Old 02-08-2016, 12:39 PM   #15
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
I purchased a VmaxTanks AGM battery through Amazon:
http://www.amazon.com/gp/product/B00...ilpage_o06_s00
So far so good.
BambiTex is offline   Reply With Quote
Old 02-15-2016, 08:35 PM   #16
Ed Brownfield's Avatar
2015 28' Flying Cloud
Charlottesville , Virginia
Thank you to everyone who replied to my original post! I want to install the batteries that I finally purchase in the battery storage box that is mounted on the A frame by the LP tanks. I am confused as to whether to replace my wet cell batteries with AGM batteries or with another set of standard wet cell batteries. I store my 2015 FC in a storage facility with no electricity so slow discharging AGM's would be nice. I like the idea of no maintenance and the slow discharge that AGM batteries offer, the price of $250-$300 per battery is a deterrent. What should I do? What brand of either type should I purchase? Where do I get the best price?
Bald Eagle
28 Ft. Flying Cloud
2015 GMC Diesel
Charlottesville, VA
Ed Brownfield is offline   Reply With Quote
Old 02-15-2016, 08:54 PM   #17
2015 30' Classic
Pleasanton , California
I'd go with flooded batteries and either remove the negative battery terminal before storing your trailer or add a disconnect switch to make this easier.
Here's some recent recomendations for batteries.
On page 3 of this thread you'll find info regarding the disconnect switch if you're interested.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 02-15-2016, 09:09 PM   #18
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Upgrade Converter
Would recommend replacing the factory installed Parallax converter to a multi-stage converter. This alone will ensure that your batteries (AGM or flooded) last longer and provide peak performance. I just replaced the factory installed Interstates with AGM to include a new PD4655 converter. Next up... SOLAR!
tsunami is offline   Reply With Quote
Old 02-20-2016, 06:10 PM   #19
Ok fellow AS'ers here my newest dilemma in buying new batteries for our AS. Someone posted that Interstate Batteries and now carried at Costco so I went to Costco to check it out. I trust Costco but there is a difference in Costco Interstate Batteries and the ones that came with my AS. The two Interstate Batteries that came in by 2015 28ft. FC are Deep Cycle Marine/RV batteries and have the following information written on them - part number SRM 24, Marine Cranking AMPS 690, Reserve Capacity 140 the. The batteries at Costco say Marine RV/Fitment Code 13 Group Size 24DC, CCA 550, 140 Reserve Capacity. They only have a one year warranty vs. the two year warranty that the Interstate Batteries that came with the RV have and the Cold Cranking AMPS on the one that came with the AS are 690 CCA vs the ones at Costco which are only 550 CCA. I'm stymied and don't know whether to buy the ones at Costco (seem like a great value $73/each or go to an Interstate Store and purchase the exact same batteries like I already have at a much higher price. How much difference does 140 CCA make? One other difference is that my Interstate Batteries have Green label on them and the ones at Costco have a blue label. Can someone help me with this?
Bald Eagle
28 Ft. Flying Cloud
2015 GMC Diesel
Charlottesville, VA
Old 02-20-2016, 07:53 PM   #20
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Originally Posted by Rgentum View Post
One downside is that I didn't see how to install two Group 27s in the battery box that came with the trailer. Consequently, I mounted them in the storage area under the queen bed & rerouted the battery cables, which turned out to be a pretty simple job. I've removed the threaded rod in the battery box, which has now become an additional, if small, storage area.
I just purchased 2 new group 27s to replace my 24s (lifelines). Here is how you can install 2 group 27s in the standard battery box. Installing lead acid batteries inside the coach without external venting is a no-no (evening if they are sealed AGMs / maintenance free):
http://www.airforums.com/forums/f37/...on-133372.html
wulfraat is offline   Reply With Quote
Old 02-20-2016, 09:10 PM   #21
1986 31' Sovereign
Miami , Florida
Cold cranking amps are meaningless in a trailer application as you aren't cranking anything...
The reserve capacity is the same for both and that is the key number. If the price is right at Costco, I'd go for it.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 02-21-2016, 05:33 PM   #22
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
My local Costco sells Interstate Group 27 batteries for approx. $75 each --- but they are flooded, lead-acid, deep-cycle batteries; I've asked if they sell AGM batteries or can order them, & they don't & can't. The Group 27 batteries I installed under the bed were Group 27 sealed, AGM batteries, at approx. $200 each.
