Wanted - Bambi Or Smaller AS
Greetings Montanaandy!
Another option, if you aren't determined to have polished aluminum, is the Argosy Minuet. The Minuet was produced from 1977 to 1979. It is 6" narrower than the standard Airstream/Argosy trailers of the period, and it was available as a 6.0 Metre (19' 3") , 6.7 Metre (22'), and 7.4 Metre (24') - - the two smaller coaches have single axles while the 7.4 Metre has tandem axles. In the 6.0 Metre and 6.7 Metre, the twin lounge model probably provides a slightly better sleeping arrangement (I may be biased as this is the floorplan that I sought-out when I purchased my Minuet). The 7.4 Metre has a center twin arrangment or a center double (convertible lounge) arrangement very similar to the Airstream Tradwind. The one thing to be aware of with the 6.0 Metre trailers is that you will likely find them to have composite aluminum floors which can complicate selection of new floor coverings.
I find my Minuet very easy to tow, in fact my Suburban rarely varies from its solo fuel economy when towing the Minuet. It is also nice to have a trailer that even the modest slide-on rear view mirror extensions can handle.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
