Go Back   Airstream Forums > Airstream Community Forums > Forum How-To's & Support
Old 02-05-2004, 11:43 PM   #1
jaco's Avatar
Profile:
Thread ID # from Post ID #
Up in the address bar on my IE there is the url of whatever web page is on my screen at a given point in time...right?
When I access a thread from the "last 25" section of the main interface that url always indicates only the post #. No matter which post in the thread I happen to be viewing.
But
If I access a thread by means of a search, the url displays a thread#. ???go figure
Also if I browse using the forum interface I get the thread ID#.
Its' just that the "Last 25" is the most convienient or at least I'm in the habit of using it to browse.
I much prefer thread numbers when I am entering worthwhile threads into my notes.
Is there a simple way to determine the thread # when the post# only is showing in the url?
BTW am I safe to assume that the thread # is static and will never change ?
Lastly does this forum software have a feature available where a "go to" box could be placed on interface and just a thread # could be entered to transport to that particular thread?
I think that would be a useful and practical tool.
jaco is offline   Reply With Quote
Old 02-05-2004, 11:48 PM   #2
tin can luv's Avatar
Profile:  1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
You lost me at IE...
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 02-06-2004, 12:24 AM   #3
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
jaco
I'm not sure about "all that" techy stuff...however, I do know that the thread number is constant, as is a post number. I believe the reason the post number shows up when you select from the "last 25" section is just that...it's the last 25 posts, not threads.
Why it does whatever else you said it does, I have no clue. Maybe someone more techy will be able to explain better than I. Here are a couple of ideas/suggestions though...
1. To view the "thread #" after selecting a post from the "last 25" section, you can go up one level in the string title at the top of the page:
"Forums > Airstream Community Forums > About these forums, How-To's & more... > Thread ID # from Post ID #"
on this thread, which will put you in the forum. From there you can reselect the thread by title and the thread number will show up in your URl area. Make sense???
2. Have you tried the "view new posts" option? I have found it real helpful when I don't get a chance to check in very often...it shows all the threads with new posts since the last time you visited instead of just the last 25 posts.
3. It sounds like you are somewhat familiar with the "search" feature...you can just type in a couple of keywords and a plethora of threads relating to the topic will show up....all the way back to the beginning of time. Saves alot of note taking effort, in my opinion.
There are so many different options and ways to use the forums...after awhile, you'll feel more comfortable with the way it works. Good luck & welcome aboard!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
