Go Back   Airstream Forums > Airstream Community Forums > Forum Admin, News and Member Account Info
Old 10-18-2015, 05:29 PM   #1
1972 27' Overlander
Woodburn , Oregon
Univolt why so heavy ?
I just removed the old univolt in my 1972 overlander and when I went to lift it out it really made me grunt, it must weigh over 60 lbs , I was wondering what's inside one of these old Bruts that make them so heavy ? I'm really curious 🇨🇱
shineybullet is offline   Reply With Quote
Old 10-18-2015, 05:32 PM   #2
Because of the transformer that's in it for conversion
0557 is offline   Reply With Quote
Old 10-18-2015, 06:31 PM   #3
1974 Argosy 20
Kooskia , Idaho
Prior to switching power supplies about the only way to convert voltage was with a transformer. In this case a big heavy one.
Electronics changed all of that, but transformer systems are still simple, very reliable and easy to understand. But the old Univolt is simply obsolete as a converter/charger system.
Old 10-18-2015, 07:19 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Good old solid American made steel and iron. Almost bullet proof and make great boat anchors.
MICHAEL
Old 10-18-2015, 08:34 PM   #5
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
The reason it's so heavy is because it's got A LOT of copper for the windings. Take it apart and you'll see. Most of it can be recycled.
DryFly is offline   Reply With Quote
Old 10-18-2015, 09:22 PM   #6
Mission , Texas
... wondering outloud why I didn't remove ours when I had the bathroom partially disassembled to replace the shower valve and plumbing ...
nrgtrakr is offline   Reply With Quote
Old 10-18-2015, 09:24 PM   #7
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
The size of a transformer is inversely related to the frequency for which it's designed... so a switching mode power supply that runs at 20+khz will have a much smaller transformer than a 60hz model.
In the end, the ferroresonant Univolts are prob. more reliable than the
switching supplies that have replaced them - but the new units are much cheaper, more efficient and quieter. The new systems also provide for temperature adjusted charging voltages, and the three-stage systems won't cook your batteries, either.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 10-18-2015, 09:40 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
They are far lighter when you let out the "magic smoke"!
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-18-2015, 10:28 PM   #9
1972 27' Overlander
Woodburn , Oregon
- Bart
It looks like mine must have quit working years ago,some pasr owner cut off its power cord to the Uni volt and wired a small battery charger in its place I'm putting in a 45 amp smart converter in its place with 2 huge 12 volt yellow top batteries
Old 10-19-2015, 11:01 AM   #10
belen , New Mexico
1st one I replaced was in my 77 ambassador (in1999) and it was suddenly sooo quiet!
alantbird is offline   Reply With Quote
Old 10-19-2015, 12:13 PM   #11
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I gave mine to a local HAM radio operator. He changed it to an oil filled unit and is happy to give it a new home. I was happy to get the 75 or so lbs out and a new quiet converter in.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 10-19-2015, 03:11 PM   #12
1974 Argosy 26
Joshua Tree , California
NRGTRKR: thanks for the confirming word. I still have our bathroom and closet apart for plumbing replacement. Might as well jump into that too!
StarckMad is offline   Reply With Quote
Old 10-19-2015, 04:32 PM   #13
Mission , Texas
Hahahaa!!!
Anytime ...
I wonder if it will fit through the battery box door if the battery compartment liner is removed?
I like our AS, but wonder about space utilization at times.
Old 10-19-2015, 04:51 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe that the early univolts were ferroresonant, which added to their weight.
Ferroresonant transformers provide a measure of passive voltage regulation, and were a reasonably common design choice before high power MOS devices were available.
Old 10-19-2015, 07:31 PM   #15
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Boat anchors are always heavy!!
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Why is my 1979 so heavy? KYAirstream Towing, Tow Vehicles & Hitches 23 08-23-2015 07:32 PM
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
why new 34' so heavy- 2007 Classic? boondockdad 2006 - 2010 Classic (all lengths) 6 06-21-2007 03:17 PM
why would the univolt boil the batteries dry silver 67 Electrical - Systems, Generators, Batteries & Solar 11 07-08-2005 03:20 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
