Old 12-06-2014, 04:40 PM   #29
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
On my Serenity the 50 Amp connection is by Marinco and looks like this:
50 Amp 125V/250V Stainless Steel Power Easy Lock Inlet without Rear Safety Enclosure | Marinco
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-06-2014, 04:47 PM   #30
gtc6452's Avatar
2015 27' Flying Cloud
2011 30' International
mooresburg , Tennessee
Mine is the same.
gtc6452 is offline   Reply With Quote
Old 12-06-2014, 08:05 PM   #31
Tincampers's Avatar
Sneedville , Tennessee
So, did you install these 50 amp inlets yourself? What is the advantage to these?
Tincampers is offline   Reply With Quote
Old 12-06-2014, 09:33 PM   #32
Msmoto's Avatar
2007 25' Safari
Images: 135
The 50 Amp input is standard on the trailers with two A/C units. Single A/C trailers have a 30 Amp service.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
AIR #31871 K4MTL
Old 12-06-2014, 09:43 PM   #33
Tincampers's Avatar
That makes sense, thanks.
Old 12-06-2014, 10:52 PM   #34
BassCan's Avatar
2014 27' FB Eddie Bauer
Mobile , Alabama
We have fifty amp and solar and just received the recall in the mail today.
BassCan is offline   Reply With Quote
Old 12-07-2014, 04:26 AM   #35
Msmoto's Avatar
2007 25' Safari
Images: 135
As I understand it, the recall group was determined by manufacturing date only. Thus, a lot of folks will contact their dealer and be told no action is needed, or so I think. We will see tomorrow.
Ms. Tommie Lauer
AIR #31871 K4MTL
Old 12-07-2014, 04:53 AM   #36
Tincampers's Avatar
Is the factory 50 amp inlet made by Furion?
Old 12-07-2014, 05:17 AM   #37
Msmoto's Avatar
2007 25' Safari
Images: 135
On mine, the 50 Amp inlet is made by Marinco.
Ms. Tommie Lauer
AIR #31871 K4MTL
Old 12-07-2014, 05:19 AM   #38
Tincampers's Avatar
This recall only applies to inlets manufactured by Furion.
Old 12-07-2014, 05:45 AM   #39
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by gtc6452 View Post
can someone remind me how to read the vin number?
My 25' has a "Manufactured by" sticker that gives the VIN, axle and tire info as well as the month and year of manufacture. Mine is October 2013, so I'm in the clear.
2012 Dodge Durango Hemi/AWD
Old 12-07-2014, 06:47 AM   #40
Msmoto's Avatar
2007 25' Safari
Images: 135
RE VIN:
World Manufacturer Identifier 1,2,3
Vehicle Attributes 4,5,6,7,8
Check Digit 9
Model Year 10
Plant Code 11
Sequential Number 12-17
As seen in one of my previously owned trailers
Airstream 25 SS International from 2007
VIN:
1ST
CFYJ2
6
7
J
52xxxx
AIR #31871 K4MTL
Old 12-07-2014, 06:38 PM   #41
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I installed a new Furion 30 amp connector on my 1966 Trade Wind. I remember how "cheap" the fasteners were that are used to clamp the wire to the plug. But I'm sure I got the wires tight. I can see how you might apply torque to the screw and think your tight but not really. I believe I purchased it from VTS. It looked like a high quality piece.
I wonder if a guy could do a resistance check from the plug to the breaker box connections. You would expect very low resistance. But if it was 50 ohms or 500 ohms, it might indicate a poor connection. I guess I could do a infrared heat image of the plug while the AC is on. That would tell me if I had a hot spot. We did this yearly in the factory looking for trouble in the load centers.
Furion has a problem on their hands.
David
PS I have installed a 2024 T3 door on my new water heater. It ain't white any longer. I didn't want you to think bad things about me.
Name:	1406 Electrical New Twist Lock Plug.jpg
Old 12-07-2014, 06:56 PM   #42
Tincampers's Avatar
The 30 amp Furrion Square with LED can be bought for $40. Might be cheaper than a trip to the dealer.
NHTSA Argosy recall notice bkahler Argosy Motorhomes 3 10-22-2007 11:45 AM
2004 Recall Notice andyfuson Axles 91 10-18-2005 07:33 PM
Recall notice~ 53flyingcloud LP Gas, Piping, Tanks & Regulators 1 01-02-2005 06:51 AM
Hey, anybody notice... CanoeStream Off Topic Forum 1 01-26-2004 11:59 AM
