Old 12-11-2003, 03:21 PM   #29
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I am still having the same problems.
I just ied it with Netscape 5 on an imac, running OS 9.2, with the same results. i am also getting "mailbox full" messages, but all I had were 7 saved PM's. Maybe the capacity is that small, which is fine, but the new mail icon won't disappear and the new message window pops up unless I delete the read message, or move it to a folder other than the in box.
Last night at home, using a different computer on a dial up, I was having the exact same issues, only worse due to the slow speed of the dial up.
I want to emphasize that I am very appreciative of the site and it's value to me. But this issue will make it impossible for to take a few seconds between calls and scan through new posts, or send replies to questions because of the time invovled in loading the pages.
53flyingcloud;
we're on macintosh here, and most of the sweepers you had mentioned will only work for windows, as far as I can tell.
And: all other sites work fine and efficient. So I doubt it's in the machine.
Uwe
www.area63productions.com
Old 12-11-2003, 03:37 PM   #30
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb You might check..
uwe
You should check your email account (PM) again for 'stuff' in the track message, send items and, inbox..
Need to put a 'check mark in the "box" and, then hit delete.
Try to clear out as much as possible. It should be okay to save a few things as it can hold a rather fair amount. (I just like to keep mine clean.)
You could be right about the Window version. I'll check again for you now that I know you're on a Mac.
Just did a quick check. Yep, you're right..Windows
btw, do you have Java loaded and, enabled on your puter?
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-11-2003, 03:49 PM   #31
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Yep. Java be on and present. At least on the machine I am on right now. 47weewind's description of this pesky issue matches mine to a T.
The mailbox thing is not an real issue, just that i am not getting some of the PM's. I'll go check to see if there's hidden PM's in the tracking etc. folders right now.
Thanks for everyone's input.
Uwe
Old 12-11-2003, 03:50 PM   #32
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Most folks don't realize that there is a sent message folder which can be the crux of the space problems since there is a copy of every thing you have ever sent in there.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-11-2003, 03:50 PM   #33
1984 29' Sovereign
Savannah , Missouri
Kewl`
Good luck..
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 12-15-2003, 02:02 PM   #34
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I was wondering if the issue with site slow downs is still happening for our Mac users out there?
I had not noticed a difference in the past, but I was wondering if it was still an issue.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-15-2003, 02:33 PM   #35
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I took Jack's advice and deleted averything I could find in the "sent" folder. This helped with the mail problems, actually resolved them.
The pages are still loading slow at times, but i did have a few times when the pages loaded quite quick.
It was lightning fast for a few days after the server change. It is definitely much slower now.
I just make sure I have time to wait whenever I go on the forum.
Uwe
Old 12-15-2003, 02:35 PM   #36
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
BTW,
just now it was "lightning quick" again, not more than a quick blib on the screen before the page changed...
Just tried the edit feature - works great right now.
Uwe
Old 12-15-2003, 06:57 PM   #37
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
This Mac user has noticed a favorable change in speed, better than before without the hang-ups. Whatever was done - its working! Thanks.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-15-2003, 08:09 PM   #38
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Andy told me that there was a DNS lapse in the random ad generator at the bottom of the page. During the time period that you were all having trouble the banners were not populating. I was just wanting to see if now that they are working again(banners), the speed issue is resolved.
Glad it is. Thanks for the updates.
Brett G
Old 12-16-2003, 10:55 AM   #39
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
My system now works very well once again. No hangups, and quick page changes, just like before.
Thanks for fixing the problem.
Uwe
