Old 10-02-2005, 08:16 PM   #29
redeagle313's Avatar
NE , Indiana
check out the Yamaha EF-2400IS
This unit is a little heavier and a little more money than the EU2000, but it has the extra power to probably do it with one generator. And they can be run in parallel like the Honda. Check out this link for a propane/natural gas/gasoline capable generator. http://www.yamaha-propane-natural-ga...m/ef2400is.htm
OR for an EBay auction
http://cgi.ebay.com/Generator-YAMAHA...QQcmdZViewItem
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 10-02-2005, 10:00 PM   #30
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
What is needed to get the Yamaha to run on propane? Just a hose kit?
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 10-02-2005, 10:11 PM   #31
NE , Indiana
The dealer in this link specializes in setting up Yamaha generators for alternative fuels. That would be a good question to ask them.
http://www.propane-generators.com/yamaha-generators.htm
TAC IN-3
AIR 7185
Old 10-02-2005, 11:57 PM   #32
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Originally Posted by juel
Has anyone bought a brand of generator other than a Honda? I love the Honda brand; however, they are so expensive. I have a 24ft Argosy, with a new 13,500 AC. I know the 3000 Honda would probably pull it, but there are other generators that are far less expensive. I know about the noise feature of the Honda and the Yamaha. Is that the primary reason so many RV people buy them? I would just be using mine at the lake property and noise level is not the primary concern. Consumer Reports rates the Troybilt highly. There is also a Coleman with a Honda engine that is quite reasonable for a 5000 watt.
"This site has a huge discussion on Chinese gensets.http://www.woodalls.com/cforum/index...d/15131645.cfm "
The one big selling point is the Honda is quiet. It is the only point as a matter of fact. If you buy one of these others you will be cussed if you run it around anyone else.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 10-03-2005, 07:23 AM   #33
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Juel,
The Honda Inverter gens have "clean" power. The clean power is great for TV, computer etc.. The other non inverter generators are cheaper b/c they are much louder. Go to your local Honda dealer and get them to start the different types and make your choice.
We decided on the two Honda EU 2000 with a parallel kit. We had our house wired for a 30A hookup for our trailer and we also use our Honda's for our house backup.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 10-03-2005, 07:24 AM   #34
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
The Honda i series puts out clean power. Could be a factor for long life of appliances, tvs, and computers.
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 10-03-2005, 07:35 AM   #35
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
. Using a siphon type device to take it out of the tank of the burb is a neat work around, but where do I put the gas fumed hose, the Suburban or the Safari?
Twink,
I just tried to siphon gas out of my 2500 Burb. The fuel filler tube has an "anti roll-over" ball. There in no way to get a hose around the valve.
If you are able to siphon let me know...
Hensley Hitch
Honda EU2000i dmac Generators & Solar Power 35 06-01-2010 11:09 AM
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 04:39 PM
**Generator Noise** Silvertwinky Generators & Solar Power 14 08-21-2003 07:41 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
