Anyway for Mac folks, if you're trying to use Safari here, some update either on this site or from Apple has blown something up for use with this site, but on others the functionality still works. IE might be a good alternative until the fix on either end is found.
It's not Safari, that is what I use. I have had issues starting new threads but no more so than Windows users.
I had problems starting thread too.
The fix I used (per Kevin) is to clear my cookies and cache for my browser. Wiz bang problems went away.
Kevin mentioned that when the software is upgraded, the old cookies do not always work with the new revision.
Tedd Ill
AIR#3788, WBCCI#4028 Membership discontinued
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
Thank you, thank you, thank you! Had noticed that this morning, but my brain hadn't registered yet that THIS IS DIFFERENT!Nancy
Originally Posted by Organic Hosting
I think the page title issue has been fixed. I am looking into a better solution though that removes the opening text of the title on thread pages. I'll keep you posted...
I'm getting a 404 error when I try to access the private message system. There's some messages in there with phone numbers I need, and now I can't get them. I knew I should have written them down! Anyway, I hope it's working again soon!
BTW, I cleared my cookies and now I seem to be able to start threads again. Cool.
Back to only being able to use the quick reply instead of post reply and I am having the same 404 error message when I try to click on private messages up in the right hand corner under my login. I can only access messages by clicking on "user cp" and then "list messages".
Not knowing enough to be afraid...
Andy, didn't the Topic Title links on the portal page used to have &goto=newpost in them, like the emails? It's a little inconvenient to be taken to the first post, especially in a multi-page topic, and clicking the tiny goto last post is not only harder, but often isn't where I want to go... that being the first unread new posting. Can this be changed?
Thank you, Andy, the button is doing goto=newpost instead of lastpost now. The ALT tag on the buttons still says "go to last post", for what it's worth.
