Old 04-25-2008, 04:16 PM   #1
flush riveter
bbwwjd's Avatar
1967 24' Tradewind
kelso , Washington
What wrong with the classified function????
I have tried in vain for an hour to post an ad.And it just keeps asking me to log in,even tho' I did log in dvery time and it states that I am logged in. Please help Thanks,Len
bbwwjd is offline   Reply With Quote
Old 04-25-2008, 04:28 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are using Fire Fox it is a cookie issue. If Fire Fox you have denied a secondary cookie some time in the past that allows access to that section. I have had the same problem in the past.
If this is the case go to Tools, options. privacy, exceptions and look for any Air Forum cookies that is Blocked. Remove the Blocks one by one till you find the one giving you the problem.
If you are using another browser, internet explorer, it may be the same problem. Internet Explorer has tried to copy Fire Fox to become a usefull browser and they may have set the same conditions.
2004 Excursion 4x4
Old 04-25-2008, 04:45 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
I was just able to load a test ad. When you go to the classifieds page, look in the upper right hand corner - you may have to login there.
AirForums Custom Search
Janet H is offline   Reply With Quote
Ignore Function doorgunner Forum Admin, News and Member Account Info 56 01-31-2008 08:56 PM
Search Function Busted 66Overlander Forum Admin, News and Member Account Info 6 11-27-2007 09:09 PM
Search function? markdoane Forum Admin, News and Member Account Info 6 09-13-2007 11:35 PM
univolt function mlmarch Classic Motorhomes 12 04-13-2007 01:39 PM
What is this function? bkpine Fresh Water Systems 2 08-15-2002 04:01 PM