I fussed & fussed trying to figure out how to install Group 27s into my battery box, & at least with the Group 27s & the battery box I had, the only way I knew how to do it involved cutting off one or more of the top lips of the box, which I rejected; maybe others have a larger box?
I acknowledge that others have opined that installing sealed & unvented AGM batteries inside the trailer "is a no-no." To obtain further information on this issue, I did a Google search on "must AGM batteries be vented?" & found:
1.
The batteries do not have to be in a box but if they are, they should be vented as per ABYC recommendations. AGM's are SVR (sealed valve regulated) batteries.
Eric
10.7.9
A vent system or other means shall be provided to permit the discharge from the boat of hydrogen gas released by the battery.
10.7.10
Battery boxes, whose cover forms a pocket over the battery, shall be vented at the uppermost portion of the cover.
NOTE TO 10.7.9 and 10.7.10: These requirements also apply to installations of all batteries whether they employ removable vent caps, non-removable caps, are “sealed” or “maintenance free” batteries, or have pressure regulated valve vent systems with immobilized electrolyte (gel batteries).
Location of Batteries and Battery Charger (see ABYC E-10, Storage Batteries). Consideration should be given to the following:
- Adequate ventilation should be provided to the bank of batteries to limit the temperature rise during the charging. Sealed valve regulator batteries do allow escape of hydrogen gasses during overcharging; therefore, SVR batteries require the same precautions for ventilation as wet (flooded) batteries. During the charging process, fully enclosed battery boxes will result in a greater temperature rise than with an open battery box.
2. From http://batteriesbyfisher.com/agm-batteries
There are two primary types of VRLA batteries, gel cells and AGM. A VRLA battery (valve-regulated lead–acid battery), more commonly known as a sealed battery or maintenance free battery, is a type of lead-acid rechargeable battery. Due to their construction, they do not require ventilation, can be mounted in any orientation, and do not require constant maintenance. The reduced venting is an advantage since they can be used in confined or poorly ventilated spaces. They are widely used in large portable electrical devices, systems and similar roles, where large amounts of storage are needed at a lower cost than other low-maintenance technologies like Li-Ion.
3. From http://www.carquestprofessionals.com...q_myths.html#9
Never install any type of battery in a completely sealed container. Although most of the normal gasses (oxygen and hydrogen) produced in an SVR battery will be recombined and not escape, oxygen and hydrogen will escape from the battery in an overcharged condition (which is typical with any battery type).
For safety's sake, these potentially explosive gasses must be allowed to vent to the atmosphere and must never be trapped in a sealed battery box or tightly enclosed space!
4. From http://www.homepower.com/articles/so...-small-systems
Article 480.9 of the National Electrical Code (NEC) states that provisions for ventilation must be made to prevent the accumulation of explosive gases, but the NEC doesn’t go into the specifics. Under the NEC, sealed battery technologies don’t require venting. American Boat and Yacht Council (ABYC) guideline 10.7.9 recommends a sealed, vented enclosure no matter what the battery type. Some local electrical codes even require power venting of the battery enclosure.
A properly designed and installed power system with a modern, three-stage charge controller keeps hydrogen gas emissions to a minimum (as with your present system), and battery technologies like sealed lead-acid don’t gas during normal operation. But what happens when the situation becomes abnormal? A poorly programmed or malfunctioning charge controller can cause any battery to gas, and even “sealed” batteries have internal valves to release the gas and prevent a case from rupturing.
__________________________________________________ ____
Here's my situation:
a. Yes, I have installed 2 Group 27 AGM batteries in the storage area under the bed, adjacent to the front storage area accessible immediately in back of the old battery box & propane tanks.. These two areas are open to each other; the plywood that separates them only goes up partially to the top of the storage area, allowing air in the two areas to intermix. The front storage area is not sealed --- it is partially open to the outside. The storage area under the bed is also not sealed --- it is open on both sides to the bedroom area. Therefore, the AGM batteries are not in a "sealed battery box" & vent into both the interior & the exterior of the trailer
b. The two batteries are strapped to the floor & covered on their top by a cover (without sides) that is also strapped to the floor. The AGM batteries are not in a container, sealed or otherwise, so any discharge from them vents into the storage area, which is open to the interior of the trailer & partially open to the exterior of the trailer.
c. When I replaced the lead-acid batteries with AGMs, I also replaced the stock converter/charger with a 3-stage converter charger, specifically made in part to charge AGM batteries, to ensure no overcharging.
