Greetings JB!
Welcome to the Forums!
Originally Posted by johnboy
Can anyone also post a good resource with information on inspecting AS units. Particularly axles & floor sturdiness? Other things to look for? Is there a "bible" of used AS's?
Thanks for the help.
jb in bboo.
Two resources that will at least, in part, answer the two questions above are:
Vintage Airstream Price vs. Condition
Airstream Henschen DuraTorque Axle Inspection Data
About the best guideline that I know of in regard to inspecting the floors is to visually inspect the junction of wall with floor around as much of the perimeter of the coach as possible - - a fine probe or awl can help to determine if a suspect area happens to be soft - - most suspect areas would include the floor under and near the bath; the floor under water heater; the floor under and near water tank; the floor directly in front of the entry door; and the floor in the front of the coach directly below the front window.
There really aren't any books that have been published so far as I know that focus upon restoration of RVs whether Airstream or other makes. This Forum is a great source as is the Airstream list on Yahoo (Hunter's List); and for Vintage Airstreams there is the Vintage Airstream Club Discussion List (e-mail based discussion forum). There is a generic book that can assist with the basic functioning of the RV systems that is often recommended for beginning RVers - -
RV Repair and Maintenance by Bob Livingston
Good luck with your research and investigation!
Kevin
