Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 02-17-2019, 10:16 AM   #1
BobAndStella's Avatar
2017 25' Flying Cloud
Monterey , California
Satellite coax cable
We have a 2017 Flying Cloud FB Twin. We just bought a Dish Playmaker and Wally receiver and are trying to connect things. Should be straightforward - yes?
The owner’s manual says the receiver end of the coax cable is ‘under the Blu-ray’ player. Can anyone tell me how to get in there? Without breaking apart the wood enclosure!
BobAndStella is offline   Reply With Quote
Old 02-17-2019, 11:43 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Take out the Blu-ray player. It is Velcro’s in place. You can slide a plastic card between the layers of Velcro to release. Sat coax is in there. You can then fish it up through the hole where the hdmi cable comes up at.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 02-17-2019, 04:02 PM   #3
Thanks, that did the trick. I hope Airstream engineers have improved that layout because it definitely is not consumer friendly. It was only the fact that my wife with her smaller hands/arms was able to reach it and snake it through the side opening that we succeeded, albeit with a few scratches and scrapes!
Old 02-19-2019, 09:15 AM   #4
I got a call from the helpful folks at Toscano RV. Rick guided me to two, small, round, plastic screw covers on the right side of the enclosure. Removing the screws allows the whole enclosure to slide right and then lift up. Much easier to access the area beneath - no more scrapes or scratches :-)
Old 03-13-2019, 03:38 PM   #5
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
SAT cable behind radio
Although the manual states that the cable will be found under the DVD player. That is not always the case.
In my 2016 International Signature I had to remove the DVD unit, remove the bottom railing of the sliding plexiglass doors to be able to remove the panel (with the two 110V wall plugs) to get to the cabling behind the radio. I found the SAT coax cable there (labelled SAT) among all the cables behind there.
The cable had two strips of electrical tape leading me to believe that the cable was taped to the rest of the cable harness but broke off during installation and remained walled in behind the panel.
This should be part of AS quality control.
Hermes is offline   Reply With Quote
Old 03-13-2019, 04:38 PM   #6
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Whoever gets chosen for the customer advisory board should make that rats nest a priority with Airstream. In my Classic it is embarrassing! Under the dinette seat is 3 times worse. My SAT cable was lost in the lower wall and I had to take the TV cabinet apart to find it.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 05-01-2021, 09:42 AM   #7
2019 25' Flying Cloud
Roodhouse , Illinois
Is the coax to the cable in that rat nest also? I want to use it for my cell booster so I can come thru screw in on the outside by the sat cable.
Carla Wise is offline   Reply With Quote
Old 05-01-2021, 10:06 AM   #8
2013 30' Flying Cloud
Kingwood , Texas
The Cable connector from the outside is connected to the back of the booster coax connector that your lounge television is connected to.
DoubleR is offline   Reply With Quote
Old 07-21-2021, 11:45 AM   #9
2018 19' Flying Cloud
Bellingham , Washington
Sat TV Coax Was Cut
New FC25 I just picked up. After digging, I found the receiver end of the coax under the DVD player - but, the cable had been cut between the wall and the connector. I will try to trace the signal to the exterior connector to make certain that it really connects and then, I guess try to put new connectors on the inside coax. Any other thoughts?
jpedlow is offline   Reply With Quote
2013 25" Eddie Bauer Ed. Satellite coax system info please! kjbowler Computers, Internet & Satellite 13 04-26-2014 05:47 AM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Outside Coax Cable Box & Antenna Rolo Audio, Video & TV 0 06-07-2011 07:20 AM
Cable TV/ Satellite Receiver Dual Coax Face Plate pwesterman 2008 Safari SE 2 11-14-2010 01:09 PM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