All in all, I remain unconvinced that given these circumstances, more venting of the sealed AGM batteries with no battery box is either necessary or recommended.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 02-21-2016, 06:49 PM   #23
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Installing a Progressive Dynamics 4655 and two 6-volt 220AH Lifeline batteries in series was one of the best upgrades I've done.
I believe it was Lester who recommended this years ago.
Not ready for lithium yet. I have found the Lifeline 6-volt configuration works well for our use.
Steamy1 is offline   Reply With Quote
Old 02-21-2016, 07:20 PM   #24
lewster's Avatar
Naples, FL , Hood River, OR
Rgentum,
You pretty much nailed it with the ABYC E-10 standards. Remember that these are written for the marine industry and the many enclosed spaces found on a boat, but I follow them as closely as possible, along with E-11, A-25 and A-31.
AGM batteries (I will address only Lifeline AGM batteries here, as they are the only ones that I install, other than lithiums) will typically only out-gas in extreme overcharge or over temp. conditions. Under normal charging situations with the use of a quality 3-stage automatic charger (and more specifically with a fully programmable inverter/charger with full temperature compensation), any gassing that is a normal by-product of proper charging is automatically re-combined into the glass mat material and does not open the one-way pressure release valve found on each AGM battery.
The only times I have seen this valve open is during prolonged over-charge episodes (above 15.5VDC for extended periods) or in extreme heat situations (ambient temperatures above 75ºC with no temperature compensation on the charge voltage).
I have placed many battery banks in similar locations to the one you are intending to use with no ill effects. You should have no issues.
Old 02-02-2019, 11:14 AM   #25
2019 27' Globetrotter
Sherwood Park , Alberta
I want to add another battery using this approach
Originally Posted by lewster View Post
Rgentum,
Hi, I see this an older post but I'm hoping to restart the conversation...
I have a 2019 GT FBQ with Solar. AS provided two Lifeline GPL-24T AGM batteries which are installed in the outside battery box on the A-frame.
I'd like the add another GPL-24T in parallel to increase the amp/h from 160 to 240. Can I relocate all three batteries into the compartment below the front bed? Any special considerations if I can do this?
Second question: Costco has a 'similar' AGM battery (78 ah vs. the Lifeline 80 ah) for about 1/2 the cost of the Lifeline... can I safely add that as my third battery?
Thanks all!
Omnial is offline   Reply With Quote
Old 02-02-2019, 12:59 PM   #26
SewStream's Avatar
Sanford , Arizona
Just curious...we have the same 2019 GT FBQ model...why would you relocate all three batteries? Why not keep two in the battery box and place the third in the front under-bed storage? We are considering adding another AGM battery, too. Look forward to hearing ideas/answers, thanks.
SewStream is offline   Reply With Quote
Old 02-03-2019, 01:38 PM   #27
Hi SewStream,
I posted a similar question here: http://www.airforums.com/forums/f449...ry-191765.html
Basically, I'm looking at installing new solar MPPT charge controller, battery monitor/shunt, cutoff switches, breakers, etc. Eventually I want to replace the AGM's with lithium.
So why relocate all batteries under the bed? 2 Reasons:
1. Since I'm doing all of the reconfiguration/rewiring anyway, and I'll want my lithiums stored inside for security reasons I may as well relocate the AGM's now and be done with it. Then when I get my lithiums I can just swap them out with minimal fuss.
2. It's my understanding that it's best to keep the jumpers between the parallel batteries all the same length, which I won't be able to do if 2 are outside and 1 is inside. Also, I understand it's best in a parallel configuration to have your sources connect to 'opposite corners' of the parallel bank. For example, connect the Positive source/load to the positive post on battery 1 of the bank and the negative source/load on the negative post of battery 3 of the bank. This will be easier if all batteries are nicely located in a row. A side benefit is moving some of the battery weight closer to the axel, away from the tongue, since the tongue weight is already high.
Having said all of that, I'm no expert and am just going by what I understand from reading the forums.... please feel free to enlighten me, everyone!
Old 02-04-2019, 09:41 AM   #28
Ayr , Ontario
Thanks all!
From the lifeline manual
Name:	2-4-2019 11-40-04 AM.png
gator.bigfoot is offline   Reply With Quote
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 05:35 PM
AGM Batteries? Boondocker Batteries, Univolts, Converters & Inverters 33 06-03-2007 06:23 AM
Cabelas AGM batteries wacnstac Batteries, Univolts, Converters & Inverters 26 10-13-2006 07:22 AM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
