Old 12-15-2014, 05:18 PM   #1
1000W Inverter not working even with full battery
Can anyone help me identify why my inverter in airstream international 19 doesn't work. The battery is fully charged and when I turn on the inverter via the remote switch it will turn on for a few seconds and then shutoff the inverter shows error code E04. Any ideas?
corymac is offline   Reply With Quote
Old 12-15-2014, 05:20 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
When you looked up the error code in the inverter manual what did it say?
Al - K4GLU is offline   Reply With Quote
Old 12-15-2014, 05:22 PM   #3
I don't think it had the exact code but it did say a red led light indicates inverter failure
Old 12-15-2014, 05:23 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
A bit more detail would help a lot. What type and manufacturer of inverter do you have? Which batteries and how large is their capacity?
Old 12-15-2014, 05:25 PM   #5
2 12v batteries deep cycle I think
Old 12-15-2014, 05:27 PM   #6
Manufacture is WFCO electronics I believe the model is WF-5110 H
Old 12-15-2014, 05:35 PM   #7
lewster's Avatar
IIRC, E04 is an overload fault. You can't repair any WFCO product like you can with the Magnum units, but an overload can indicate a bad internal component (AC board, etc.) or is simply indicating that an event occurred and a hard reset is needed.
A hard re-set is accomplished by removing all power (both AC and DC) from the inverter for 15 minutes. Re-connect and try to operate it again. If the error code persists, your inverter is toast!
Smell anything burning?
Old 12-15-2014, 05:44 PM   #8
So just to be sure are you saying I should disconnect the batteries and reconnect them after 15 minutes and that may reset the inverter?
Old 12-15-2014, 06:14 PM   #9
lewster's Avatar
Yep.
Old 12-16-2014, 07:25 PM   #10
drftboat's Avatar
2012 16' Sport
2015 19' Flying Cloud
Seattle , Washington
I recently, a couple months ago, took delivery of a 2015 19FC. Just as you described the inverter did not work once the remote (wall switch) was pushed and green light on. I read the manual, called WFCO and they confirmed 1) a red light was bad (failure) and 2) asked me to isolate and test. I bagged it and returned to the dealer. The dealer was Johnny on the spot and quickly determined that the unit was bad and replaced it. Your situation sounds identical to mine. Exercise your warranty. Hope this helps.
drftboat is offline   Reply With Quote
1000w inverter for Dometic Rm3762 GammaDog Electrical - Systems, Generators, Batteries & Solar 16 11-14-2014 09:18 AM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
600w vs 1000w inverter SilverEagle6 Batteries, Univolts, Converters & Inverters 14 12-02-2013 06:38 PM
1000w+ solar Airstream Darkspeed Generators & Solar Power 26 08-19-2011 10:41 PM
