12-05-2014, 12:15 PM
Sneedville
, Tennessee
Recall notice
I just received a letter in the mail notifying me of a recall on certain model 2014 and 2015 trailers.
It says there might be a problem with the "power inlets" having loose connections that might get hot enough to start a fire.
Remedy is to inspect and replace the power inlet.
12-05-2014, 05:30 PM
2014 25' Flying Cloud
New Ashford
, Massachusetts
I rec'vd one as well. I like how it says certain models? Why doesn't it just tell us which models.
Joe D
12-05-2014, 05:55 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I am somewhat concerned about your posts. We are currently out in New Lucy (2015 FC 25FB) and will not be back at home until after Christmas, so I am not receiving any nail mail. I do not know if I have received a recall notice from Airstream.
I am assuming that the power inlets referred to are the outside power connectors for the 30 amp shore power cord.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-05-2014, 06:40 PM
Sneedville
, Tennessee
I would assume that the recall applies to you as well. Maybe you could call the dealer and have them check your VIN.
I am assuming the power inlets are where the generator and power cord plugs into the trailer.
12-05-2014, 08:42 PM
Durango
Does it say exactly what an owner is suppose to do?
I have a 2015 Serenity and live a long way from any Airstream dealer.
What do they mean by loose? Loose on the inside of the trailer. The external plug screws on so how can it be loose?
Not sure what exactly that recall notice means.
12-05-2014, 09:27 PM
2005 28' Safari S/O
Paradise
Found this on the Canadian Government website, but nothing listed on the US Recall website yet... Road Safety Recalls Database
Steve
"THE OLDER I GET, THE BETTER I WAS"
12-05-2014, 09:32 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
I'd call the mothership on Monday Morning - probably something any competent electrician can fix. Meanwhile just go feel every inlet/outlet to make sure you don't have any hot spots.
It SOUNDS like it might be the 30 amp cord inlet.
May I suggest a workaround for the weekend? I had a 30 amp cord stolen on a very cool night. I ran a heavy duty extension cord from the post through the fantastic fan (Just snap out the screen and open the lid manually, then tighten it down so it'll just allow the cord through. ) Hooked up a space heater and kept nice and toasty. I had a second cord I could have also run had I needed it.
Paula
12-05-2014, 11:19 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Do they not know which serial numbers have the defective parts ... it would be nice to know rather than just receiving the general letter of recall ...
12-06-2014, 07:52 AM
2018 23' Flying Cloud
Huntsville
, Alabama
Thank you for posting the links for the recall.
Ron
12-06-2014, 08:04 AM
Sneedville
, Tennessee
It affects all AS trailers manufactured between 11/26/13 and 8/14/14. The issue is the Furion plug assembly (I would assume front and back).
12-06-2014, 08:05 AM
Sneedville
, Tennessee
Paula
Fixing it yourself is an option, but you'd still have an open recall notice on your trailer. Might be an issue if you ever decided to sell.
12-06-2014, 08:18 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
One might hope that an independent shop could do the check as some dealers I would not trust to touch a cabinet knob inside my trailer, let alone the electrical system.
Fortunately, when our trailer inlet service was completely rewired for our solar system, the Furrion power connection hardware was checked as that wiring was totally replaced as it went to a new fuse power box.
12-06-2014, 08:42 AM
2015 27' Flying Cloud
2011 30' International
mooresburg
, Tennessee
can someone remind me how to read the vin number?
12-06-2014, 09:19 AM
Cuddebackville
, New York
I was going to have to get one of the Furion connectors replaced anyway- the LED doesn't work on one of them.
It sounds like it's not defective parts, but improper torque on the lugs when installed.
2019 Ford Expedition Platinum
12-06-2014, 11:24 AM
Sneedville
, Tennessee
The way I interpret the descriptions in the supporting documents, Furion, had a bad batch of plugs with bad terminal screws/bolts that would not stand up to proper tightening which results in the loose connections.
12-06-2014, 12:19 PM
Cuddebackville
, New York
Right Mrprez. I missed that.
12-06-2014, 12:20 PM
Cuddebackville
, New York
Left to right?
12-06-2014, 01:04 PM
Sneedville
, Tennessee
Street side front corner right behind the rock guard.
Left to right?
Oooh you're bad!
This recall is not VIN specific. It affects all trailers made between Nov/13 and Aug/14. See above for specific dates.
12-06-2014, 01:43 PM
Durango
Well mine went onto the line on Sept. 29, 2014. So I guess I am in the clear. I also haven't received a letter from Airstream.
Thank you for the info and links, mrprez.
