02-22-2016, 08:43 PM
Remember, Safety Third
Catfish Corners
, Georgia
User CP issues
My User CP is having issues updating. It shows me the new posts in threads I've contributed to.....just as it should. But when I go to a thread and view the new posts, that particular thread still shows as having new posts in the User CP. Same in Quick Links when I bring up Subscribed Threads.
Windoze 7 using Google Chrome. I'll go try it in IE on the same machine. Yep, same there.
02-22-2016, 09:16 PM
Alamo Heights
I'm seeing the same behavior. I'll send a note to the tech types.
DKB
— David
02-22-2016, 09:35 PM
1976 25' Caravanner
Salt Lake City
, Utah
Me, too. Thanks for catching this!
02-22-2016, 10:20 PM
Alamo Heights
This was already being worked on when I contacted the HelpDesk. They'll get it squared away.
— David
02-23-2016, 12:01 AM
2005 19' Safari
GLENDALE
, AZ
I noticed other peculiar behavior that started this evening. When the THANKS button is selected to send someone a Thank You Note, a box appears with the following text, and the regular Thank You text entry box is missing:
www.airforums.com says:
You cannot give reputation to this user.
02-23-2016, 04:50 AM
Retired.
, At Large
I just tried to give you thanks for that post, and got the same message.
Then, I tried quoting your post, and was unable to do so.
I clicked "quote", and as you can see, it didn't.
02-23-2016, 02:36 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
This should all be fixed now - thanks for posting about it.
02-23-2016, 05:51 PM
Retired.
, At Large
Your thanks worked, and my quoting your post worked. Looks good from here.
02-24-2016, 02:08 AM
2005 19' Safari
GLENDALE
, AZ
Janet, thanks for your quick response and corrective action!
02-24-2016, 01:26 PM
2016 25' Flying Cloud
Albuquerque
, New Mexico
As a new member/owner, I wanted to add a picture of our new trailer. Following the guidelines, I tried to load a 99kb file, but it kept saying that it failed. The specs called for under 100kb. Is there something I'm doing wrong? I also added the model of our tow vehicle, but don't see that information.
02-24-2016, 03:29 PM
Alamo Heights
For your avatar (the small photo that appears on the left side of each post) there are 2 limitations... 100kb *and* 120x120 pixels. You have to be within both of those parameters for the avatar photo.
The profile picture, that only shows when someone looks at your public profile, the limit is still 100kb but the size can be as much as 400x400 pixels. I see you already have one there, though, so it's probably the avatar that's causing you trouble.
The tow vehicle info you type into your profile shows in the profile (I see that yours is a 2013 Denali, for example.) It's not displayed in the left-hand field but you can put it in your signature if you like.
— David
