apart that they weren't covered. With the AS, I think it would've been a problem. That's why I went with the Arvika Tongue rack.
I just hate cleaning up the bikes when carried without a cover.
-Rich-
Old 05-03-2012, 12:01 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Attachment 157367
I can see that having the license plate obscured makes it more difficult to read.
I fail to see why that is unsafe. Something like not being able to record the number of someone fleeing the scene of an accident towing an Airstream with bicycles on the back is about the only issue that comes to mind. Strikes me as more of an administrational kind of thing.
I'm sure that you could get a ticket for it, depending on the mood of the officer.
Vaughan
Old 05-03-2012, 12:17 PM   #11
dznf0g's Avatar
Oswego , Illinois
You misunderstand...I was talking about the question from UKToad about covering the tail lights in this post. Previously I posted that the plate ISN'T an issue IMO. I agree with you completely.
-Rich-
Old 05-03-2012, 12:44 PM   #12
MrUKToad's Avatar
Chatham , Ontario
Going off track a little, in the UK the licence plate you have on the back of the trailer is a copy of the one on the car; trailers don't have a separate licence plate. But over there, the licence plate cannot be obscured in any way, as well as having to be lit, and neither must the lights be obscured. Using the bike rack in the UK you would be required use a 'trailerboard' like this The licence plate is usually a stick on model that goes between the lights:
I take vswingfield's point though, you're hardly going to make a run for it towing your Airstream.
I could claim that UK trailerboards are there so that Gatso speed camera can catch you, but trailerboards have been around much longer than Gatsos.
Old 05-03-2012, 12:46 PM   #13
MrUKToad's Avatar
Chatham , Ontario
Attachment 157367
That's gotta mess with the airflow over the front, eh? Still, it looks most impressive.
Old 05-03-2012, 01:00 PM   #14
Gainesville , Florida
Anyone living in Fl knows they can be pulled over for a burned out tag light . Be careful. Jim
