Search Function Busted
I have periodically check to see which threads are the most active by using Advanced Search and specifying a minumum number of replies as part of the search. This used to work just fine, but for at least a couple of weeks (or maybe longer) it's not been returning the correct results.
For example, do an Advanced Search on the word "Airstream" and request only results with a minimum of 1900 replies. This search should return 3 results, but it currently is returning only 1. A similar search with a 1000 reply limit is returning only 4 results, but I think it should be returning two to three times that number of results.
Please look into this and get it back working correctly. Thanks.
Joe
WBCCI/VAC #5533
'94 28' Excella / '05 Hummer H2
(and casually seeking a vintage AS)
