Old 05-18-2014, 01:01 PM   #1
2014 25' Flying Cloud
Orinda , California
25 Foot 2014 FC steps for flushing and emptying black water tank
We are on our first trip with our new AS. We want to make sure we empty the tanks thoroughly and properly to avoid any odor. Can anyone recommend a step-by-step guide? Our manual doesn't offer much info.
Thank you.
Enjoy your streamers
DogGonnit is offline   Reply With Quote
Old 05-18-2014, 01:11 PM   #2
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
Empty the black tank first.
Once it's empty hook a non-drinking water hose to the tank flush fitting (located just above the city water connection). With the black tank valve still open, turn on the hose and flush for a couple of minutes. Shut off the hose and let the tank drain.
Close the black tank valve.
Open the grey tank valve. Close when it's empty.
It's good to put a gallon or so of water in the black tank before you use it again, so things aren't landing in a dry tank and getting stuck there.
2019 Ford Expedition Platinum
Old 05-19-2014, 09:35 PM   #3
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
If I can, let me add a little to Wayne and Sam. Buy a clear plastic elbow to hook between the drain fitting and the hose. This will show you when clear water is flowing from the tank. After I drain and flush with the water hookup, I close the valve a couple of minutes with water still running then reopen to drain that partial fill (depends on your tank size--mine is 38 gal and two minutes will not even 1/2 fill the tank back up). That floats any paper, etc that might still be clinging to the sides, etc. Finish with the drain open and the flush water running for a few minutes. If you drive a distance before emptying the tank, everything will be liquid and drain/flush clean quickly. If you empty the tank as you leave the park, solids and paper will still be solids and thus will take longer to flush clean. Put your tank deodorizer in toilet, flush down and you are good to store. Like Wayne said, drain gray water last. I've found some people using regular toilet paper. That will for sure stop a macerater type toilet and will sooner or later cause dump valve problems with the drop valve type.
Howard L. is offline   Reply With Quote
Old 05-19-2014, 10:48 PM   #4
Orinda , California
Thank You
Dear Wayne & Sam and Howard,
You've been a giant help. We're on day 3 of our epic adventure and your advice will ease our minds.
Old 09-15-2014, 01:46 PM   #5
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Here is a picture of what your looking for. I don't think you can know for sure if system is clear without one of these it also has a connection which sends water stream up into the doing itself. Instructions are on the side. Click image for larger version
Name:	ImageUploadedByAirstream Forums1410810302.079374.jpg
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 09-15-2014, 05:28 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I agree with the clear plastic fitting. Watching the black tank drain ain't the greatest show in town. But you know when it is flushed and draining clean. I was surprised how many rinses it took to get all the paper out. And I agree with keeping the bottom of your black tank wet. The age old idea of pouring 5 lbs of ice chunks into the black tank and then towing your trailer home on the last leg of your trip sure helps scour the sides of the tank clean.
David
Black tank flushing beetlebob Plumbing - Systems & Fixtures 17 09-14-2013 05:52 AM
Black colored water when flushing toilet Mikec1231 Plumbing - Systems & Fixtures 3 06-20-2013 06:09 PM
First emptying of the black tank Getahobby Waste Systems, Tanks & Totes 8 08-08-2012 11:32 AM
Propane Tank Emptying & Certifying drober05 LP Gas, Piping, Tanks & Regulators 1 11-03-2003 11:35 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
